Question about Hoover Dishwashers
HEDS 668-80 all four lights flash, it beeps 20 times or so and then the lights come on and I can't do anything with it. Woke up this morning machine had been on overnight and the trip switch had tripped (don't know why). Water had leaked from machine, but I tested it with some water and the pump seemed to work ok. It wont reset now
catriver
  • 878 Answers
SOURCE: Dishwasher tripping the circuit breaker
Andy, leave the breaker off and remove the toe panel (bottom panel) from the dishwasher. Remove the cover of the junction box where the cord connection or wiring is made. Look at the wire caps and see if they are not burnt. Sometimes these connections become loose and arch, tripping the breaker. If so, cut the wires, strip a new end and reconnect. Catriver...post back.
Posted on Aug 21, 2006
watugot
  • 290 Answers
SOURCE: dishwasher is tripping off our safety switch
It depends on what kind of test he was doing. He was probably checking the amp draw which checks how much power the whole machine was pulling. This would be the way to check the problem you have as long as he checked it with everything running, motor, heater,..etc. If you find the amp draw to be too high, then you go to individual components.
Posted on Oct 05, 2007
Timon90
  • 126 Answers
SOURCE: Overfill protection tripping
Seems like the machine fills too much water. Try to reduce your water pressure a bit, and try it again. But just a bit!
Posted on Jan 23, 2008
  • 249 Answers
SOURCE: BOSCH DISHWASHER Loss of power
check fuse in plug top,if its not that it could be door switch 30 years repairing. Close Ire....
Posted on Feb 23, 2008
  • 3 Answers
SOURCE: Bosch Dishwasher SHV4313GB/17 Wont switch off !
Introduction: This may work for your problem, but only if you're finding that you cannot get further water to flow into your machine. If your machine fills OK, then this ISN'T a solution to your problem. If your machine doesn't fill but your drain motor continues to hum for no apparent purpose, this may work.
I have a Bosch SHV. My sink drain backed up, and the water accumulating in the sink then migrated to the dishwasher, through the drain pipe, causing the dishwasher to fill up and, it turned out, overflow a little. When I turned on the dishwasher, the water drained, but no new, clean water came through the hot water pipe. The drain just kept running, but nothing else happened.
Here's what happened. Under the main chamber of the dishwasher, by three inches or more, is a white plastic tray. It sits almost at the floor, and it may not be obvious that it's a tray capable of holding water. The overflow water spilled into that tray, which in turn caused a float in the far left side of the tray to lift (the way a toilet float lifts when the water fills in a toilet tank) and shut off the water intake valve (like the toilet float shuts off the toilet water flow). So long as that valve is closed, your machine will not run.
STOP: disconnect power supply at this point for safety.
To see the white plastic tray and thereby fix the problem, you'll need to take off the BLACK TOE-KICK (attached on my unit by two star-head screws at its bottom) and, possibly , the OUTER PANEL OF THE DISHWASHER DOOR (in my case, a custom wood panel (attached by a few screws through the inner side of the door, two screws that are accessed by popping off little--smaller than a dime size--covers on the sides of the doors, and then the door panel lifts up and out). (I took the outer panel off, but I can't remember if I would have had to reach into the white tray without doing so.)
Once you do that, you can see the white plastic tray. It doesn't come out--at least not without removing the entire machine--so try this. You can take your fingers and feel over and into the tray. You'll probably feel the water--I did. Look at the far left of the tray with a flashlight. Back there you'll see a flat, round, 3-inch diameter piece of white plastic sitting at the bottom of the tray. To its center is a generally U-shaped lever looking device, which, at its far left end, is connected to a red stick pointing up into the machine. When water goes into the tray, the float rises, causing the U-shaped lever to rise, causing the red stick to raise, which (though I couldn't see it) causes an electrical signal to run to, and shut, the valve for your water intake.
I took paper towels, and then a narrowly cut sponge, to sop up the water in the tray. I then took my shop vac and, using it as a blower, blew what little water was left right out. You might be able to use a hair dryer, but first sop out what you can or it'll take forever. Once you've done that, put everything back together and plug your dishwasher back in. My buttons are at the top panel. To reset, hold down the two buttons marked for clear drain for three seconds and release. You should be able to start up then. It took 15 seconds before the water started to run, but it did and the machine works fine again.
Interesting note: The valve that stopped the water from flowing in automatically opened once I got the water out of the tray. You don't need to reset the valve.
Good luck.
Montpelier Man
Posted on May 09, 2009
I woke up this morning and found that my phone had frozen up sometime during the night. I cannot get it to even open, turn off, etc. It's not responding to anything I've tried.
google the model & find the soft reset usually holding down 2 buttons together for 10-20 secs till it beeps then it resets.
Jul 01, 2015 | Cell Phones
First four lights on cycle indicator flash and machine beeps 10 times and then beeps every 30 seconds
I recomend checking drain hose for kinks or obstructions and checking drain pump. most dishwashers will drain first for about 25/30 seconds.Also check the drain hose into the main plumbing connection it maybe blocked.If it cant drain it wont do anything hope this helps.
Feb 17, 2012 | KitchenAid Dishwashers
Kenmore He2Plus Washer: Controls Locked button lites up & beeps
plug it back in and there should be a buttong somwhere toward the corner and in small lettering"un-lock/lock" hold that button for 5 secs and see if it un-locks the board. if it dont the your board might be bad....hopefully this helps
Jul 30, 2009 | Washing Machines
Blank screen; Unresponsive computer, & three beeps in succession
2 short beeps and 1 long beep (repeats 5 times) = Unable to initialize video or video card required but not installed. Sounds like the card may have gone down
Jun 19, 2009 | Intel Desktop Board D845GLVA...
Beeping Lights
there is way to find out what error codes the dryer may have and that may suggest a what part may be the problem
Nov 15, 2008 | Frigidaire FEQ1442ES Electric Dryer
Four blinking red lights.
Either on of the backlight inverter boards is bad or a backlight has failed inside the panel.
Oct 11, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Panasonic tvs-100 voice mail beeping and flashes red power light four times
I'm having an issue with the same unit. But the blinking light is NOT on my phone it's the power light to the actual unit in my server room. It will flash 4 times and then stop. Flash 4 times again... I have looked through the manual to see what 4x power light means and I have found nothing!
Jun 21, 2008 | Lands Phones
Dishwashers Logo
103 people viewed this question
Top Hoover Dishwashers Experts
Gil Shultz
Are you a Hoover Dishwasher Expert? Answer questions, earn points and help others
