Question about JVC Televison & Video
Jvc dvd player model dr-mvisu. I cannot get rid of the flashing loading sign on window. I don't have a reset button on the machine.
  • grampydws Jul 12, 2008
    jvc dvd/vcr model-dr-mvisu
    I cannot get rid of the flashing loading sign on the window. I have unplugged the machine for various periods of time and the machine doesn't have a reset button. The machine is stuck in the loading mode and will not function. Thank you for your advise.
  • grampydws Jul 14, 2008
    The loading sign appears when I plug in the machine. The machine will not function no mater what buttons I push. The machine is empty. Unplugging the machine and plugging it in again does not remove the flashing loading sign.
I HAVE HAD EXACTLY THIS PROBLEM.
LOADING MESSAGE CONSTANTLY, AND NO RESPONSE FROM ANY BUTTONS.
WHEN THE TOP COVER IS REMOVED ON THE DR-M10 THE MAIN BOARD HAS 4 LARGE VALUE ELECTROLYTIC CAPACITORS ACROSS THE WIDTH OF THE BOARD.
THEY ARE ALL MORE OR LESS SIDE TO SIDE WITH EACH OTHER .
THEIR LIFE IS SHORTENED DUE TO THE COOLING FAN NOT RUNNING IN STANDBY.
BY REPLACING ALL 4 ( THEY ARE ONY £0.60 EACH THE PROBLEM IS RESOLVED).
ALSO.
THE PROBLEM CAN APPEAR BRIEFLY IF YOU HAVE A RIPPLE ON THE MAINS, BUT THIS IS CURED BY UNPLUGGING THE MAINS LEAD AND RE CONNECTING.
DEREK.
Posted on Dec 15, 2008
    Brigadier General:
  • 6,966 Answers
To my knowledge, this is a combination VCR DVD. It would seem that your unit has failed to finish loading its firmware. That being the case, then it would require a reset. Since you have unplugged that unit "...for various periods of time..." then it is possible that it would require a flash of the firmware.
Alternately, you may want to check the +5VDC rail supplying the logic board with particular attention to C5207, 1500uF/6.3V and C5203, 1000uF/10V. Of course this would require that you be familiar with electronic circuitry and components, use of a DVM and a soldering iron. It would be to your advantage access to a Service Manual or at the very least a schematic diagram with voltage readings. Should you not be comfortable with a DIY (do-it-yourself), then perhaps your best bet would be to seek the services of a qualified professional or a Service Center.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 12, 2008
    Guru:
  • 859 Answers
You've tried putting a DVD in and taking a DVD out? Because, normally when you get the flashing loading issue it means the system cannot read the disk.
So, my question to you is this: has it ever worked? Do you have a disk in the drive now? Have you tried ejecting the tray and does it eject or not? If the tray will eject, have you put a DVD disk in the tray and still get the same problem?
Thanks. The reason I ask is if there is a fix from the manufacturer it has to be burned to a DVD and then loaded to run, do you think this machine can even do this?
Regards,
Worldvet
Please don't rate this, I'm just asking questions.
  • 4,889 Answers
Looks like you have got a dirty/bad lens. You should first try a lens cleanr and see if it does the job. You can get one for as low as 8$. Just insert that in the player to clean the lens.
If it doesn't work you should take the player apart and check if the the lens assembly is slightly out of place. Just move it and align it back in place then check if it works. If it still doesn't work then you will hav to get a new lens.
Good Luck!
Sai.
  • 1,879 Answers
Greetings,
It shows "Loading" when you turn it on with or without a disc ?
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
  • JVC Master
  • 13,433 Answers
Have you tryed unpluging the device for up to one hour to reset it? also is this a loading screen when you have entered a dvd or just a startup loading screen?
How do you Reset JVC DR-MV100 DVD Recorder/VCR Combo?
First press and hold the (Stop) button first and then press& hold the (Standby/On) Button until you see *RESET* flashing on & off on the display, hold both buttons in until the unit shuts down.
Nov 12, 2012 | JVC DR-MV1S DVD Recorder/VCR
I have a JVC VCR/DVD-recorder, model DR-MV7S. It developed a problem... when you placed a DVD on the tray & pressed the "eject/open" button to take the DVD into the recorder, the tray...
This can be due to a faulty LOADING drive settings, It can be due to a misalignment of the loading section and so the load does not reset to the PARK CONDITION of the MODE.
It can be a aulty gear, belt or jamming in the drive.
You need to open the player, remove the mechanism and manually check the forward and loading motion which can confirm. If the belt or the drive is jammed this can be checked and replaced or reset.
Check the mode switch settings of the forward loading.
Sep 19, 2011 | JVC DR-MV7S DVD Recorder/VCR
I have an JVC dvd/video player and when I turn on the power it doesn't do anything . so I was wondering were can I take it to have it check out? the mn>DR-mvisu,sn> 129A5605
More than likely its just a blown fuse, I had this happen with a SONY combo unit i had , I used a Philips head screwdriver opened it up and took the fuse to FRY's Electronics or a radioshack if its more convenient put the new one in works like a charm.
Dec 03, 2010 | JVC DR-MV1SU DVD Recorder/VCR
Loading keeps blinking Nothing works anymore. even power of no longer works
Check for dried up electrolytic capacitors on the DC-DC converter C5318, C5340, etc.
Nov 13, 2009 | JVC DR-MH30S DVD Recorder
Cannot eject DVD or turn off machine or anything
hold your power button down for 8 seconds and the machine will power down
Feb 19, 2009 | JVC DR-MV5S DVD Recorder/VCR
DR-MH20S HDD/DVD - had a power outage for about 4 hours. There was a DVD in the player. Now power has returned but system just keeps flashing with 'loading' in window. On/Off not functional nor any other...
so sir your problem is how to get out the dvd stucked on it? in this case try pressing the open/close button several times until its open.
CHARCOIS
Oct 11, 2008 | JVC Televison & Video
JVC DR-M10 DVD Recorder not working
Contact JVC @ 800-252-5722, the "loading" is a known bug and they will fix this defect at n/c even if it's out of warranty period.
Mar 12, 2008 | Televison & Video
JVC DR-MV1SU DVD user manual
http://books.jvcservice.com/booklist.asp?Model=DR-MV1SU
JVC allows download of their manuals in PDF.
Jan 15, 2008 | JVC DR-MV1SU DVD Recorder/VCR
JVC DR-MH50S
Just had the 2nd diagnosis for the error - "digital PCB" at a cost of £252 - BONKERS! Have e-mailed JVC to see if they can make the cost of the repair reasonable, got a positive reply they want me to send my proof of purchase, serial no etc. & they'll consider dropping the cost significantly. On top of that just found same model on ebay, ex display £130. baught it, was prepaired to pay upto same for the repair - gunna swap HDD for mine when it arrives, the stuff on there was the main reason i wanted it repaired. Still gunna try to get mine fixed for nowt though through JVC! May as well try for nothing!
Nov 10, 2007 | JVC DR-MH30S DVD Recorder
Televison & Video Logo
160 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
