Amp smokes - Audio Players & Recorders
  • 1,512 Answers
Hi dkharial
this is not good. there will be an internal problem that is causing the unit to smoke. I suggest you stop using it immediately, and get someone to have a look at the internals for you. What make and model is it?
regards
robotek
Posted on Jul 07, 2008
How do you do a smoke test to check for an emission gross leak
Evap Smoke Machine,scan tool,system diagrams
& other testing tools,only a repair shop has
Google Evap System Smoke Machines & testing
Jul 30, 2014 | 1999 Ford Taurus
I bought purge control but my cat still smokes only after it is wormed up will the egr silinoyed make the car smoke
Check for obd codes & diagnose them
Do not install parts until you component
test your codes & find a failed part
Jul 30, 2014 | Cars & Trucks
My 95 Integra smoke at the start white smoke what is that five minutes later it goes away
White Smoke --usually a sign of a failed head gasket
or other issue, allowing coolant into the cylinder & a major
repair
White Smoke only on start up after sitting (Not Lasting 5 Min)
is raw fuel (gasoline) from leaking injectors, leaking fuel into
the cylinders
Injectors can fail,wear,leak or be dirty & NO you can not clean them
Forget the Genie in a Bottle The injectors have to come out & be
mailed away for Ultra-Sonic Cleaning
That condition - the raw fuel- will over heat your exhaust converter
& ruin it as well as many other problems-lack of fuel control the
main one.
Jul 19, 2014 | 1995 Acura Integra Coupe
1998 gmc sierra 1500 5.0L
white smoke is a blown head gasket [white smoke burning anitfreeze]
Jun 24, 2013 | Cars & Trucks
Stop leak fix value stem & values
Does the smoke smell like coolant, it will be a somewhat sweet smell.
Jun 10, 2013 | 1994 Jeep Grand Cherokee
I need a evap hose diagram for a 1999 hyundai accent
No--- it is not time to change anything
It is time to diagnose the cause of the evap code
Without the smoke,I ask--what if the hose are okey?
Then what?
What about the 5 or 6 solenoids & sensors?
You need a smoke machine & scanner to command thing
on & off
A diagram can be had at any shop with ALLDATA
They can print that for you,
I assume you got a small leak code,not a specific
item in evap
How about a shop smokes it & you go home &
make the repair?
Dec 10, 2012 | Cars & Trucks
Im having the problem with my mtx tc6001 amp smoking my speakers I hook up everything and when I turn on radilo speakers jump pop and smoke.
MAKE SURE THE SPEAKERS ARE CONNECTED TO THE AUDIO OUTPUT OF THE AMP AND NOT TO SOME WIRES SENDING DC POWER ........ IF THE AMPLIFIER HAS AN INTERNAL PROBLEM AND IS SENDING DC CURRENT TO THE SPEAKERS THIS WILL MAKE THEM SMOKE ALSO ...... HAVE THE AMP TESTED ON A BENCH IN A SHOP ...
MY GUESS IS IF THE SPEAKERS SMOKED THEY ARE DESTROYED AND CANNOT BE FIXED....... COIL ON THE BACK OF SPEAKERS NOW OPEN ---- SORRY TO TELL YOU THIS...
Jun 29, 2011 | Car Audio & Video
How smoke affects air conditioners?
The smoke is drawn into the unit by the evaporator fan motor, & as the smoke travel through the filter & evaporator coil it leaves a sticky light brown residue, which causes filter & coil to get dirty quickly along with leaving a unpleasant smell.
Mar 02, 2010 | Heating & Cooling
Smoking amp
The only way you'll know is by hooking it up and testing it. Amps should not smoke, so there's a pretty good chance you fried it.
Jun 16, 2009 | Legacy LA838 Car Audio Amplifier
MTX 1501 D
If the terminals were smoking, it's probably due to loose screws in the terminal block or wire that's too small.
Did the amp work properly after the terminal blocks smoked?
Apr 29, 2008 | MTX Thunder 1501D Car Audio Amplifier
22 people viewed this question
 Grubhead
Grubhead
