You will check the SMPS. Unpluge two dc socket from *********** board.
Ensure the smps perfet or not Follw the link it will present with picture
Just click on http://www.jestineyong.com/?p=267
http://www.ucertify.com/article/switch-mode-power-supply-smps.html
If you connected to sort the smps,helping with the pic.soon your Smps Fan will run.
For text all the voltage, use multi meter for more knowledge, click here http://www.smpspowersupply.com/connectors-pinouts.html
After testing the SMPS
If your smps bad no harm to open the cover to repair ,just check the fuse inter the SMPS or can go nearest technician.NOTE IT IS VERY DANGEROUS, BECAUSE, YOU CAN GET HEAVY SHOCK. Better to hand over, to any Technicians .
IF YOUR SMPS RUNS WELL
Folwhen i press on power button to open my pc no - shibuda_22.jpg instruction.
Unpluge the AC power cable
Remove the CMOS Battery.
Hold on or press the on off switch for 40 seconds
Install the CMOS Battery.
Go to BIOS setup, for set up bios.
Follow the link
http://www.pcbuyerbeware.co.uk/BIOS.htm
If you can do just set load fail save default.
Or you can make with detail set the BIOS.
http://www.ybet.be/en-hardware-1-23/bios-setup.htm
I will tell you very simple way to set bios just do load fail save default
and set boot priority
!st boot =CD/DVD
2nd boot =HDD.
And press F10 >yes or hit.
I hope *********** board will run soon ,because 80% mother board can solve with this system.
Hope it will help you.
