Question about Sony PlayStation Portable (PSP) Console
Will not turn on even when connected to power outlet
  • kathieallsup Jul 07, 2008
    I believe I was locked out for some reason??? I have only watched one movie on it and have played a Tiger Woods golf game and I might have hit a security lock button some how?? I've removed the battery, plugged in to AC power and the power light is on but it won't do anything else???
    Thanks, Kathie
    Problem Solver:
  • 7 Answers
First make sure your battery is not in critical damage.then, check your power outlet and psp system to make sure thats not damaged.If you need to get a new battery
Posted on Jul 07, 2008
Loss of power when printing
  1. Is the printer off?
    Press the I on the power switch to turn the printer on.
  2. Is the power cord loose or disconnected?Turn the printer off and connect the power cord properly. Turn the printer on again.
  3. Is the printer connected to a correctly rated outlet/socket?Connect the printer to an AC power outlet/socket that you know works. Do not connect any other equipment to the outlet/socket. Do not connect the printer to an auxiliary power outlet on the back of a computer.
  4. Is the printer defective?Turn the printer off immediately, disconnect the power cord from the outlet/socket, and contact your dealer or Brother Customer Service.
    Still having Problem Then follow Us For
Brother Printer Support
Mar 23, 2014 | Brother MFC Office Equipment & Supplies
Power outlet
Sometimes accumulation of kitchen dirt can reduce contact on the outlet . If you can use a contact cleaning spray or even a WD40 into the contact it might help. If not you will need to open the outlet to confirm the case of power within the unit. Failure of power means the circuit must be traced back but presence of power confirms the switch fault.
You can use a holder and bulb to confirm the power along with a line tester to confirm if the phase is present. A multimeter is not an expensive investment but must be careful to use in the correct range.
Jan 06, 2012 | Kitchen Appliances - Others
Midiland 8200 (ADS 4000 controller) 5.1 hum problem
You may have an earth loop problem. This is caused by connect various equipment to different mains power outlets.
Connect all the PCs, audio and speakers to a single mains power outlet, use a power board so they are connected to the one mains power outlet.
I suggest you use a power board that has a built-in surge protection.
Nov 14, 2011 | MidiLand S4 8200 Computer Speakers
My SP console keeps turning itself of when I turn it on even when its been charged
If the system remains powered on when connected directly to an electrical outlet, then you are likely looking at a bad battery. If the problem persists even when the SP is plugged into an electrical outlet for charging, then you likely have some circuitry damage and may need to replace the entire SP.
Aug 24, 2011 | Nintendo Game Boy Advance SP Console
Mr printer won't turn on. It is plugged in and hooked in to my computer. It has been working before today.
Check power cable
Try connecting it to directwal outlet not power strip
check the power cables if it has power adapter with green ligh on it if it has then check the power cord connected directly on wall outlet try to use it in some devices compatible to it
lastly take advantage to you canon support if you printer is covered with warranty they can find better solutions even replacement too!
Hope I gave you even a bit of idea.
Thanks
Mar 28, 2011 | Canon Pixma MP480 All-In-One InkJet...
Cannot turn on the printer even if connections are ok ?
The only thing that could stop you from turning the printer on other than a broke printer is the power/power cord is not connected. The printer should turn on without a USB or parallel printer cable attached.
If no lights are showing when you try to power the printer, check the power connection in the back of the printer to ensure it is plugged in, check the plug into the adapter is connected and that the power cord's plug is connected to the wall outlet - if you have a power strip make sure it is turned on and the circuit breaker is not popped. Make sure that there is power to the outlet by plugging in something else to show it has power. If all of those check out ok and you have a meter, check for voltage at the power connector at the printer (pull the plug out of the printer and check voltage from inside the plug to outside the plug. It should be 18 vac.
If all of this is ok, there is something wrong inside the printer. Probably time for a new one as cost to repair is probably too high.
Oct 11, 2010 | HP DeskJet 810c InkJet Printer
My dryer will run for a while but then it stops. I can still hear the timer ticking and if I push the button again the dryer will run again.
My Best Guess would be a bad power connection, or just a bad connection, A bad timer or Bad Motor
I would ckeck the power cord connections first and even the outlet. Making sure all the wiring is sucure.
Of course make sure you turn off the breaker to the outlet befor serviceing and unplug the machine befor serviceing
Sep 05, 2010 | Amana DLE330RAW Electric Dryer
Wii will not turn on even though it has power and everything is connected. Help?
This is a common problem with the Wii. Even if it's hooked up to a surge protector. If there was a power surge, or the power went out, etc...anything, this will happen. The problem is with the AC adapter, not the Wii itself.
There is a circuit inside the AC adapter that needs to be reset. Unplug the AC adapter from the wall/surge protector outlet. Don't unlpug it from the Wii, it has to be at the outlet. You have to kill power to the adapter.
Unlpug it from the wall/surge protector outlet, and leave it unplugged for 5 or 10 minutes. This will kill power to the AC adapter, and give the circuit time to reset. When you plug the adapter back into the outlet after 5 or 10 minutes, the red led on the front should be lit up.
Dec 09, 2009 | Nintendo Wii Console
My laptop wont even turn on! how do i make it work?
OK! I'LL PLAY ALONG?
MAKE SURE POWER CABLE CONNECTED TO REAR OF LAPTOP/PLUG END IN SOCKET/TURN ON SOCKET/MAKE SURE POWER AT SOCKET?
OPEN LAPTOP/SHOULD SEE LED(S) SHOWING?
LOCATE SWITC/BUTTON/PRESS/SHOULD HEAR HDD STARTUP AND SCREEN ACTIVATE?
BATTERY MAKE NEED RENEWING IF NOT HOLDING CHARGE?
Nov 15, 2009 | Compaq Presario Notebook
HP c4280 says carriage jam
SolutionStep one: Perform a power reset and connect the printer directly into the electrical outlet Remove all the paper loaded in the main input tray.Make sure that the product is turned off.
Disconnect the USB cable from the back of the product.
Disconnect the power cord from the product.
Disconnect the power cord from the electrical outlet and wait 10 seconds.
Reconnect the power cord directly into the electrical outlet and check for the following.
Make sure that the power cord used is the one provided with the product.
If a computer is connected to the product, make sure that the computer is connected to a grounded (three-prong) wall outlet.
Make sure that the power cord is firmly connected to both the product and the power supply.
Reconnect the power cord to the back of the product.
Press the power button ( ) to turn on the product.
Reconnect the USB cable to the back of the product.
If the issue is resolved, proceed to Step six: Print a self-test page.
If the issue continues, proceed to the next step.
for more information please go to below link>>
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458822&cc=us&lc=en&dlc=en
Thanks for using FixYa.
Jan 25, 2009 | HP Photosmart C4280 Aio Printer
Sony PlayStation Portable (PSP) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
