Question about Dishwashers
I have a Haier HDW201ss dishwasher and i seems to be stuck i draining. all three lights stay on and is beeping, the start button is not allowing me to pause it
  • 93 Answers
SOURCE: Slight water leak towards end of cycle
Did u notice the Quantity of detergent used? If the leaking water is soaping, it is an indication of excess detergent used that cause the leaks. Reduce the detergent n observed the DW running, or run the DW without detergent several times to remove all residual residing inside the washer.If not check the door gasket or change the door gasket.
Posted on Nov 19, 2008
SOURCE: pump not draining - Haier portable dishwasher
purchase new pump at www.partsquick.com/haier
about 33 shiped must be able to replace if they sell the pump i have the same problem looking for a diagram to replace pump
Posted on Jan 05, 2009
SOURCE: Haier HDP18PA
Not sure of the background on your fault, but this may help:
I have an HDW202. I accidentally opened the door while it was running - a no-no, but there is no lock preventing opening the door while it is running - not idiot-proof at all, disappointing, really. Anyway, closed the door, the washer kept running, then water started to leak out the front door. I quickly turned it off, mopped up the water, and turned it back on. It pumped out the remaining water visible in the bottom, then started flashing lights and doing 10 beeps in a row, pausing for a minute, 10 beeps in a row again, etc. - it was stuck in this cycle. I tilted the unit forward, backwards, and side to side, while turning it on and off periodically to check for results. More water came out of the unit, and it started to behave normally while tilted, but not level. Eventually, after more tilting, it returned to normal behaviour when level. It seems it did not pump all of the water out initially, and this was causing it to malfunction until all of the residual water inside had drained onto the floor from tilting the unit.
Posted on Mar 10, 2009
SOURCE: Kenmore dishwasher Lock On light flashing
holding the button for four seconds will not do it, you have to hold it until the light stops blinking and
will go back to normal, normall takes more than four seconds to unlock the unit, this is something
the sears repair techs know becouse the are trained on all this things but, they will not share this things, becouse thats how they make money
Posted on Apr 18, 2009
SOURCE: haier dishwasher
I useto have same problem. For some reason there was water under machine, then i tilted machine, clean water and problem solved. This is built-in dishwasher that is why water acumulates under machine and "leak cut off switch" turn off machine. You can't reset machine while you have water under, machine telling you there is a problem, but Haier wan't put solution on their site - Haier suport is very bad. Sorry for English and hope this help.
Posted on Jul 26, 2009
Haier dishwasher HDW9WHT beeps 5 times and won't wash what is wrong with it can I fix it or should I get someone in
7 results (0.54 seconds) Search Results
    Haier HDW100WH / HDW100SS - ProductReview.com.au
    www.productreview.com.au > ... > Dishwashers > Freestanding > Haier
    Rating: 1.7 - ‎30 votes
    Haier HDW100WH / HDW100SS: 30 customer reviews on Australia's largest ... 1.7 out of 5 stars for Haier HDW100WH / HDW100SS in Freestanding Dishwashers. ... I putthis review in to do my part for what I think is a great consumer service you ... it it keeps beeping 10 times telling me doors open??and won't begin cycle.
    Haier Dishwasher Error Fault Codes - Lights Flashing ...
    removeandreplace.com/.../haier-dishwasher-error-fault-codes-lights-flash...
    Dec 21, 2015 - Haier dishwasher error codes - flashing lights - beeping ...Dishwasher keep filling water and draining at the same time ... Fix Washing Machine That Won't Drain - Washer Not Draining Water .... 2015; Samsung Galaxy Note 5 Quick Users Guide September 25, 2015; My Freezer Is Cold But The Refrigerator ...
    Dishwasher Has Beeping Sounds Blinking Lights - How To ...
    removeandreplace.com/.../dishwasher-has-beeping-sounds-blinking-light...
    Dec 21, 2015 - At times your dishwasher may need to be reset. ... Haier DishwasherError Fault Codes - Lights Flashing Beeping Sounds My Haier ... Fix WashingMachine That Won't Drain - Washer Not Draining Water .... 2015; Samsung Galaxy Note5 Quick Users Guide September 25, 2015; My Freezer Is Cold But The ...
    How to Troubleshoot & Repair a Dishwasher ' HomeTips
    www.hometips.com/repair-fix/dishwasher.html
Jan 19, 2016 | Haier Dishwashers
Need a manual for a HDW201SS
follow up link:
http://www.2shared.com/document/XipZl0Kc/haier.html
Please endorse me if helped :)
Jan 11, 2012 | Haier Dishwashers
Drans and then bleeps
My dishwasher has four programe lights flashing and beeps ten times it seems to be constantly draining
Jul 21, 2011 | Haier DW12PFE2U Dishwasher
Haier HDP18PA
Jan 25, 2009 | Haier HDP18PA Stainless Steel...
Dishwasher will not empty
check to make sure nothing is binding the impeller, ie: broken glass, coins, twist ties, plastic bag.
Jan 18, 2009 | Haier 17 in. HDT18PA Built-In Dishwasher
All 4 lights on my haier dishwasher Model CG206B blink and beep.
I had the same thing the drain hose was plugged.To reset You have to tilt the washer back 45 degrees.Mine is now running hope this helps.JIM
Jan 04, 2009 | Haier ESD200 Built-in Dishwasher
Nov 18, 2008 | Haier Dishwashers
Haier dishwasher
Aug 08, 2008 | Haier ESD200 Built-in Dishwasher
The washer keeps beeping and trying to drain as soon as it is turned on
I have a Haier HDP18PA with the same problem... I tried tilting mine backwards while running...this made a mess BUT the beeping stopped BUT the lights were still flashing. Turned it off and started it again and the lights still were flashing BUT no beeping. Decided to try tilting it forward while running ... made another mess BUT the lights stopped flashing. Turned it off again and restarted it and it is now running fine. Good luck!
May 05, 2008 | Haier HDP18PA Stainless Steel...
Dishwashers Logo
142 people viewed this question
Top Dishwashers Experts
