Connecting a new computer to an older printer
I bought an Extensa 4620-4605 earlier this year. I just now went to connect it to my older printer--an HP laserjet 2100 series (C4170A)--but I don't know how. My printer has 3 connections--a parallel port (my computer doesn't), a local talk port (my computer ???), and IR (so does my computer but printing is hit and miss--mostly miss). How do I connect the two?
  • 3 Answers
Does this Laptop have a docking station? If so then on the back of the docking station should be a parallel port.
Is you laptop connected to a router/firewall/switch? Then you can get a device that will make the printer become networkable and connect to you firewall switch...this unit is called HP jetdirect. It will make your parralel printer become more useful and connected to the network.
Problem is the printer is "old school" and the laptop is "new school", the JetDirect will bridge this...
Posted on Jul 07, 2008
Hello, My olympus sp-500uz has more and more problems with connecting to my PC. Some USB ports don't work any more(front connection) and the back connection works sometimes but getting my pictures on the...
Many people find it more convenient to just take the memory card out of the camera and put it in a card reader, especially now that these readers are built into computers and printers. That would be a "work around" for your problem.
As to the problem itself, a bad cable might be the cause, with damaged connectors. That is something you can replace cheaply (search Amazon on "Olympus SP-500 USB") so it won't be expensive to check it out.
Slow transfer might be due to using an older standard USB port. The first USBs were much slower than USB2 widely used now. Some older computers only have the earlier standard, and some have a mix of old and new.
Nov 19, 2010 | Olympus SP-500 UZ Digital Camera
I have an Acer extensa 5420-5687 and I dropped it and the screen broke. How can I hook it up to a tv so I can go online and still use my computer?
You should have compatible connection pins for connecting with tv.
Also, your tv should also support the above connection.
Try to get a new LCD by repairing or claiming warrenty.
For more support, go to
http://www.acer.com/worldwide/support/index.htm
http://www.acersupport.com/
Sep 05, 2010 | Acer Extensa 5420-5687 Notebook
I bought an Acer Extensa Laptop from Best Buy in America in February this year so it is only 9 months old.It won't start up.Battery charger has light on but there is no life in the Lap top
This computer when bought brand new has an warranty of one year. Dig up your reciept and call BestBuy. They will help you *s*
Thank you and good luck.
Oct 26, 2008 | Computers & Internet
I bought a new computer and my Lexmark printer is not connecting . Should it install automatically when I connect
No , While buying printer they will give driver CD . After connecting the computer u need to install in that system
Sep 24, 2008 | Lexmark Office Equipment & Supplies
Xerox DocuPrint P8ex
In order for me to deal with this query for you i need get some informations:
- what operation system does you computer have?
- Are you gonna connect via parallel, USB, or External Ethernet Adapter
Fran10
Apr 10, 2008 | Xerox DocuPrint P1202 Laser Printer
Printing cartridge
Check the date on your ink cartridge.  I bet it has expired. If you put in a "new"cartridge but it is even an HP one with an older date, it may not work.
I had my printer stop in the middle of a print job.  It was printing fine and suddenly would not print.  So I refilled the cartridge with an ink kit I had on hand and reinserted it--no go!  Then I opened a remanufactured cartridge I had bought some time ago and inserted it.  No go, despite the fact I could see ink coming from the jets.  I finally gave up and bought a new HP ink cartridge, and it worked just fine.  But it bugged me why the new one would work and the other two that seemed just fine would not.
Later I learned that HP has a chip that reads the expiration date on the cartridges and that is what keeps those old ones from printing.  I found one trick of setting my date on my computer back to a year earlier than the exp date on the cartridge.  I saw the date on the remanufactured one I had tried earlier was 2005, so I set my computer date to today date but year 2004.  After forcing me to do print alignments several times and take the remanufactured cartridge out and put it back, I got it to print just fine.  And that 2005 cartridge that would not work earlier is what I am printing with right now.
Be advised, though, if you try the date setback, that HP printer will buck and try every way to not let you use that old cartridge.  You must say no to reflashing if HP tries to pull that on you.  And you will take out and put back that same cartridge multiple times and keep printing alignment sheets 3 or 4 times before you are successful.  But, if you persist, you can get it to work.
Oct 28, 2007 | HP PSC 1350 All-In-One Thermal Printer
Change all ink message
Your Lexmark cartridges may be like my HP ones--they have a chip that the machine reads so they cannot be reused without doing some tricks to fool the printer.
My HP remembers the last 2 or 3 cartridges and also will not use ones that have passed the expiration date that is stamped on the cartridge. I'll tell you what worked for my HP.
Oct 25, 2007 | Lexmark X63 InkJet Printer
Ink cartridge error
Later I learned that HP has a chip that reads the expiration date on the cartridges and that is what keeps those old ones from printing.  I found one trick of setting my date on my computer back to a year earlier than the exp date on the cartridge.  I saw the date on the remanufactured one I had tried earlier was 2005, so I set my computer date to today's date but year 2004.  After forcing me to do print alignments several times and take the remanufactured cartridge out and put it back, I got it to print just fine.  And that 2005 cartridge that would not work earlier is what I am printing with right now.
Oct 16, 2007 | HP PSC 1210 All-In-One InkJet Printer
HP 1350 not working
Aug 16, 2007 | HP PSC 1350 All-In-One Thermal Printer
HP 1350V all-in-one
Hi, You need to get a new ink cartridge. It is really not recommended to refill ink cartridges but if you do then it is advisable not to exceed 3 times because it could damage the printer head. If the new inks still gives error, then your printer head may need to be checked to see if it needs replacing. Good luck!
May 25, 2007 | HP PSC 1350v All-In-One InkJet Printer
Computers & Internet Logo
182 people viewed this question
David Payne
David Payne
