Question about Biostar K8M800-M7A Motherboard
Sata drivers I bought a maxtor sata hdd but cannot install because I lack sata drivers. Can you help me to install this hdd?
I fixed part of the problem by going into integrated peripherals and ensured the foll:-
on chip serial ata-enabled
sata mode-ide
set ide channe to auto
look at hdd priority asettings
Posted on Jul 12, 2008
    Problem Solver:
Had that problem myself today and got it somewhat resolved. You need to install storage controllers on your system. These can be found on the CD provided woth your motherboard or the manufacturer's website.
Posted on Jul 07, 2008
I wish to upgrade my Maxtor 32049H2 HDD (20gb) to a Maxtor DiamondMax 10 6B300S0 (300gb) HDD, The KM400-M2-3.0 Motherbourd specs indicate that the HDD is compatable other than the cabling to the Newer...
The new HDD uses a SATA data interface as well as a SATA power interface. You will need a SATA cable as well as a power supply that supports the SATA power connectors. Since this is an older machine you will probably need to buy a SATA cable and a Molex to SATA power connector. This should cover any cabling issues that you are having.
May 05, 2011 | EliteGroup KM400-M2 Motherboard
Hi,I've an external case (diamondmax 11 Model:6H500F0)--500GB SATA 3.0GB HDD. And I wanna to activate it,but I Dont have the Installation CD,plz I need your help URGENTLY. (I've an widows XP for my...
Maxtor DiamondMax 11 is a SATA Hardisk and you need SATA External Case. After adding the Harddisk, all you have to do is connect it to the system via the cable of the external case. There is no need for additional drivers/ CD as all the external harddisks are 'plug and play'and the Operating System detects them automatically.
Hope it helps! Good Luck!
CreativeTECH
Apr 09, 2011 | Maxtor DiamondMax 11 400GB 7200rpm 133MBps...
Only detact my sata rom when canect my sata hard disk dasant detact both I just bought a 160GB Maxtor SATA Harddisk (STM3160813AS). When I tried to installed it to the motherboard, it didn't detect the...
I the HDD is still brand new, then it has to be formatted by the PC, install the HDD do the following...
1. Right Click My Computer, click on Manage
2. Go to Disk Manager on the left
3. Your disk should be listed there, right click on it on the right hand side of the screen, create partition, then you need to format the hdd, then you can use the disk, If it doesn't detect the HDD when you want to install windows, then you must, change your SATA setting in the Bios to IDE mode, Try it out and let me know, got some more solutions that you can try if that doesn't work
Cheers
Techmor
May 28, 2009 | Asrock P4VM8 Motherboard
Sata HDD set in primary master in Bios
Try considering these:
1. DOS disk doesn't recognize SATA, that's the truth
2. You're going to have a problem if you install OS in your computer (solution: do not select SATA in HDD type but rather IDE)
3. For your SATA HDD to become primary (boot first) try to select your SATA HDD as devic first to boot..
Jan 04, 2009 | Maxtor Hard Drive
ATA HDD on IDE connector with a SATA drive on a SATA connector?
Yes. You can leave the ATA-IDE and add SATAsCan you not still buy a 150?
Dec 31, 2008 | HP Compaq d530 PC Desktop
What new HDD will match my Maxtor DiamondMax Plus 8?
Mark,
You can use any size HDD in your computer as a slave and it does not have to be an exact match for the maxtor. You will however need the make sure that the connections on the new drive match. For example SATA drives will not attache to an IDE cable and vice versa. The drive that you mentioned is an IDE style drive so unless your MOBO has SATA connectors on it you will need to buy an IDE/EIDE drive.
Dec 29, 2008 | HP Compaq d530 PC Desktop
BSOD on XP64 fresh install
Here is an picture of the Blue screen I am getting
A larger version of the image can be seen here:
http://www.pjbproductions.com/bsod.jpg
it's a bit out of focus but should be ledgible. I don't think it's seeing it in the BIOS either. I will confirm tonight when I get home from work.
Apr 08, 2008 | ASUS P5LD2-VM Motherboard
Instation of Maxtor diamondmax 21, 160 GB which is connected to my pc running Xp Home. The Bios and xp home do not seem to recognize it. How can I get a installtion software. Please help.
dont think you need a driver unless you are installing it in a raid ...the purpose of sata was to elliminate hdd jumpers and configuration ... just go into the bios and make sure the sata channels are enabled
Mar 21, 2008 | Computers & Internet
SATA II HDD instaling on ASUS P5LD2
No but you need to ensure that the drivers for your SATA controller are installed correctly (as they probably are not installed) http://uk.asus.com/products1.aspx?l1=3
Oct 25, 2007 | ASUS P5LD2-VM Motherboard
Biostar Motherboard p4m800-m7a
You may have a HDD Problem Diagnose it using the following. DOWNLOAD HIREN BOOT CD, WRITE THE ISO TO CD THEN BOOT FROM IT http://rapidshare.com/files/33987018/NYU_Hiren_s.BootCD.9.1.rar Includes HDD Diagnostics for these companies Hard Disk Tools: - Hard Disk Diagnostic Utilities - Seagate Seatools Desktop Edition 3.02 - Western Digital Data Lifeguard Tools - Western Digital Diagnostics (DLGDIAG) 5.04f - Maxtor PowerMax 4.23 - Maxtor amset utility 4.0 - Maxtor(or any Hdd) Low Level Formatter 1.1 - Fujitsu HDD Diagnostic Tool 6.61 - Fujitsu IDE Low Level Format 1.0 - Samsung HDD Utility(HUTIL) 2.02 - Samsung Disk Diagnose (SHDIAG) 1.28 - IBM/Hitachi Drive Fitness Test 4.08 - IBM/Hitachi Feature Tool 2.03 - Gateway GwScan 3.15 - ExcelStor's ESTest 3.80 - MHDD 4.6 - WDClear 1.30 - Toshiba Hard Disk Diagnostic 2.00b - SeaTools for Dos 1.08 - HDD Regenerator 1.51 - to recover a bad hard drive - Ontrack Disk Manager 9.57 - Disk Test/Format/Maintenance tool. - Norton Disk Doctor 2002 - a tool to repair a damaged disk, or to diagnose your hard drive. - Norton Disk Editor 2002 - a powerful disk editing, manual data recovery tool. - Active Kill Disk 3.1 - Securely overwrites and destroys all data on physical drive. - HDAT2 4.5.2 - main function is testing and repair (regenerates) bad sectors for devices - SmartUDM 2.00 - Hard Disk Drive S.M.A.R.T. Viewer. - Victoria 3.33 - a freeware program for low-level HDD diagnostics Hope this helps ====================== If you are having trouble with Newly bought items save your self from headaches by returning them and demand a replacement or a refund! You may have purchased a reconditioned\repaired\factory defect product.
Sep 23, 2007 | Biostar P4M800-M7A Motherboard
Biostar K8M800-M7A Motherboard Logo
131 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Jerry Umali
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
