Question about Philips 50P8341 50" Rear Projection Television
Philips 50P8341 50 in. Rear... Problem:
My picture is not sharp the color muddled and picture controls are unresponsive. Is this tv worth fixing?
  • 69 camaro Jul 14, 2008
    our tv has a red tint tried adjusting called repairman he said it's the tubes cost is $400.00 . another repairman wants $175.00 for labor $30.00 to fill tubes is there a way i can remove the tubes my self and have them filled.
  • sirrob69 Aug 12, 2008
    My Philips 50P8341A has a problem ,the screen isn't clear and adjusting it doesn't help
How do i refill the CRTs and what do i fill them with
Posted on Oct 25, 2012
  • Philips Master
  • 8,617 Answers
You need to change the coolant in the CRTs ( picture Tubes) and the set will get its color and clarity back.
Posted on Jul 07, 2008
2 Suggested Answers
Slinteriors
  • 8617 Answers
SOURCE: Philips 50P8341 50 in. Rear... Problem:
You CRT coolant needs to be replaced, its a very common problem with the phillips and magnavox projection TVs. If you need more info on the Coolant Change let me know.
Posted on Jul 14, 2008
I have aquires a Magnavox rear projection tv. The picture is sharp but is in shades of red and pink. Obviously the green and blue are not working correctly. Any Ideas besides kicking it to the curb?
The tv have a problems known as a convergence pictures problems,the tv convergence board it is dead,that why tv colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?This tv can be repair,by fixing the convergence board,by replacing 2 STK convergence ICS and some or all of it resistors too.Will fix convergence pictures problems.The tvs shops will cost u like $300-350 for parts and labors,to save this tv.
Jul 27, 2011 | Philips Magnavox 51MP392H Rear Projection...
We have a Philips 60pp9401, 60' rear projection tv. The images looked like they are layered. How do we align the colors without the original remote control? Using Intellisense.
U can't alignments this even u have the original remote.Tv have a problems known as convergence problems,it dead.Colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts,must be changes on the tv convergence board to fix convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Dec 18, 2010 | Philips 60PP9401 60" Rear Projection...
Foggy picture
not worth it, likely been dropped and all the lenses etc are out, or just worn out from a hard life.
Oct 12, 2009 | Philips 9P5034C 50" Rear Projection...
Picture is pale, yet reds are bright. checked color, brightness, and conversion settings. TV seems unresponsive to the color, tint, and brightness adjustments.
open the back and look into the projectors red blue and green should be clear picture if its blurry need to change the coolant if its not on need to replace the projectors
Aug 22, 2009 | Philips 50P8341 50" Rear Projection...
Adjusting to the proper color
Tint would be the control that will control the color balance, but this sounds like it may be deeper then that. Turn your color all the way down so that you have a black and whit picture. If the picture is still yellow then you have a problem with the blue picture tube.
Feb 02, 2009 | Philips 43PP9202 43" Rear Projection...
DOUBLE PICTURE WITH DIFFERENT COLOR
this is a convergence problem,
well worth fixing
I would have a TV repairman take a look at it.
Regards,
daniel.
Jan 12, 2009 | Philips Magnavox 51MP392H Rear Projection...
Dull picture, whites have halos, need to watch tv thru dvd player
the picture color problem is the coolant in the CRTs. You can get the coolant replacemnt Kit at the following link. The other problem with the Input through DVD sounds like the signal board. You can get the replacement board and the Phillips CRT coolant kit at the following link.
http://servicemanuals.vstore.ca/
Sep 14, 2008 | Philips 60PP9202 60" Rear Projection...
Jul 14, 2008 | Philips 55P8341 55" Rear Projection...
Color & sharpness problem
Sounds like you need Coolant fluid change, this is the fluid under the Lenses. If you have not done this before I suggest that you get some one who is qualified. Because if the coolant leaks and get to the circuit board, there goes your tv. You need new fluid in the 3 CRT's. If you look down with the back off and looking in the lense, you would see contamination in the fluid, this needs to be taken out and cleaned and replaced with new fluid. The fluid can come from places like MCM electronics corp.
Mar 19, 2008 | Philips Magnavox 9P6034C 60" Rear...
Bottom of projection tube is another color
Yes, worth fixing, sounds like convergence is out on the tip ends. Check papers for Convergence controls. See if have auto fix.
Aug 12, 2007 | Philips 60PP9202 60" Rear Projection...
Philips 50P8341 50" Rear Projection Television Logo
136 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
