Question about Dryers
My ge dsxh43 dryer is chewing up clothes and leaving brown burns on the end.what can i do?
  • hounddogcrj Jul 07, 2008
    dave,i think its the front seal.what website can i find this and purchase?you were very helpful.thank you,raymond jackson
  • Anonymous May 13, 2009
    I would like to replace the glide/drum support as well, how do i remove this plastic piece??
  • 525 Answers
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Below is a link to common solutions that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
It provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Once you access the site you will be able to navigate numerous pages of information on your product. You will need to enter your model number to access your product information.
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
Here are some things to look for:
If your clothes get marked or torn in your dryer, check these:
Rollers
Rear seal
Front glides
Front seal
Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set.
Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it.
Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set.
Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 07, 2008
I have a 2006 Whirlpool Duet Electric Dryer that leaves brown marks on my cloths. I have cleaned the inside of the dryer per the manual's diretions, but it still leaves the marks. They almost look like...
Usually, if you are getting brown streaks or marks on clothing, one or both of the drum seals are going bad. Clothing will drag between the bulkhead and the drum, leaving brown marks. If you want to do the repair yourself, I can provide instructions, otherwise call for service.
Dec 30, 2009 | Whirlpool GEW9250 Electric Dryer
Brown marks on my light coloured clothes
I just noticed My Frigidaire doing the same thing. Using a lightly soapy damp cloth, I cleaned the interior, paying particular attention to the small gap between the drum and the housing. I also took apart the lint pre-filter and screen and cleaned them. There was a filmy build up of the same colored substance. I suspect that dryer sheets are leaving a waxy residue that over time is sufficient enough to rub off on lighter colored, primarily synthetic, fabrics.
Jul 11, 2009 | Kenmore Elite HE4 Electric Dryer
The dryer is leaving what looks like brown burn marks on clothes
you might need to replace the felt on the inside front that the tub rides on
Apr 23, 2009 | Dryers
Kenmore dryer leaving brown burned lines on clothing
the rear drum seal was bad and as things rub against it they will get black marks on them.
Larry
Aug 02, 2008 | Whirlpool GEW9250P Electric Dryer
Ge dsxh43
This link goes directly to the exploded view/tear down page for G.E. dryers at Repairclinic.com. From there you can navigate back to the parts breakdown/order page. Just enter your model no. in the search box and click search Most G.E. dryers have 3 or 4 screws holding the top panel to the front panel. Open the door andd they should be accessible at the top of the door opening. After removing those, then should be 2 screws at the bottom to loosen, then the front lifts off the 2 screws. The diagram should help guide you through the rest.
http://www.repairclinic.com/0100_20.asp
Thank you,
Dave E. (Illeagle)
Jul 07, 2008 | Dryers
Parts of clothes get stuck in edge of dryer...seems to burn them.
I have had this same problem with my stack-able dryer. It was leaving small burns on my kids clothes and my good sheets. My dryer has a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer can get caught and scorched or torn in the space between the clothes drum and the front of the dryer interior. My seal was worn out, so I needed to replace it. I had someone come in and do the work the first time but when it wore out again I just order the part and replaced it myself. It is fixable:)
Apr 07, 2008 | Kenmore 98702 Stacked Washer/Dryer
Dryer damaging clothes
Call repairman if you are not mechanically inclined it will be worth the money spent.
Oct 29, 2007 | LG DLG5988 Gas Dryer
Dryers Logo
684 people viewed this question
Top Dryers Experts
