Question about HP (D7580-60003) Motherboard
Password I put Password in the setup where u go change defaults and boot sequence and I forgot what it was how can get into it.
    Guru:
  • 1,342 Answers
My son put a password on my Dell inspiron n4030 and he forgot how can i factory reset it without a password
See link below for a possible solution. Please note: virtually any solution will require another computer to download software and create a bootable CD or DVD. Your initial boot screen should give you the key or keys to press to change the boot sequence and force a CD or DVD boot.
Offline Windows Password Registry Editor
Jun 08, 2014 | Dell Computers & Internet
Reset password forgot
Hi, if this is Windows PC, you need to download an ISO disk and burn it, along with a PW reset program (like Ophcrack)- or store it on a memory stick. Then reboot, press F2 to enter the BIOS setup and change the sequence devices are read in the boot sequence. Move USB ports up top and CD rom second before HD. Then save and reboot with USB/CD with ISO inserted. Use the ISO SW to navigate, use the PW recovery program to reset PW.
Jan 03, 2014 | Computers & Internet
Xirrus XN4 forgot password
To reset a Xirrus Array to factory default:
Connect to the console with Putty via Serial - Setting the Baud to 115200.
Power cycle the Array and watch the boot sequence very carefully. Press Spacebar access bootloader
Use the default UN/PW: admin/admin
- You should be at an XLB> prompt
-Type 'env reset' and press enter
Array will reboot and all settings should be back to factory default.
Nov 09, 2012 | Computers & Internet
Forgot user name and password
All Linksys routers have a built-in web-based setup page that allows the user to customize settings and set up advanced properties.
NOTE: Before accessing the router's web-based setup page, make sure the router is powered on and the computer is wired to one of the Ethernet ports on the router (1, 2, 3 or4 ).
Accessing the Router's Web-Based Setup Page
NOTE:To access the router's web-based setup page using Mac, click here.
Step 1:
Open a web browser such as Internet Explorer.
Step 2:
Go to the Address bar and enter your router's IP address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE : For WRP400, the default IP address would be "192.168.15.1" and if you place the router behind a primary router with the IP address of "192.168.15.1", then the router will automatically assume a new default IP address, "192.168.16.1".
NOTE: If the IP address of the router has been changed, type the router's IP address in the Address bar instead.
The router's IP address can be changed by:
1. Running the router's setup CD.
2. Changing it on the router's web-based setup page.
If you forgot the router's IP address you can:
1. Check the router's IP address. For instructions, click here.
2. Press the Reset button at the back of the router for 30 seconds.
NOTE
: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the password will be "admin".
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank then enter your router's password ("admin" is the default password), then click OK.
If you forgot the router's password you need to reset the router. For instructions, click here.
Windows XP
Windows 7
NOTE:
If the password of the router has been changed, type the router's new password in the Password field instead.
The router's password can be changed by:
i. Running the router's setup CD. Click here to learn how to download firmware.
ii. Changing it on the router's web-based setup page. Click here to learn how to change password on the web-based setup page.
Unable to Access the Router's Web-Based Setup Page
Reset your router for 30 seconds. Try accessing again using the default IP address "192.168.1.1". If you are encountering problems accessing the router's web-based setup page, click here.
Related Articles:
Setting-Up WPA Wireless Security on a Linksys Router
Changing the Wireless Network's Name (SSID) on a Linksys Router
Setting-Up a Router with DSL Internet Service
Downloading at Linksys by Cisco Support Site
Nov 06, 2010 | Linksys Wireless-G WRT54G Router
What is the boot up sequence please
You need to go inside BIOS to find out whats the boot sequence. To activate the BIOS Utility, press F2 during POST (when “Press <F2> to enter Setup” message is prompted on the bottom of screen).
Press F2 to enter setup. The default parameter of F12 Boot Menu is set to “disabled”. If you want to change boot device without entering BIOS Setup Utility, please set the parameter to “enabled”.
Press <F12> during POST to enter multi-boot menu. In this menu, user can change boot device without entering BIOS SETUP Utility. Navigate to BOOT page on top.
Hope this helps!
Aug 22, 2010 | Acer Aspire 5535-5050 Notebook
Can't boot and forgot bios password on ibm r50e
Yikes. You've set a password on the BIOS and don't remember it?
Well, most manufacturers set a "backdoor" password on the bios that will allow you to get in. It used to be the backdoor PW for IBM was "merlin" but that may no longer be the case. If you absolutely cannot get in, then your option is to open the case to the laptop and disconnect the CMOS battery for about 15 seconds and then reconnect it. That will clear the CMOS to the factory defaults.
I wish you well with this.
Thanks for using FixYa!!
Mar 06, 2009 | IBM ThinkPad R50e Notebook
Bios default password
The BIOS default password is just blank, and it is not asked.
When you set a bios password, you are asked to enter a value, therefore if bios is asking the password, the password had been changed.
To reset the bios password if you do not know the password you need to access to motherboard and temporarily remove battery for few seconds.
Removing battery will reset bios and delete the password.
Unplug power cord before accessing the motherboard, and try not touching the motherboard with your finger.
Put battery back in place before restarting computer.
See also the following websites:
technibble.com/..
satyathakur.com/blog/
Mar 04, 2009 | Dell OptiPlex GX520 PC Desktop
Boot
Since you forgot the password best thing to do is make the cmos forget it. The way to do this is remove the cmos battery. Take it out for several hours then put it back in. This will reset the cmos and you should gain access.
Sep 20, 2007 | Packard Bell (181379) Motherboard
HP (D7580-60003) Motherboard Logo
110 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
