Question about Toshiba Computers & Internet
I have a Toshiba Satellite Pro L10 laptop which now fails to detect the hard disk during a start up. It shows a PXE fault and won't proceed any further. The laptop is running XP.
    Guru:
  • 1,342 Answers
Your computer is trying to boot from LAN. Somehow the boot order got changed in the BIOS. Access the BIOS and set the first boot device to the hard drive.
Refer to this article for further assistance.
Posted on Jul 07, 2008
Problem with my Laptop
Maybe its a hard disk problem or a software issue. Do you have a boot disk? Try this Download Hirens BootCD 15 2 HBCD Fan Discussion Platform , that's a good tool to format disks and other things.
Mar 01, 2014 | Toshiba Satellite A135-S2276 Notebook
I have a toshiba satellite l655d-s5093 with windows 7 and it shows pxe-mof exiting intel pxe rom... no bootable device -- insert boot disk and press any key. any help to restore my computer? Thanks
Try a "Cold-Start",Remove all media, DVD, CD, USB..etc., Remove AC plug, Remove Battery, Hold down on/off button for 10 seconds, Replace battery, Plug into AC outlet,Push on/off button and Start normally.
IF THAT FAILS, try F-8 during pre boot, try to get to safe mode, or F12 to enter restore /recovery. After each try cold start, remove battery during this process.
Nov 09, 2012 | Toshiba Satellite L655D-S5093 Laptop
Laptop won't start up
The error PXE-E61: Media test failure usually means the hard disk has failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Aug 12, 2012 | Toshiba Computers & Internet
Pxe-e61
PXE-E61 ERROR
The error PXE-E61: Media test failure usually means the hard diskhas failed or the hard disk needs re-seating or the disk controller is faulty.First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Next - to check if the harddrive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a workingcomputer's USB port. If this computer cannot see itas an USB mass storage device and you cannot open the various folders and fileson this drive, then this confirms the hard drive is faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Aug 06, 2012 | Toshiba Satellite A135-S4527 Notebook
Toshiba satellite pro l450-13q PXE-E61 media test failure check cable
This indicates hard drive issues, or windows files have been corrupted. If you have a backup disk try and load windows, no change! have the hard drive tested for possible replacement.
Jul 08, 2012 | Toshiba Satellite Computers & Internet
Error codes pxe-m61 and pxe-mo0f
The error PXE-M61: Media test failure usually means the hard diskhas failed or the hard disk needs re-seating or the disk controller is faulty.First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Dec 19, 2011 | Toshiba Satellite P35-S611 Notebook
PXE-61 Media test failure/ PXE-MOF Exiting PXE Rom
The possibility of the hard disk is not detected. So, when the laptop is powered on, the hard disk is not detected.
solution
Remove the hard disk, then reinsert
Nov 22, 2011 | Toshiba Satellite Computers & Internet
My toshiba satellite pro 4600 laptop has a error PXE-E61 media test failure, check cable and PXE-MOF existing Intel PXE ROM
This error relates to an antiquated boot system used mostly for dumb terminals. It's coming up because the laptop isn't detecting a hard drive that is bootable or a bootable dvd so it continues down it's list of options and tries to boot from your network card.
This means the harddrive in your laptop is damaged or failing. If there's nothing of importance on the drive or if whatever important stuff is on there is backed up elsewhere. Buy a new drive(or have your local PC shop put one in) and use the factory Toshiba restore disks to get up and running again.
If you do have important files on the drive you can still get it up and running, but save the old drive(pack in an anti-static bag), and contact www.armor-it.com for professional assistance retreiving whatever files you need from the failing drive.
Let me know how you make out or if you need further assitance.
Chris
Jan 07, 2010 | Computers & Internet
Toshiba Satellite A215-S4747 does not start up.
Have you tried booting from a cd?
It sounds like you hard drive has failed.
Dec 31, 2009 | Computers & Internet
Pxe-e61 pxe-m0f error with boot up
Hai,
It seems that ur hard disk is having some kind of mechanical problem. Solution to this is try to boot it up and if u succeed, backup ur documents to a pendrive or CD and go for a new HDD
good luck
Rabby
Jun 16, 2008 | Toshiba Satellite Pro 6000 Notebook
Computers & Internet Logo
104 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
