Question about Sony Computers & Internet
My Sony VAIO PCV-1132 doesn't boot up or start anym ore, it states that I have a corrupted registry hive. I'm running windows xp professional now, although it came with Windows media edition center
    Guru:
  • 1,342 Answers
Tip
Boot problems and their possible causes & resolutions
Symptoms:
Black screen
"Invalid Partition Table"
"Error loading operating system"
"Missing operating system"
Cause:
Corrupt Master Boot Record (MBR)
Resolution:
Boot into Recovery Console and run "fixmbr" to repair the MBR
Symptoms:
"A disk read error occurred"
"NTLDR is missing"
"NTLDR is compressed"
Cause:
Corrupt boot sector
Resolution:
Boot into Recovery Console and run "fixboot" to repair the boot sector
Symptoms:
"BOOT.INI is missing or corrupt"
"Boot device inaccessible"
"Windows could not start because the following file is missing or corrupt:
<Windows root>\system32\hal.dll"
Cause:
BOOT.INI missing, corrupt or out of date as a partition has been inserted
Resolution:
Boot into Recovery Console and run "bootcfg /rebuild" to repair the BOOT.INI
Symptoms:
"Windows could not start not start because the following file is missing or corrupt:
\WINDOWS\SYSTEM32\CONFIG\SYSTEM"
Cause:
Corrupt/missing system hive
Resolution:
1. Boot into Recovery Console and run "chkdsk C: /f" to check the system disk for errors and fix them, then reboot.
2. If the error continues and System Restore is enabled, copy the system hive from the last restore point into \WINDOWS\SYSTEM32\CONFIG
3. If the error continues, copy the system hive from \WINDOWS\REPAIR into \WINDOWS\SYSTEM32\CONFIG
4. If the error continues, perform a repair installation by booting from the Windows installation media
Symptoms:
"Windows could not start because of a computer disk hardware configuration problem.
Could not read from the selected boot disk, Check boot path and disk hardware."
Cause:
Boot volume (with Windows folder) is not accessible as defined in BOOT.INI
Resolution:
Check the boot volume is accessible
Symptoms:
Dual-boot 32-bit Windows and 64-bit Windows system reports "NTOSKRNL.EXE is corrupt" trying to boot into 64-bit Windows
Cause:
System volume contains an older boot loader than the boot volume requires - e.g. XP SP2 installed after XP x64
Resolution:
Copy NTDETECT.COM and NTLDR from XP x64 installation media to the root of the system volume
on May 03, 2010 | Computers & Internet
Hey guys any windows experts out there? how do I search the registry on a corrupted hard drive? my computer crashed and right now i just have the old hard drive mounted on another machine. there is a...
To access the registry of a corrupted hard drive:
1. Attach the drive to another computer 2. Boot into a working version of windows 3. Start -> Run -> regedt32.exe 4. Click on the left panel and minimize all the folder branches so you only see HKEY_CLASSES_ROOT HKEY_CURRENT HKEY_LOCAL_MACHINE HKEY_USERS HKEY_CURRENT_CONFIG
5. Click on the root key HKEY_USERS or HKEY_LOCAL_MACHINE 6. File -> Load Hive 7. See http://en.wikipedia.org/wiki/Windows_registry#Locations for default locations 8. When you are done, UNLOAD HIVE!!!!
Mar 09, 2011 | Computers & Internet
Windows XP Home Edition (Version 2002) will not load, bought "Iolo's System Mechanic", but it says not to proceed if the system is 64-bit...data will be corrupted. How do I find out if my Sony...
If it is running Windows XP Home Edition (Version 2002) it is not 64 bit it is 32bit. 64 bit only came in Windows XP PRO 64bit and Vista 64bit and Windows7 64bit
Feb 12, 2011 | Sony VAIO PCV-RS630G PC Desktop
My laptop will not boot, instead it goes to a blue screen that states it is not able to access the hive.
I think this is the exact error : Stop: c0000218 {Registry File Failure} The registry cannot load the hive (file): \SystemRoot\System32\Config\SOFTWARE or its log or alternate
CAUSE
This issue can occur if the System or Software hive for the Windows XP installation is missing or damaged.
RESOLUTION:
To resolve this issue, please follow one of the following methods.
Use the Recovery Console Tool:
To restore a damaged registry hive, use the Recovery Console to restore the backup copy of the hive from the Repair folder. The Repair folder contains a copy of the system's registry hives that were created after the first successful startup of Windows XP.
WARNING : Although data should not be affected by the following procedure, you may need to restore changes you previously made to programs or system settings since the first time you successfully started Windows XP.
To replace the damaged registry hive and restore the backup copy of the hive from the Repair folder: Start your computer to the Recovery Console. You need your original XP CD, boot your PC from the CD and press R when it say 'Press 'R' to use recovery console.
In Recovery Console, change to the c:\Windows folder.
Type cd system32\config , and then press ENTER.
Type dir system , and then press ENTER.
If you cannot run the preceding command successfully (because the file is missing), skip to step 3. If you can run the preceding command successfully, type ren system system.bak , and then press ENTER.
Type copy c:\windows\repair\system , and then press ENTER.
NOTE : If the message that you received referred to the software file, replace "system" with "software" in the preceding command. For example, you would type copy c:\windows\repair\software (instead of copy c:\windows\repair\system ), and then press ENTER.
You should receive a "One file copied" informational message. For additional information about how to use Recovery Console during startup, click the article number below to view the article in the Microsoft Knowledge Base:
Q307654 HOW TO: Install and Use the Recovery Console for Windows XP
IMPORTANT : If you encounter problems when you run the preceding commands, you may need to use the Change Directory command ( cd ) one folder at a time before you run the preceding commands. For example, type cd system32 , press ENTER, type cd config , and then press ENTER.
Type exit , and then press ENTER to quit Recovery Console and restart the computer.
i understand this looks a litle daunting, please get back to me if you have any trouble with this.
Oct 16, 2010 | Sony Computers & Internet
I have a dell dimension 4400. when i turn it on, it runs normal, but after the windows XP is loading "logo", the screen goes blank for about 5 minutes, and then i get a blue screen with whire lettters that...
The operating system is corrupted you have reinstall you windows xp , you have insert the xp boot cd in the cd rom after that the option will be aksing to (press any key to boot from cd..) at that time you have press any key then the booting will be started.
Oct 30, 2009 | Dell Dimension 4400 PC Desktop
Registry File Failure c0000218
Try this: Reboot and select Recovery Mode, then from the c:\windows prompt type: chkdsk
Let it run through checkdisk then try it should boot up.
Jun 25, 2009 | Sony VAIO VGN-N110G/W Notebook
My Sony Vaio keeps saying MTLDR missing, restart, & F8 did not help
You have a corrupt registry. The easiest thing to do is get out your Windows Cd and boot to it. Choose the option for a repair install and allow it to proceed. 30-45 minutes later, you will be back in business.
If you are more daring, you can use the recovery console to copy the 5 registry hives from the C:/windows/repair folder to the system32/config folder, but this will force re installation of some programs.
Either way, you will not lose data
Jun 23, 2009 | Sony VAIO PCV-RX511 PC Desktop
Sony Vaio PCV-RS710G wont start up
one of the files in the system32 directory in the windows folder is corrupt, the files in the system32 folder contains vital files for the boot procedure, try to start the machine in "safe mode" by pressing F8 after the sony boot screen, if it allows you into the operating system you will need to choose "system Restore" take the time back to at least a week before your problems started DO NOT CREATE A RESTORE POINT
Nov 14, 2008 | Sony VAIO PCV-W600G PC Desktop
Problem with pc
Here is the solution right from Microsoft.
SYMPTOMS
When you try to start or restart your Windows XP-based computer, you may receive one of the following error messages:
Windows XP could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM
Windows XP could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SOFTWARE
CAUSE
RESOLUTION
To resolve this issue, use one of the following methods.
Determine if the file that is mentioned in the "Symptoms" section of this article is present, and if it is, rename it:
Type cd sytem32\config , and then press ENTER.
NOTE : If the message that you received referred to the software file, replace "system" with "software" in the preceding command. For example, you would type ren software software.bak (instead of ren system system.bak ), and then press ENTER.
Oct 23, 2007 | Computers & Internet
Computers & Internet Logo
772 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
