Question about Sony SDM-HS74P/S 17" LCD Monitor
Sony SDM HS74P Screen Stays on for approx 15 seconds then shuts off but power light is still on?
I recently acquired a Sony SDM-HS74P Flat Screen monitor but I am stumped. The screen comes on and is brilliantly displayed for 2 to 15 seconds (depending on how long it is on) but then shuts off, leaving the power light still on? I have looked for parts but do not know where to go? Is there something I can do without having to hunt down impossible to find parts?
  • 2 more comments
  • Anonymous Aug 15, 2008
    HI, SEEMS LIKE POWER ISSUE, U NEED TO REPLACE THE THE POWER BOARD ON THE UNIT, THE POWER BOARD MODEL FOR YOUR SYSTEM IS PWI17LS285A, ACTUALLY THE CAPACITORS DOES NOT KEEP ENOUGH CHARGE TO KEEP THE LCD WORK... HOPE YOU FIND IT HELPFULL
  • goofygeef Oct 01, 2008
    I had mine replaced under warranty TWICE by Sony for this problem. The original new unit went 2 years.The second unit (the rebuilt replacement they sent) lasted 6 months. So far, after 18 months, the third (also rebuilt) unit is holding up.
  • patrick7550 Mar 27, 2009
    I have a VAIO with a SDM-HS74P screen. When powered on the screen comes on for 2 seconds and then goes off.
  • Anonymous Apr 06, 2009
    yea.. exactly the same problem, except, when it turns off, an "out of range" error message...
    Problem Solver:
  • 9 Answers
so the big capicitor needs to replaced? 100µF 450V
Posted on May 17, 2009
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 165 Answers
Your problem is the capacitors please verify all your capacitors and the "big" one what have 450V
Posted on Nov 25, 2014
I think my monitor and/or driver /cable is causing a blue screen error on my dell inspiron laptop???? is there a driver update or something else i can do to update my monitor?
blue screen error is not there because of monitor's driver
there are others reasons like
1. smps supply may be faulty you may swap it with some other
2. recently software is faulty
3. mother board is faulty
Aug 27, 2010 | Sony SDM-HS74P/S 17" LCD Monitor
LCD screen SDM-HS75P has a message on the center displayed all times.It says INFORMATION MODEL:SDM-HS75P SER.NO:1022769 MANUFACTURED:2005-18 and it stays on top of windows all time. How can I take this...
Press once the Input button. The menu appears. Press the Input button again and hold it. Now this is reduced to the problem of blocking the Input button (holding it with something). (Not very technical but then again neither is the restart when the computer blocks :D) Cheers
Mar 04, 2010 | Sony (141857441) 15 in. Flat Panel LCD...
Screen flickers. Color is off until it warms up or I give a good hit.
you have a bad power supply. remove rear cover look for crowned or leaking capacitors. reomve bad ones by desolding. take to electronics arts store and get new ones. resolder and good to go.
Dec 24, 2009 | Sony SDM-HS74P/S 17" LCD Monitor
My Sony SDM-HS74P display does not stay on.
I have the same issue and wrote the monitor off for now after checking all cables (and a different computer). The logic circuitry and panel are sill ok as I can see a faint image with proper lighting and close inspection, but no backlight makes it useless.
Since there are 4 lamps (CCFLs) on this model, the problem likely is not there but on the inverter circuitry driving them. This does not look easy to replace as this is part of a bigger board.
It looks like some could repair by changing a few (or even one) component on the board, but unless your are used to this (de-soldering and soldering back), you are kind of stuck.
I will attempt this if I have time as I hate junking 99.9% ok hardware. In your case since this is an old monitor you should just replace it if not technically (on the electronics side) apt.
Dec 13, 2009 | Sony SDM-HS74P/S 17" LCD Monitor
MY SONY SDM-HS74P
You open the inverter unit and check any dry soldering is there. Some times dry joints inside the inverter unit cause this type of problems.
Apr 06, 2008 | Sony SDM-HS74P/S 17" LCD Monitor
Sony SDM-HS74P/S 17 Monitor won't stay on the right picture.
This is a duplicate post, click the following link to read the active posting: http://www.fixya.com/support/t138012-sony_sdm_hs74p_s_17_monitor_stay_right
Mar 16, 2007 | Sony SDM-HS74P/S 17" LCD Monitor
Sony SDM-HS74P/S 17 - Monitor won't stay on the right picture
When the screen turns black again take a flashlight and shine it in the bottom left hand corner where the Windows Start button is located. If you can see a faint image then your back light is failing. If that?s not the case the next step would be to attach another monitor to your computer to see if the problem disappears. If it does that points to the monitor, if it doesn?t then we need to take a look at the computer itself. Let us know what you find out and please don?t forget to rate this posting.
My monitor says "input ......" and then the screen flashes off.
Sony SDM-HS74P 17" Monitor goes black after turning on
Most likely you inverterboard went bad on the monitor.
Nov 04, 2006 | Sony SDM-HS74P 17" LCD Monitor
Sony SDM-HS74P/S 17" LCD Monitor Logo
1,887 people viewed this question
Top Sony Computer Monitors Experts
Lala Alonsi
Lala Alonsi
ray gallant
Are you a Sony Computer Monitor Expert? Answer questions, earn points and help others
