Question about Kenwood Car Audio & Video
I have a kenwood deck and it locked i can not use it it is a kdc-mpv6022
  • 405 Answers
Good Day,
KENWOOD SECURITY CODE CLEAR procedure
These codes are applicable for all Kenwood radios that do not have DVD or DVD screens located on unit.
Your radio will require one of the following procedures.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds
(so that “…” disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio
stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key on the remote
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key on the remote
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key on the remote
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key on the remote
The security is canceled and the set enters the TUNER mode!
The above was pulled from:
http://forum.ecoustics.com/bbs/messages/4/134366.html
Also try:
press reset use remote right after it loads press 552222777 then track forward do this with the remote open so you can use the numbers and make sure its in the audio mode the little switch on the side. prerty simple p.s. nothing will happen on the screen so dont stop pressing the code and press track forward you can now set the code to what ever 4 dig code you want in the set up screen
Also try: bypasse code of "2222"
Hope this helps
Posted on Jul 07, 2008
Kenwood KDC-319 CD Player Logo Problem with KDC-319 CD Player installed a kenwood kdc 319 in a 04 chevy malibu when i have car off i turn deck on an my cars dash board lights turn on Posted by A
I would start by disconnecting the radio and hooking it up right,the power should go through the ignition switch.So that when you turn the car off the radio will go off and to hear it on again you have to turn the key to accessory or start it.That might take care of a few of your problems.
Jun 25, 2012 | Kenwood KDC-319 CD Player
My Kenwood KDC-X493 deck is flashing "Protect" ,
You can unplug the unit for 10 minutes. This will clear this.
Jan 19, 2011 | Kenwood KDC-X493 Car CD/ MP3 Player
Can you ground a amp to a aluminum washer and bolt
the bolt and washer don't really matter. you just have to make sure you have a good clean connection to the chassis or ground. aluminum is a very good conductor by the way.
Jun 30, 2010 | Kenwood Sirius KDC-MPV6022 CD Player
Need un lock code for a KDC-MP528 kenwood cd
Hey to reset the code on a Kenwood deck try this: Hit Disp 1 one second after V up spell KCar w/track up button it should work.
Sep 19, 2009 | Kenwood KDC-MP528 CD Player
I just bought a Kenwood KDC-MP438U I installed all the wires right, power is to the deck because it accepts a cd. the deck face doesn't light up. I called in at Kenwood and they had me test it directly to...
Check your Ground Wire inside the Truck and Check the Illumination Wire. I Think on Kenwood the Illumination Wire goes with the Power Wire. If they still will not work, You might want to get a Wiring Harness from Schoche.com Please Rate My Response! Thanks!
Jan 30, 2009 | Kenwood KDC-MP438U Car CD/ MP3 Player
SECURITY CODE ON MY CD DECK
Get the serial number for you unit and call Kenwood in your country. They will have the codes on file. They will also give you instructions on how to put the code in.
Jan 20, 2008 | Kenwood KDC-MPV619 CD Player
Kenwood KDC-X590 ipod
Do you have a Ipod shuffle?
Is the deck on random?/shuffle?
Try pressing the small reset button on the deck, its small a small black button you would need a pencil tip to reset!
Hope it helps,
Don
Mar 16, 2007 | Kenwood KDC-X590 CD Player
Car Audio & Video Logo
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
