Question about Ricoh Office Equipment & Supplies
I am having difficulties connecting my laptop to a networked Ricoh Aficio CL7000 PCL 5c. I have installed the correct driver.
I downloaded the driver and placed it on the desktop.
Then went into printers and faxes and logged into add a printer.
Follow the wizard and make sure that you create a new port and
hook into a TCP IP port using 10.1.1.100 as the address when requested.
The mistake I was making was using a local port.
Printer is now working.
Posted on Jul 07, 2008
Ricoh Aficio SP C430DN - Print Data Error
Its you, change drivers, postscript on the printer? PCL 5C is what your are using?
Mar 31, 2014 | Ricoh Office Equipment & Supplies
Print driver (2228C PCL 5C) shows printer queue offline. How can I bring it back online? I have rebooted the printer. There dosen't appear to be an option on the print queue when going in as admin on...
Remove the data cable from the back or size of the printer. Turn the printer on and let it cycle. Then plug back in the data cable. It should show a green light by the cable if you are reconnected.
May 12, 2011 | Ricoh Aficio 2228C Copier
We have a network ricoh aficio mp 1600 pcl printer we recently upgraded to windows 7 printer and copier are working ok but scanner is not working is there a problem with the scanner driver for windows 7
please go to www.ricoh.com and instal the scanner drivers of windows-7 other wise you can instal the scan to folder which dos not required any drivers or you can install scan to mail this also does not required any drivers - thanks
Mar 10, 2011 | Ricoh Aficio MP 1600L Black and White...
Using the PCL drivers for our Ricoh Aficio MP 3350
Try using the RPCS (Ricoh's proprietary print driver) for printing from Word, and see if that works any better. You could also try another version of PCL -- if you're using PCL6, try PCL5, for example.
All of the 3350 drivers can be downloaded here (just choose the correct operating system):
http://ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb/html/dr_ut_e/rc2/model/mp33/mp33en.htm
Dec 02, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
Installed XP printer driver for Ricoh CL7000 5c
during the installation you have to select this option, by default the duplex option is not selected. Uninstall the software, restart your pc and install the software again, and select the duplexing option. I hope this helps
Sep 03, 2009 | Ricoh Aficio CL7000 Laser Printer
Ricoh SP C410DN Will Only Print One Page
Hello sir; you need to set up your system from printer, go to manue ,roll down to system , roll down to auto continue,then press enter ,
Feb 13, 2009 | Ricoh Aficio CL3500N Laser Printer
HO TO FIND THE RIGHT DRIVER FOR RICOH AFICIO 250 COPIER
Goto ricoh-usa.com and select the correct drivers from the model number for your copier.
Use the PCL drivers only.
Oct 19, 2008 | Ricoh Aficio 250 Copier
Ricoh Aficio CL7000
If you have it connected by a CAT5 network wire, then the answer is no.
if you are using a usb 1.1 port on your computer to print to it, then that port is a slow port. I would recommend getting a faster 2.0 usb adaptor and using that port. It will print a little faster.
Steve C.
Oct 17, 2008 | Ricoh Aficio CL7000 Laser Printer
Installation driver for Ricoh Aficia CL7000 laser printer
go to www.ricoh.com, usa, downloads and then select your printer in the drop down windows, lastly choose your operating system. now just unzip the file and install
Sep 26, 2008 | Ricoh Aficio CL7000 Laser Printer
Network printer installation problem
Are you using the proper Windows Vista Driver? You can't use the XP version...here's a link to the download page:
http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb/html/dr_ut_e/rc2/model/cl7000/cl7000en.htm
Jul 11, 2008 | Ricoh Aficio CL7000 Laser Printer
101 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
