Question about Dryers
Whirpool dryer how do I get the heater element out of the casing of an old electric whirpool dryer?
  • bornaschella Jul 07, 2008
    How do I get the heater casing element out , not the heater element but the casing that it is in? It is the casing that I am having the problem with it. It is an old whirpool dryer at least 12 yrs It looks like there are no screws holding the casing on the back of the dryer.
  • 481 Answers
Once you take the element casing out of the dryer then you will see a screw at the very bottom of the casing where the element goes in. usually a 5/16 hex head screw.whirpool dryer - 1933c22.jpg
Posted on Jul 07, 2008
  • Mike Durland
    Mike Durland Jul 07, 2008
    • depending on its size (super capacity, large capacity),
    •  at the top of the element casing there is a metal clip held by a screw.
    • older dryers require a 6" extension on a 1/4" drive ratchet with a 5/16" socket. this goes thru a small hole in the outer case to the screw holding this clip.
    • newer dryers, the screw is on the inside (where the drum is) so you have to lift the lid to get to it.
HOW DO YOU CHANGE THE HEATING ELEMENT ON A WHIRPOOL DRYER MODEL LE7000XTW0
The heating element is on the back side under the dust cover.
You gotta remove a strap at the top of the heater chamber and then you can get the heater assembly out. Remove the filter and raise the top:
The element is on the right
The heater
the heater element slides out after ya remove a screw at the base.
Service Manual
Oct 29, 2011 | Whirlpool Dryers
We have a Whirpool AWZ 2303 that only blows cold air & the heater element looks OK - will it definatley need a new heter element or could it be something else?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 10, 2011 | Dryers
Whirpool dryer 10 years old is still heating but taking very long to dry clothes. Checked dryer vent and it is clear. Will heating element help?
If your heating element is still heating up the cause lies elsewhere. Filter for dryer both at the base of dryer and filter location . If you are getting heat then airflow is the problem. how is the fan motor in front of heating element
Mar 09, 2010 | Whirlpool LER5636P Electric Dryer
What resistance is expected for the themostat, high cut off, and heater element, for a WED5300SQ Whirpool Elec dryer?
high cutoff should be 0 ohms or dead short like a switch, the element can vary from 100 ohms up to 250 ohms depending on the model
Dec 24, 2009 | Whirlpool WED5300S Electric Dryer
NO Heat
Replace the timer,the spot on the timer is burned out.
Oct 01, 2009 | Whirlpool LER5636P Electric Dryer
No heat at all.
Hello Friend, Your problem is very simple to fix. You need a thermal fuse and or heater element, both very simple and affordable to replace. Try replacing the thermal fuse first to see if that's the problem. To replace the thermal fuse just remove back cover of dryer and look down where the air blows out. Now, just to the left where all the wires are you will see a white plastic part with two wires plugged into it. This part is called a thermal fuse. Just remove these wires and replace the thermal fuse. If this don't solve your problem you will need to replace the heater element. To replace the heater element, with the back cover off of your dryer just look down and to the right of were the air blows out. You will see the electric heating unit with two fat red wires plugged into it. Unplug these wires and you will see on the sheetmetal housing two screws that hold it on, one on each side. On older elctric dryers there is only one screw that holds element in place, it is on the bottom center of element screwed in from behind. Remove screw(s) and remove old heater element. Now, lay the new element next to the old one and take notice that there is a heat sensor attached to the old element where one of the red wires unplugged from. Gently remove this sensor and install it onto the new element in the same location as the old one. If you have an older electric dryer, the old heater element doesn't have the heat sensor on it, just skip this step. Now, plug in your two red wires and re-install your heater element. Your dryer will run like new. Happy to help, Tim.
Jun 26, 2009 | Roper REX3614KW Electric Dryer
Heater element for whirpool dryer
  • depending on its age,
Jul 06, 2008 | Dryers
How do i get the heater element out of the whirpool dryer
take off the back panel, then to the right is a large vertical metal casing. depending on the age of your dryer, you either:
  1. take off the 4 screws near the bottom of the casing to release the heating element.
  2. older dryers require the whole casing to be removed and the element is slipped out of the bottom of the casing.
Jul 06, 2008 | Whirlpool Dryers
Dryers Logo
98 people viewed this question
Top Dryers Experts
