Question about E-Machines eMachines Desktop PC
Unit will not Boot up
I have T6520 desktop e-machine. When powered up, the power blue LED is on, the HDD yellow LED is on, system and processor fans are running and after few seconds a beeping sound comes on. It doen't boot up because you don't hear the typical booting activity associated with a booting-up hard drive and the monitor flashes "no signal". KAJuly06
  • hoserleo Jul 11, 2008
    I have a T6532 desktop model. The power on light is lit, the yellow flashes a couple of times, but I don't hear the hardrive actuate.I get no video prompt from the monitor. I checked my monitor with another PC and it's in working order. I also disconected and reconected all the peripherals.It's there any way that the start up protocols had been compromised ( a virus)and is there a solution?
  • cagiemoore Jan 23, 2009
    I have the same problem as mentioned above. Using Microsoft Windows XP 2005 on an eMachine T6520. CPU = AMD Athlon 64 3400+. It would beep a short beep about every 3 to 5 seconds. It will not boot all the way up. Can you help? Thanks.
    Problem Solver:
  • 30 Answers
A long beep? what?
be specific!! so we can help
Posted on Jul 07, 2008
  • edward belmes
    edward belmes Jul 25, 2008
    start up might be affected. try boot to cd ( bootable disc) or to usb, if that works, your system is infected. reformat your system to do clean up. before installing new OS.
  • 23 Answers
Make sure your monitor is plugged in and try again
When turning computer on, fans start then shuts down with one long blue light flash around power button. Suspect power supply
You could be right in your analysis, however, before replacing the PSU unit (a weak point with both Medion and E-machine computers) check the following:
  • That the Power button is not sticking in the case
  • Inside the computer case, the PW wire is firmly making contact with the motherboard (switch to motherboard 2 pin wires)
  • That the PW wire does not have a kink in or is broken giving an intermittent fault
After checking those:
  • Disconnect HDD, DVD Writer, remove 1 stick of ram and test with each removed, replacing each in turn. If the computer still does not boot, then check the ATX connector to the motherboard and the 4 pin auxiliary CPU connector (black and yellow) if fitted
  • Remove the motherboard and check underneath to make sure there are no items of metal that might be causing the board to short out. Check the board underneath for signs of blacking or burning.
  • Replace the board and refit all connections.
  • Inspect the capacitors on the board (small cylinders) if any are bulging at the top, leaking and with a brown residue, the board is failing and will need replacement.
  • Finally, remove the PSU and test with a known good one.
  • If this fails and the board shows no blowing capacitors, the problems may now lie with a blown CPU or micro damage to one of the motherboard circuits
Jul 18, 2011 | E-Machines T6520 PC Desktop
I need the wiring diagram that shows where on the motherboard to plug the power switch ,power LED, and HDD Led on a T6520 emachine desktop
Most Motherboards are made to only accept certain plugs in that specific spot! If you are trying to add something new like a new Fan or LED, or HHD and you need power you would have to use a 4 prong plug off the power supply, If your power supply does not have any more available plugs, Amazon.com or Newegg.com sells splitters!
Good Luck and Best Wishes!
May 03, 2011 | Computers & Internet
Installed a Graphics Card on my Emachine. Made sure it is in the PCIX slot correctly and seated right. I also installed a Power adapter cable (20 PIN - 24 PIN ATX) to utilize the other 4 pins for use with...
Sounds like there isnt enough power even with the adapters your powersupply cannot give you enough sustained power to run the system if you take the card out does it boot normally? even just disconnecting the power to the card?
Mar 26, 2011 | E-Machines W6409 (7234) PC Desktop
Gateway 503gr has no power, the standby light flashes green when I remove power. Tried new PS and the standby LED stays lit. I then tried both new and old PS disconnected from board and shorted...
Disconnect everything from the motherboard except the power supply connections and cpu fan. Install one stick of RAM and connect your monitor. Then try starting up. See if you get any BIOS boot messages. This will tell you that the board and processor are okay.
With what you say you've tried already, I'm thinking you might have a bad processor. Most every other problem would result in some kind of error like POST beep codes or messages on screen. If the system still doesn't boot with the bare minimum parts installed, replace the processor.
Mar 02, 2010 | Gateway 503GR PC Desktop
Blue LED light connection from Bezel to Motherboard
red white is the pair that supplies power it should be 2pin socket on motherboard
Sep 19, 2009 | E-Machines T6520 PC Desktop
Wires unpluged
these normally go at the front of the motherboard if you are looking at it where the power supply box cables are at the back. There are litlte pins that these fit onto that will say on the motherboard Hdd led etc... in small writing.
hope this helps
Oct 31, 2008 | E-Machines eMachines Desktop PC
I have an emachines t6520 and the power sw wire, HDD led wire, and the power led wire hve been disconected
On the system board, on the left edge next to the primary IDE connector, there is a 9 pin header.
I usually get a magnify glass and look down on the header . From right to left,you will see PWR led pins closer to the edge of the motherboard.and the Power BTN next to it.(the side of the pins that has 4 pins on it)
Then on the other side, you will see the pins for the HDLED across from the PWR led. Then the Reset pins across the PWR BTN.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 29, 2008 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
275 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
