Do you want to format your windows or your hard drive? These two are a bit different thing. If you want to format your windows then get a Windows CD with a valid serial key to format your Windows. And if you want to format your Hard Drives other than the drive in which the Windows Files are installed you can do it manually without re-installing the windows. But to format the Hard Drive in which the Windows Files are located you should format your computer with a Windows Copy.
Reinstall Windows XP
loadTOCNode(2, 'moreinformation');
To reinstall Windows XP, try either of the
following methods. If the first method does not work, try the second.
Note
You may want to disconnect from the Internet during the installation.
This helps protect you from malicious users.
Start the reinstallation from Windows XP
loadTOCNode(3, 'moreinformation');
To reinstall Windows XP by using Windows XP CD, follow
these steps:
If you
successfully completed the reinstallation, congratulations. You are
almost done. Please continue to the "After you reinstall Windows XP"
section to finish.
Method 2: Repair install of Windows XP by starting
your computer from the Windows XP CD
Note If Windows XP was preinstalled on your
computer, you may need the installation CD to reinstall. Contact your
computer manufacturer to make sure that you have the installation CD for
a repair installation.
To reinstall Windows XP by starting your
computer from the Windows XP CD, follow these steps:
Hope this helps.
do you have the windows xp disc
