Question about Viking 42 in Built In Professional Integrated Side by Side Refrigerator - VISB423
Water leaking from freezer
Last summer we had 2 repairmen out to discover that the water hose had a crack in it. Unfortunately this leak ruined our hardwood floors around the fridge.
Now we have water trickling out from the freezer side and we keep putting a dish towel down while we are tryng to figure this one out. My husband and already made adjustments to the temperature and even cleaned some fan that can get plugged. I am ready again to call a repairmen to our hous. I wish we had known prior to our purchase that it would take 2 repairmen to move this monster.
  • Bikerpoohbea Nov 25, 2008
    Water leaking from freezer side at bottom. Don't see any leaks. only leaks about once a week. Any though?????????????
  • Tom Hurley May 11, 2010
    do you have any ice on the freezer floor
  • 6,927 Answers
If the water input for the ice maker is not leaking ,have him check the defrost timer.It has stopped(like a clock)on the defrost mode,while the compressor is trying to freeze the coils.It ends up a watery mess.If I can help anymore.please let me know.
Posted on Aug 20, 2009
Why is water leaking from back of kenmore elite refrigerator?
Also, can be a crack on the plastic hose, close to the inlet water valve.
Aug 16, 2014 | Kenmore Refrigerators
Water leaking from the bottom of the refrigerator
You could have a clogged drain line or a cracked drain pan. I would start with the drain line.
Mar 24, 2013 | Maytag Refrigerators
1999 chevy cavalier oils like milk in coffee, antifreeze leaked bad last winter, summer only drove 4-6 miles a week checked every time I went to store, used 1/3-1/2 gallon antifreeze, now getting cold out...
you're getting water in to your oil that's why its milky. could be a bad head gasket ,cracked head, or a cracked block, usually one of the last 2. better get it to a mechanic, if its the block it would probably be cheaper to replace the engine, it takes less time and most places charge 75-100 dollars an hour
Nov 17, 2011 | 1999 Chevrolet Tahoe
What causes the anti freeze to leak out of my 1999 chevy malibu?
if you dont have a hole in your radiator hose then you have a bad water pump. when they go bad fluid leaks out the front of your motor. best of luck to you.
Dec 28, 2010 | 1999 Chevrolet Malibu
Water leaks every 5-7 days from the freezer. I
If your water valve is not closing properly, it will do that. The water valve is not very expensive. If you have ice and water in the door, there are 2 water valves. Replace BOTH! If one is weak, the other is not too far from giving out too.
Jun 01, 2010 | Refrigerators
Fridge leaks water when Ice maker is activated by lifting lever
Either a loose or broken hose , or worse, a crack on the water valve.Pull fridge and check water valve and hose when signal calls for water.
Jul 09, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
The refrigerator is leaking water routinely and had repairmen work on this problem several times to no avail
Of course if it has an ice maker, look for leaks in the water line. Also look to see if it is draining properly during the defrost cycle. It may be partially plugged with ice or debris from the freezer. Check the drain tube for rotten places or cracks and lastly the drain pan for cracks. These are all very frequent repairs i run into.
May 04, 2009 | Frigidaire Refrigerators
Water leaks
If there is water leaking from under the washer, then you have a water leak from one of your water hoses. Check the back of the washer, where the water comes into the washer, to see if its leaking water or the hose is cracked. If its leaking water from the intake hose, then unscrew the hose and check the rubber washer, to see if it needs reolaced. Sometimes those rubber washers get cracked or broken. If that doesn't help, unplug your washer from the power cord and unscrew your intake water hoses and flip the washer gently on it's side and check the water hoses under the washer for leaks or cracks. Replace the hoses if cracked. Your local hardware store should have replacement hoses. This should solve your problem, but if not, then you need to call a washer repair person to look at it. I hope this helps.:)
Jan 19, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Leaking
Is there a condensate trap in the line before the discharge?
Also is the orifice or near it cracked?
With all the movement and expansion and contraction due to the temperature changes in the seasons and conditions, there might be a crack somewhere else.
Be ready with a Wax Ring for a toilet ( a new one ).
They usually seal it up fairly well.
Works for me until I can get a new pan.
God Bless.
Erik
Aug 08, 2008 | Danby Portable Air Conditioner
Viking 42 in Built In Professional Integrated Side by Side Refrigerator - VISB423 Logo
125 people viewed this question
Top Viking Refrigerators Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
