Question about Ricoh CL3000E Laser Printer
Error message on my Ricoh CL3000
Please help me I am desperate, I have a Ricoh CL 3000 and in the middle of printing some color copies and the print just changed color. I did a color registration and now the error light comes on saying Color Regis. Error. I have plugged out the machine and restarted it and nothing is working. Please help as I am really stuck.
    Welcome Back:
    Visited the website for 2 consecutive days.
I had the same problem with the color cpu and found that the gear/clutch was broken. I put it back on but it still does not register. Where do you find parts like that without replacing the entire unit?
Posted on Jul 27, 2016
To elaborate - what i see happening is that the yellow toner seems to be missing (and yes I have replaced the toner). All of the other colors are printing fine. What would stop just one color from printing? I am in the Caribbean with no Ricoh center in my island, any help would be appreciated
Posted on Jul 15, 2008
  • 446 Answers
What do you mean changed color, please elaborate so i can help you out, in similar scenario it could be a sliping clutch that controls the developing unit causing the respective color to disengage while working on, M, C Y, K pls identify which is which, if you can try one of each color independently as a diuagnostic then youcan start from there which color is malfunctioning,remember the combination of each color depends upon each other color, thus maybe is the reason you can see a sudden changed of color
  • ariel santos
    ariel santos Jul 24, 2008
    chances are the yellow toner developing unit is not engaging, as what you said you have replaced the toner (y) this would not mean anything if the unit that caries the toner (developing unit)fails to engage, in many scenario either the clutch is not working at all (y developer assy) or the mechanism that drives the unit fails to operate, try opening the covers and observed the situation while in actual operation this time use yellow only..
    as a first step
Installed a duplex unit in Ricoh CL 3000 not working.
You will have to find in printer driver ----> change accessories and you will have to CHECK duplex unit. Then you will be able to use the duplex.
Good luck
Sep 22, 2014 | Ricoh Office Equipment & Supplies
Color Print Quality
In my experience, the fuser has always been the cause of the lines.
Jul 09, 2008 | Ricoh CL3000E Laser Printer
Drivers for aficio cl 3000
Yes it's compatible with windows 7.
Click here
You can download the driver from above link.
Let me know if you need further assistance.
Thanks for using FixYa.
Aug 15, 2011 | Ricoh Aficio CL3000 Laser Printer
My RICOH AFICIO CL3000 give me an error message SC441, what to do ?
Did you just replace your color PCUs (photoconductor units)? If so, one of the new units may be defective. Try reinstalling the old units to see if the problem goes away (after resetting the machine). If it does, you can replace the PCUs one by one to see which one is bad.
If you still get the sc441 even with the old PCUs (or if you don't have them anymore) install a set of new PCUs and that should fix the problem. On the off chance the problem doesn't go away even with new PCUs, contact your local service company because you may have a bad circuit board, motor, or gear.
Nov 15, 2010 | Ricoh Aficio CL3000 Laser Printer
Ricoh CL3000 error sc441
sc441 is a drum motor error. It could be caused by anything from a faulty circuit board to a bad motor, but the most likely fix (and the easiest) is to replace the color PCUs (photoconductor units) which I believe all come as one set.
Turn the machine off and unplug it from the wall, then install the new PCUs, plug it back in and turn it on. There's a good chance your printer will work fine. If the sc441 error comes back, you should contact your local service company and have them take a look at it, because the problem is either electrical or mechanical.
Hope that helps!
Nov 09, 2010 | Ricoh Aficio CL3000 Laser Printer
Has bee my default printer until now. Connection to router is fine, will not print - only gives error message. none of the buttons on the control panel work. online light is out. is this a big fix or...
go to the control panel, select printers and double check if the Ricoh Aficio CL3000 Laser Printer was selected as a default printer. you can check it by right clicking the printer name and choose set as default.
Sep 13, 2010 | Ricoh Aficio CL3000 Laser Printer
How to clear the pcu code
The printer is set to display the "replace PCU" message after a set number of copies. The only way to clear the message is to replace the color PCU that the message mentions.
Apr 17, 2010 | Ricoh Aficio CL2000N Laser Printer
Error SC 411 appears
SC411: Separation bias error
-Definition- [B] A separation bias leak signal is detected. - Possible causes - · High voltage supply board defective · Poor connection of the PCU · Discharge brush defective You need the service manual or have a technician fix it. If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 15, 2009 | Ricoh (R) Aficio CL3000 Color Laser...
Ricoh CL3000 Laser Replace Waste toner
Ricoh CL3000 Laser, replace waste toner displar unit will not print, waste toner cartrige is empty.printer will not print? How do I reset unit?
Feb 17, 2007 | Ricoh CL3000E Laser Printer
Ricoh CL3000E Laser Printer Logo
203 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
