Question about Timex 1440 Nylon watch
Here is how to set 24hr or 12hr on WR50M T5E881
Alot of people here have the wrong information on how to set 24hr or 12 hr on this watch.
On the regular time screen, hold the receive/start/stop button, and the mode button for five seconds and it will change to 24hr or visa versa.
2 Suggested Answers
joeguest2
  • 2080 Answers
SOURCE: no problem I just forget
Here is a link to the Timex support page with the download links for all the different instruction manuals:
http://www.timex.com/info/Product_Instruction_Guides_Downloads
And here is the direct link to the manual for the Ironman 30 Lap model:
http://assets.timex.com/user_guides/W89_M877/W89_M877_NA_EN.pdf
To view the Support Page or the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
See page 1 of the manual for instructions which basically read as follows:
1. In TIME mode, press and hold SET/RECALL. Time zone will flash.
2. To set, push + or - to select first or second time zone.
3. Press NEXT. Hour digits flash.
4. Press + or - to change hour including AM/PM. (Scroll through 12 hours to get to AM/PM).
5. Press NEXT. Minute digits flash.
6. Press + or - to change minutes.
7. Press NEXT. Second digits flash.
8. Press + or - to set seconds to zero.
9. Press NEXT. Day of week flashes.
10. Press + to - to change day.
11. Continue pattern to set month, day of month, 12-hour or 24-hour time display, MM.DD or
DD.MM date format, turn hourly CHIME on/off, turn BEEP on/off. If you select BEEP on, a
beep will sound every time you push a button (except INDIGLO).
12. Press DONE to confirm and exit or NEXT to continue and set second time zone, if desired.
Thank you very much and good luck.
Joe.
Posted on May 23, 2011
Set time format from 12 hr to 24 hr for casio LA670W
Was this problem answered? If yes, can somebody tell me how. My Casio LA670W is in 24hr format and I want it back on 12hr format. My watch have 3 buttons only. Mode, Start-Stop and Timer
Nov 22, 2013 | Casio LA670W Digital Ladies Watch LA-670WA...
How do I set the time 12hr or 24hr on Alba Avalon ChronoCX watch
Consult the owner manual/instructions and if do not have Google the model number for "manual" to try to locate one.
Nov 05, 2012 | Alba Avalon Chrono CX Series Metal...
I just bought an adidas ADH4033. I have read through the manual thousands of times and have figured out how to change the hours on the watch but still cannot change the minutes, date, 12/24 hour, or any...
this might help. press and hold top right button to change to T1 or time 1. press and hold top left button and u will see ' light on/off' on display. press bottom left button to set chime. press again watch will show 24hr/ 12hr and current time set on watch. 12hr/24hr should be blinking. press top right button to change to preferred hour. press bottom left button to navigate to hour, min,sec use right buttons to select numbers.
Aug 27, 2011 | Watches
Can't get the time back to 12 hr mode and can't stop the timer display from flashing.
Hi, Push the set button and then push the mode switch move the cursor to when it reads 24hr and then select reset and then set button. Hope that helps you.
Aug 14, 2011 | Watches
How to set time and date on kenneth cole watch model a126-03 rk5033
I had 2 problems:
1- my watch was stuck in 24hr time format.
2- I didn't know how to turn the alarm off.
Solution for issue #1 (switching between 24hr and 12hr time displays):
You press both the upper right and lower left button at the same time's
Solution for issue #2 (turning alarm on/off):
You press both the upper right and lower right button at the same time, twice.
Apr 14, 2011 | Kenneth Cole RK5034 REACTION
HOW DO I CHANGE MY WATCH FROM 24 HOUR MODE TO 12 HOUR MODE?
click on mode or setting option.then you will see the default time.edit it..try to change it using select or any mode available.there you can see 24hr clock and 12 hr clock.select which one you want.if it is in 12 hr then the time will be displaying like eg:7:00am or 7:00pm it means that it is in twelve hours.if it is showing 7:00 or 19:00 it means it is in 24hr clock.
Jan 29, 2011 | Casio W71-1V Wrist Watch
The 24 hour hand sticks at the 12 oclock posiion on my omega seamaster gmt every 24 hours the hour hand will not pass this position.
It sounds as though the 24hr hand is being obstructed, and that is also stopping the 12hr hand. Try to examine the face carefully for foreign objects (or bent hands). Unless you're very skilled with watches, I would suggest that you take it for repair. If the hands are sticking, gently pull out the crown ("winder") to stop the watch and prevent further damage.
Jul 19, 2010 | Omega Seamaster 2561.80 Wrist Watch
Kenneth Cole unlisted watch ul1052 s60
you need to go into menu or function settings for your watch after the time setting you shoud be able to scroll between 24hr and 12hr...or get your instructions from manufactor you can do this online you need your model and make..serial number should be on back of watch
Mar 24, 2010 | Watches
Coleman watch Model No. 40-328 How To change from 24 to 12 hour
I couldn't find the instructions for your watch but as watches tend to have similar operating characteristics, try this:-
Press the mode button until you come to a message that says something like "12hr" or "24hr" or something that indicates display change.
Then press one of the two buttons on the right to change to the display you require.
Some experimenting may be required!
Feb 01, 2010 | Watches
I cant Change it!!!
hello,to switch back and forth from 12 to 24hrs.:
push and hold lap/reset button and push the mode button,
an (A) will appear meaning it's in the 12hr zone,no (A) means 24hr.mode.
Aug 19, 2008 | Timex 1440 53591 Sports Quotient...
Timex 1440 Nylon watch Logo
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Brett Duxbury
Brett Duxbury
Vladimir Frolov
Are you a Timex Watch Expert? Answer questions, earn points and help others
