Question about Vacuums
How to take the bottom off to replace the belt on a Hoover Elite U5061-900
Http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=749807
Generic problem for all Vacuums
Posted by 4456 on Jul 07, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Some Hoover Elites have either screws or clips and the bottom plate should come off without a problems. Or if that is not the case then once you remove the screws then the top cover will come off and you can replace the belt from the top. If you have further questions please feel free to contact your local vacuum cleaner dealer in your area, or contact the Hoover website and or the cust serv phone # @ Hoover listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jul 07, 2008
How to replace belt for hoover elite vacuum
http://www.hoovervacuumbelts.net/
How to replace
Disconnect cleaner from electrical outlet.
1. Place handle in operating position and turn cleaner over.
2. To remove bottom plate, insert end of flat screwdriver into wide area of right-hand slot and push handle of screwdriver to the rear. Repeat in left-hand slot.
3. Lift extension of bottom plate, rotate plate and remove from
cleaner body.
4. Remove agitator and broken agitator belt. (If belt is not broken but is stretched or cut, proceed with steps 7-10 and pull belt off motor pulley. Then continue with step 5.)
5. Slip agitator through new belt (with lettering toward outside of cleaner) and position belt in belt guide. Push end of belt into
opening in cleaner body. Reposition agitator making sure to
align flat sides of projection on belt end of agitator with flat sides of slot in cleaner body.
6. Place the three tabs on bottom plate into slots in front of cleaner body. Snap bottom plate into place over agitator.
May 29, 2010 | Hoover Elite U5061-900 Bagged Upright...
I need to know how to install the belt on a hoover elite upright, #38528027
There are two snaps underneath to release the bottom plate. Next remove the top cover by gently prying off the base with a flat screwdriver. this will expose the belt. Install the new belt on the roller nd then push through the hole to attach to the motor shaft. reinstall the cover and bottom plate.
Jan 14, 2010 | Hoover Elite U5061-900 Bagged Upright...
Hoover elite how do i put the belt on
Here is the belt you need: Hoover U5061900 Belt
Simply turn the machine over and you will see (4) screws, remove them and you will be able to access of the belt.
Dec 14, 2009 | Hoover Elite U5061-900 Bagged Upright...
How do I change the belt on my Hoover Elite Dual Purpose Vacuum cleaner? The belt part # is 38528-027. Where is the motor pulley?
The hoover belt number you listed (38528027) has been changed by Hoover to 38528040. Below I have listed a link to the manual that has instructions and a link to the belt you need. Hope this helps!
Hoover Elite Manual
Hoover Elite Replacement Belts
Nov 02, 2009 | Hoover Elite U5061-900 Bagged Upright...
Hoover elite, model no. u4671-930
in the front on the bottom you will see 2 slots put a small screwdriver in and push up on the clips in the slots and the bottom cover will come off .be careful not to break the clips.just push up on the clip and pull out on the cover at the same time.before you replace the belt clean the old rubber off the motor shaft first ,if you don't the new belt won't last very long
Apr 29, 2009 | Hoover Elite U5061-900 Bagged Upright...
How do you change the belt on a Hoover Elite
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=704482
posted by Belle406 on Jun 25, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. the Hoover Elite belt change can be done from the bottom under the bottom plate by removing clips or screws and the bottom plate should come off and then you can get @ the belt. 1st, lift the brushroll out from the pulley end on the side – remove the belt and slide on the new belt and re-install the new belt on the pulley side. Then use a belt puller or a screwdriver that may or may not have a hook or bend on the end and then stretch the belt onto the motor pulley and the track the belt in a straight line, then /2 that time replace the bottom plate. If you cannot get @ the belt from the bottom, then the top cover will come off and use the steps above.
8 a.m. - 7 p.m. EST
Go Ahead. Use Us.
Jun 25, 2008 | Vacuums
Hoover u5227-930 Elite Upright
I figured it out! The key is removing the "head" that covers the headlight - use a flathead screwdriver to pop it off.....then the belt connects from the agitator to the motor pulley. Phew!
Jan 20, 2008 | Hoover U5227-930 Elite Upright Vacuum
How to change a Hoover Elite sweeper belt
on the bottom there should be a few screws take them out and a cover should come off the belt is right there. hope this helps
Dec 18, 2007 | Hoover Elite U5061-900 Bagged Upright...
Replace the belt
on the bottom there is a few screws remove cover and there is a roller brush there and the rest should be self explanitory
Oct 16, 2007 | Hoover U5227-930 Elite Upright Vacuum
Vacuums Logo
113 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
