First I want you to download Hardware Monitor v1.17 from CPUID. I have a Zotac GTS450 and it gets to about 82 degrees Celcius under heavy load with no problems; and 36 degrees Celcius at idle, with this I need you to see how hot your card gets before it freezes. If it is higher than 82 during gameplay then it may just be the case that it is getting too hot. Do you have sufficient fans in your case? I would also suggest a clean out of the system to get out any dust as dust can cause an increase in heat levels.
