Question about Carrier Heating & Cooling
I have a rooftop that when it runs the suction presure is in a vacuum and the high side is 150 p.s.i.
  • 182 Answers
Restriction.
Posted on Jul 07, 2008
Stanley 3.5 wet/dry vacuum motor runs but suddenly suction stopped just like it does when tipped over, but didn't tip over
ck ball that saves the motor when container gets full of water , they sometimes get stuck inside the little cage there in an shut off suction
Jan 19, 2016 | Stanley 3.5-Gal. Wet/Dry Vacuum
Where is low side of air conditoner
There are 2 lines coming from the firewall on any vehicle that has ac. One is the high presure the other is the low presure. Follow each line until you find fill valve.
This valve is used to fill the system. It will be covered by a plastic cap that screws on. Each side, the high and low has one of these valves. Often the cap is labeled with an "L" for low or "H" for high. Another way to tell is to flip the caps upside down. The low presure side will always be the smaller of the 2.
Jul 05, 2014 | 2006 Ford F-150
Low side presure to high.high dude presure to low 75/150
Most likely have a leak to find & repair
The system is low on refrigerant
Do not add to it,have a shop work on it
Sep 07, 2013 | Cars & Trucks
Need pichers of a 82 ford f150 vacuum diagran 4speed 300eng
change vacuum presure hoses, check for leak, repalce aternator vacuum passage.
Mar 03, 2013 | 1982 Ford F 150
Low side psi 150 high side 165 on a watersource
Sounds like a weak suction valve on compressor.How old & what refergrant?
Mar 16, 2010 | Comfort-Aire RAD-81 Air Conditioner
I installed a 2 hp high head pump on a waterfall and the amps are running about 16 when I start closing the discharge side of the pump the amps come down where they are suppose to it is going out on...
make sure your wireing is up to the job and your back presure at the pump discharge is within limits. both of these should be in your pump book that comes with your pump. If you don't have one you should be able to look it up on-line or order one from Pentair.
Aug 15, 2009 | Pentair Challenger High Head 1.5 Hp Pump...
No suction
You have a clog somewhere in the vacuum. Check the hose and the little trap door on the underneath side of sweeper.
Does the brush turn? If not, then the belt that drives the brush is broken. Replace the belt
Jim
Jun 08, 2009 | Hoover Tempo Widepath Upright Vacuum -...
Operating pressures for 134A refrigerant system
I would go for 40 on the suction and 150 discharge, or divide the locked rotor current by 6 and charge so the current is 1/6 of the locked rotor current of the compressor, or by temperature/pressure relation 110* discharge and 35* suction, or get the suction line sweating. The best way is to remove all the refrigerant and then weigh the refrigerant the system is designed for on these critical charge appliances.
May 20, 2009 | Amana 22.6 cu. ft. Side-By-Side...
How to put refrigerant in Demotic RV Rooftop Air Conditioner
You will need to add a self tapping port to the suction side of the unit. You will have to determine what the size of the pipe is and then go to a local a/c supply company and buy one. It's kind of like a self tapping supply for water but for high pressure. Hope this helps. I would also put one in on the high side as well so you don't blow the valve in the compressor if you over charge it or the system is dirty.
Apr 08, 2009 | Dometic Rooftop RV Air Conditioner
Hayward Northstar 3 HP pump for waterfall too noisy
Did you put the slip ring in with the wide end out? This slides foreward when the pump runs and seals the presure side of the impeller from the suction side. If this is not right it can create a lot of cavation noise. I don't know how long this has been a problem but if you just put this in a 3hp pump is a lot and will need a 3" suction on most runs and at least 2.5" on the presure side depending on the run. I hope this helps.
Oct 23, 2008 | Hayward Northstar Dual Speed Max Rate 2 Hp...
Heating & Cooling Logo
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
