Memory i need a pc2-4200 ddr2 sdram dimm for my desktop. Would a Optima 1GB PC2-5300 DDR2 DIMM work???
    Sergeant:
    Novelist:
  • 166 Answers
Hello there.
Yes you can mix different speeds of DDR2 memory, please be aware that if you mix a higher speed with a lower speed, the higher speed memory will only run at the slower speed.
Hope this helps.
Posted on Jul 07, 2008
  • 23 Answers
No. You will be able to use RAM hardware of the same brand and series, though. the Optima product you listed is hardware that increases your computer's Hard Drive memory.
What is the max size of ddr400 memory you can fit into ddr1 & ddr2 dimm slots on a p4vm8 mother board
1) Total maximum amount for motherboard is 2GB.
2) There are 2 Ram Memory slots.
3) Maximum amount for EACH ram memory slot is 1GB.
Either DDR Sdram at 266MegaHertz, or 333MHz, or 400MHz.
PC2100, PC2700, and PC3200, respectively.
http://www.asrock.com/mb/VIA/P4VM8/
There is no DDR1 and DDR2 slots, in a manner of speaking.
May be marked on your motherboard that way, but stating it that way on a computer product support website = No.
You're going to make someone think, you don't know what you are talking about.
They may think you are referring to DDR Sdram, and DDR2 Sdram, and they know the motherboard only uses DDR Sdram ram memory.
Suggest state Slot 1 and Slot 2; or DIMM 1 and DIMM 2.
For additional questions please post in a Comment.
Regards,
joecoolvette
Mar 18, 2013 | VIA ASRock P4VM8 P4(S478)/...
I bought a new 1GB ram(DD2) when i insert it it nt work bt whenever i insert it with old 512MB ram then its work bt in bios setting only show the 1GB ram
Maybe 1GB is the maximum amount of memory that your system will hold. And maybe your system likes memory to be in pairs, so when you put the 1GB in by itself it didn't work, but when you put it in with a 512MB it works.
May 18, 2012 | Computers & Internet
Can I upgrade my acer 5315 memory to 2GB with two 1GBs in two slots or I can put two 2GB slots adding up to 4GB? Thanks
You can upgrade it to 2GB (MAX) if icon_detail.gifMemory Type: DDR2 PC2-5300, DDR2 (non-ECC)
Maximum Memory: 2GB
Slots: 2
Each memory slot can hold DDR2 PC2-5300 with a maximum of 1GB per slot.
Hope this helps.
Jun 17, 2011 | Acer Aspire 5315 Notebook
IN COMPAQ DL380G4 I HV SOME TECHNICAL PROBLEM WHEN I INSERT MEM PC2-3200R-333 THEIR IS NO DISPLAY . WHEN I REMOVED MEM I AM GETTING MEM BEEPS PLS REVERT BACK ASASP
Use below mentioned memories.
1GB of Advanced PC2 PC3200 DDR2 SDRAM DIMM Memory Kit (2 x 512 MB)
343055-B21
2GB of Advanced PC2 PC3200 DDR2 SDRAM DIMM Memory Kit (2x1024 MB)
343056-B21
4GB of Advanced PC2 PC3200 DDR2 SDRAM DIMM Memory Kit (2x 2048 MB)
343057-B21
May 18, 2011 | HP Compaq ProLiant DL380 G4 Server
I want to upgrade my system ram size to 2gb...my system memory configuration as follows mother board: intel102ggc2 system bus speed :800mhz processor (p4):3.0ghz ram slots available:2 and presently i'm...
The below is the contents of Intel published for your board
Intel Desktop Board D102GGC2 Technical Product Specification
System Memory The board has two 240-pin DIMM sockets and supports the following memory features: • 1.8 V (only) DDR2 SDRAM DIMMs with gold-plated contacts • Unbuffered, single-sided or double-sided DIMMs with the following restriction: Double-sided DIMMS with x16 organization are not supported. • 2 GB maximum total system memory. • Minimum total system memory: 128 MB • Non-ECC DIMMs • Serial Presence Detect • DDR2 533 or DDR2 400 MHz SDRAM DIMM
hope it helps, if so rate the solution
Nov 16, 2010 | Intel D102GGC2 Motherboard
Will 1gb ddr2 800mhz ram support intel102ggc2
  • Unbuffered, single-sided or double-sided DIMMs with the following restriction: Double-sided DIMMs with x16 organization are not supported.
  • Non-ECC DIMMs
  • DDR2 533 or DDR2 400 SDRAM DIMMs
Note
To be fully compliant with all applicable DDR SDRAM memory specifications, the board should be populated with DIMMs that support the Serial Presence Detect (SPD) data structure. This allows the BIOS to read the SPD data and program the chipset to accurately configure memory settings for optimum performance. If non-SPD memory is installed, the BIOS will attempt to correctly configure the memory settings, but performance and reliability may be impacted or the DIMMs may not function under the determined frequency.
May 27, 2010 | Intel D102GGC2 Motherboard
Will Intel D102 Series Motherboard support Transcend 1 GB DDR2 667 Mhz RAM. Please confirm
According to Intel, this board will support a maximum of 2 x 1GB PC2-4200 533MHz Memory Modules, so your PC2-5300 667MHz Ram may not work.
Intel® Desktop Board D102GGC2 - System Memory Features:
Non-ECC DIMMs
Jan 12, 2010 | Intel D102GGC2 Motherboard
Can i connect one two 667mhz rams in INTEL D102GGC2 mother board?
Memory Two 240-pin DDR2 SDRAM Dual Inline Memory Module (DIMM) sockets Support for DDR2 533MHz and DDR2 400MHz DIMMs Support for up to 2GB of system memory
hope helpfull
May 29, 2009 | Intel D102GGC2 Motherboard
Ram issue with compaq presario 5000 G1 Series
as you can see from the information below there are different requirements for RAM to work stable in your system . Most importand are the RAM VOLTAGE , SPEED , and Configuration of chips. you will need to consult the manual for qualified RAM requirements. Some RAM will work but not very stable. make sure the voltage supplied by your system is enough for the RAM. If you are running DDR RAM in dual channel mode, the ram needs to be the same size also. DIMM modules for the HP computer must meet the following requirements
  • The number of pins on the DIMM must match the socket type.
  • DDR memory requires a 184-pin slot and 1.8 operating voltage.
  • DDR2 memory is not compatible with DDR1 memory and requires a 240-pin slot and 2.5 operating voltage.
  • Synchronous dynamic random access memory (SDRAM): Only use DDR type SDRAM memory if the computer came with DDR-SDRAM.
  • SO-DIMM modules for the HP computer must meet the following requirements
    • SO-DIMM memory requires a 200-pin slot.
    • DDR2 SO-DIMMs are not compatible with DDR1 DIMM and DDR2 DIMM memory modules.
    • With a computer running at a system bus of 533 MHz or 667 MHz, use a PC2-4200 (DDR2 DIMM 533) type.
    • The following requirements must be met for the DDR memory to function in dual channel mode:
      • Same density (256MB, 512MB, etc.)
      • Same DRAM chip technology (x8 or x16)
      • All either single-sided or dual-sided
      • Matched in both Channel A and Channel B memory channels
Oct 22, 2008 | Compaq Presario 5000 PC Desktop
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
