Sony projection tv has a curved distourted display and the colors are all shadowing each other. Would clear up before after a few hours of unit being on. Now it stays distourted.
  • sonygary Jul 07, 2008
    KP57WS500
    KP57WS500
  • 8,617 Answers
You need to replace your convergence IC Most sonys use STK392-560 ICs but please respond to this same post with your model number and I can tell you for sure as well as where to get replacements with free instalation instructions
Posted on Jul 07, 2008
  • Sonny Berry
    Sonny Berry Jul 07, 2008
    Yes that model uses two STK392-560 ICs you will most likely need a couple 4.7 ohm 1/2watt metal film resistors also. You can get the replacement ICs and resistors at the following link and they provide instalation instructions and free online tech support when youre doing the actual replacement. Here is the link.
    http://servicemanuals.vstore.ca/
I have a 8 year old 57in Sony projection HDTV,when the picture is dark you can see faint blue lines in a curved arch like pattern across the screen.Any ideas? Thanks
The tv problems is call a convergence picture problems,it is just starting to developing.This problems when it is fully developing into a convergence picture problems to the tv eventually.Tv will develope into a colors lines R,G,B mis alignments,have a colors shadow pictures or into a picture 3D look alike.Eventually the tv convergence board will dies,have to have it parts replaced like 2 STK convergence ICS and some or all of it resistors too.This problems the tvs shops will cost u like $300-350 for parts and lobors.
Aug 13, 2011 | Sony KP-57WS500 57" Rear Projection...
I have a Phillips 60" rear projection TV. recently
Tv have a problems known as a convergence problems,it is dead.The tv convergence board it is dead,that why ur tv picture are R,G,B colors lines mis alignments,have colors shadows picture or 3D picture lood alike?The tv convergence board require changes 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop will cost u like $300-350 for parts and labors.
Jun 01, 2011 | Philips Televison & Video
Picture is greenish / purplish and curved lines at top & bottom of screen. definitely not an input issue, distortion is the same on all inputs and even on the menu/settings...
Very common problem throught out ur DLP tv live,will happen again again many times for the tv life times.Ur tv have a problems known as convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts must be replaced on the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 05, 2011 | Sony KP-65WV700 65" Rear Projection HDTV
The picture looks 3D and kind of curving in
The tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignments,have pictures colors shadows or have a 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to solved the tv convergence pictures problems.The shop,will cost u like $300-350 for parts and labors.
Nov 23, 2010 | Sony KP-57WS510 57" Rear Projection HDTV
Blue screen for about a half hour and then still blueish color
Tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D look pictures.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts,must be replaced on the tv convergence board to solved the tv convergencce picture problems.The shop,will cost u $300-350 for parts and labors.
Oct 20, 2010 | Sony KP-65WV700 65" Rear Projection HDTV
SONY PROJECTION TV MODEL # KP-51WS510.
If the entire screen is curved, and it is not taking the whole screen, then you have a vertical deflection problem.
If the colors are double and do not match, with lines of different colors around pictures , then you have a convergence problem, often caused by a faulty convergence board.
The curving effect can be a side effect of bad convergence, or you may have both problems at once.
Unless you are a TV repairer yourself, better calling technical support. Usually you can ring the number listed on the owner manual.
Jul 21, 2009 | RCA P52920BL 52" Rear Projection...
Picture is curved like an hour glass
that a pincushion problem likely caused by a failed capacitor
Mar 26, 2009 | RCA Televison & Video
Picture is multi color, double shadows, curved
This is failure of convergence out ICs in TV. Qualified TV tech will replace convergence out ICs or board.
Feb 14, 2009 | Philips Televison & Video
Convergence issue resolved but concave picture remains
Set will need new convergence IC's.Requires chassis pull===technical & mechanical skill mandatory.After repair,re-aligment necessary.
Sep 26, 2007 | Philips 55PW9363 55" Rear Projection...
Televison & Video Logo
128 people viewed this question
Top Televison & Video Experts
Electro Med Services...
