Question about Panasonic SC-PT1050 System
Sub woofer We had the unit in service 3 times and they can't find anything wrong with it inside. Do you think it could be some kind of power or hydro problem when we bring it home and it acts up again. I plugged it into an extension cord instead of the wall this time and it seems to work the whole evening, when usually it would have kicked out by now.
    Genius:
  • Panasonic Master
  • 1,689 Answers
It is possible, but very rare that I have seen this, the unit's AC plug is not making good contact in to the wall socket. The extension cord's AC plug may be making better contact to the wall socket, and the socket on the extension cord is making better contact to the unit's AC plug. It could be something this simple.
In my mind however, I sort of think that there is a very intermittent fault, and it does not show up too easily. Sometimes moving a device can disturb it in such a way that its fault may not show up (fault gets to be masked). The fault may come back to haunt you. Time will tell which scenario is the right one.
Jerry G.
Posted on Jul 07, 2008
It stopped pulling today , only 128 hours on it. Transmission bypass levers are in proper position! Is there anything else that can stop it in its tracks like this?
You did not mention if it was both sides that quit or just one. If it is both sides then the only thing they have in common is the belt and tightener other then that they are two totally separate units.
If it was one side only then I would be checking the plastic fan on the pulley on top of the side that quit. It is a 7 inch 10 blade plastic fan.When it breaks or most of the fins fly off it does not cool the oil inside of it, there is only 1 3/4 quart inside. With time off getting hot it will condensate on the inside and make the 20w50 motor oil watery and it will foam and load the system with air and it stops pulling. The transmission will need to be removed to replace the fan blade. There is 5 bolts and 3 wire clips. I would strongly encourage you to remove the filler plug and dump out that oil and replace with new. I have two of thease mowers and can take the drive unit out in about a hour. http://www.outdoordistributors.com/pdf/hydro-gear/zc-zd_service_manual.pdf Genuine Hydro Gear FAN 7 0 BLADE HYG 53050
May 29, 2016 | Cub Cadet Riding Lawn Garden Zero Turn...
Why does on my hydro rain timer it says power off when its still plugged in? non of the sprinklers go on
Hi
Diconnect all power to unit this allows the unit to reset includes battery .After reset check/you may have a shrt circurt in the systen
Aug 19, 2014 | Orbit Hydro-Rain HRM-100-03-BD HRM 100...
When I turn on my Kyocera phone it freezes when it's turning on
Are you able to use it all? Is it turning on? *by the way, I just replaced my Hydro today..Anyway, You need to delete emails, texts and apps, clear up some space. I had to do that several times. Today I got tired of it and bought another kind of phone.
Mar 05, 2014 | Boost Mobile Kyocera Hydro Smartphone
I have a 18000btu LG mini split heat pump installed about 1 year ago in vacation home. In heat mode the unit cycles on and off when room temp is within 2-3 degrees of set point. Cycle on time varies...
Hello.I think they are on to something with shortcycling on temp sensor.I think it should be sampling the return air instead of (inside coils ?).A 2*f dead band use to be built in (factory installed) to thermostats to prevent on/off, but not sure in this case.Try a new sensor location(return air) and see if anything changes.
Oct 26, 2010 | LG LS-L1210CL Mini Split Air Conditioner
Whend i puch the brake pedal make a noise like a cow
This is your hydro boost unit, it runs with assistance of your power steering pump.Check your power steering fluid level, if it's low then top it off.If not then it's time to replace that hydro boost unit.Any other questions get back to me..Thx
Dec 22, 2009 | 1998 Chevrolet Tahoe
New ink and power to printer, but will not print on paper
how about the program or driver is installed properly? if installed properly open it then check the board of printer maybe it has something wrong inside why not printing..
Sep 14, 2009 | Canon MultiPASS MP370 All-In-One InkJet...
My phone is actually blocked
Your phone gets locked. So you can't make calls other than emergency calls. I think, you(or someone) incorrectly attempted the wrong code many times. Hence, go to your phone service center, there will reinstall the software. Kindly revert to me if you have any clarifications.
Regards,
Dharan
Jan 05, 2009 | LG Shine KE970 Cellular Phone
Unit turns off after 3 seconds
sir i think theres something wrong with the power supply kindly check it out thanks and hope too help you,,,gud luck
Feb 26, 2008 | Mitsubishi VS-45607 45" Rear Projection...
POWER LIGHT BLINKS 5 TIMES
That's the LA-3 LCD projection unit. 5 blinks on that model means a lamp driver error. You would need the service manual to diagnose exactly whats wrong with the system. I have included a link where you can get the entire 121 page service manual for your set if you would like it. It cost 15.99 and they will email it to you and provide free support to help you diagnose it. Here is the link if you would like the service manual.
http://servicemanuals.vstore.ca/
Feb 24, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Panasonic SC-PT1050 System Logo
65 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
