What driver do the qsc 153i take - Audio Players & Recorders
  • 1,512 Answers
Hi squirtipower
Here is an exploded view and parts list to identify the driver.
Posted on Jul 07, 2008
How to hook a qsc rmx 850 to a numark cm100 mixer
The output of the mixer goes to the input opf the QSC rmx850.
Aug 14, 2014 | QSC Audio Players & Recorders
Qsc hpr153i rattle
Please specify a bit more, does the rattle is physical(Enclosure structure) or electronically hear thru speaker(Power Amp Common Issue)? I have the solution for the amp issue, let me know.
Mar 20, 2013 | QSC Audio Products QSC HPR153I 12 SPEAKER
Not putting out sound fan on light on
A common issue with the QSC RMX series amp is faulty volume pots, so i would recommend go this way first of all, let me know a bit more to improve help.
Feb 04, 2013 | QSC Audio Products QSC RMX 850 RMX850...
Qsc hpr181i blow fuse
Two possibilities here, one is a cracked pin on one of the power supply UF diodes and the other one that the power output devices got fried.
Jan 30, 2013 | QSC Audio Products QSC HPR 181i
How do I bridge my QSC GX 3 amp to run one speaker cabinet?
For QSC amps the GX series are not bridgeable. You will have to run one speaker to each channel.
Mar 22, 2011 | QSC GX3 Amplifier
MAckie 1604 VLZ Pro Mixer, running QSC 1850 with jbl's from main outs. I would like to hook up powered subwoofers. What is the correct pathway?
The best way is to use a two-way crossover between the mixer and the amplifiers. In your case, the low output from teh crossover would go to the powered subs, the highs to the QSC. Use the crossover adjustment to set the frequency crossover point to get the sound quality you require.
Mackie 1604 ---> Crossover --- Highs ---> QSC --->Speakers
-----> Crossover --- Lows ---> Powered Subs.
Jan 27, 2011 | Mackie 1604 Vlz3 16 Channel Mixer
Qsc mx 2000a left channel go into protek mode
Does it do it with nothing connected to the inputs and outputs? If yes, something internal.. anything loose in there (is it moved alot and something could have fallen inside of it)
Mar 28, 2010 | QSC MX1500A 2-Channel Amplifier
I have qsc amp model noisa500it 2nd channel is not working i replased the fuse and 2sc5200 and 2sa1943 everthing get shorted
It is likely that additional components were damaged when the output transistors (2SC5200, 2SA1943) were shorted. Check the driver transistors which preceed the outputs in the circuit as well as resistors in the area. Also, there should be a bias transistor mounted on the heat sink that needs to be checked as well.
Keep us posted,
Mar 02, 2010 | QSC Audio Players & Recorders
QSC ISA 280 Stereo Power Amp stopped working
This is a very precise questions as QSC amp are pretty rare and high end electronics equipment. There is no way getting an answer other than getting the amp at a sound shop for repair, wich might go for a visit at QSC anyway. From a sound shop repairman...
Sep 07, 2009 | QSC ISA 300Ti Amplifier
37 people viewed this question
