Question about Coleman Heating & Cooling
My air conditioning doesn't seem to be cooling
  • 182 Answers
That's a bit vague.Start with checking your filter.
Posted on Jul 07, 2008
Do I need to put air conditioning in my dog house? It seems kind of extravagant.
It depends where you live, but if you live in a hot climate and suffer from the heat yourself (and use air con to cool yourself down), the chances are that your dog is suffering too. The dog house provides some shade but it doesn't help humidity and really hot temperatures.
Aug 22, 2012 | Dogs
Lg air condition doesn't work when it is cold outside
Sounds like the crankcase heater. This is likely hooked to a temp sensor that is activated when it gets below a certain temp. There is likely a short in the heater and it trips the breaker. The heater keeps the refrigerant warm inside the compressor when compressor not running. Find a different technician.
May 19, 2017 | LG Heating & Cooling
I bought Air condition today(Haier 8000 BTU) I install my living room but it doesn't cool it,the setting is Cooling and high,please help me before I return it.
I would take it abck. Iknow its not the answer you want to hear but it might save you a lot of heart ache in the future
Jul 19, 2011 | Haier Heating & Cooling
My air conditioning united seems to be blowing cold air, but its not cooling down my room? Plus the temperature reading never lowers. Thank you in advance.
Sounds like the rear coil may be stopped up with dirt, etc. If it is, the unit will not cool properly. You may just be able to unplug it and wash it out with a hose and sprayer from the back of the unit. If its real dirty, you will have to pull the unit out of the window, take the case off and clean it real good. If you wash it out from the back, be sure you can do it when you can leave the unit off for an hour to dry. Let me know if I can help you any more of if this doesn't work. Stay cool. mark
Jul 10, 2011 | Haier HWR05XC7 Wall/Window Air Conditioner
My AC doesn't seem to be as cool as usual ive checked the pressure ( 100 and 30 )but i cant find what normal is. the model # on my unit is 561cj048-f
Hello, if the high side pressure iS 100 and low side 30, then the unit is undercharged. Im assuming this is a R-22 unit. Typically your low side should be between 65-70 psig and high side should be between 220-230 under normal conditions.
Jul 08, 2011 | Bryant Heating & Cooling
The thermostat works fine for heat, but as soon as I switch it to cool, the air conditioning will kick is but the inside thermostat will not change, causing the air conditioner to run continuously
If the temperature doesn't drop when the air conditioning is running for some time (two hours), the air conditioner is not working. The problem is not in the thermostat.
Gary
Jun 14, 2011 | Honeywell CT500 Digital Heat / Cool Manual...
I have a 2005 Hyundai Elantra with an air conditioning problem. The air conditioner works intermittently. As far as I can tell, it works well on extended trips that involve highway driving, but works...
You describe a typical 'cooling fan' problem. When moving through the air, the AC operates normally, but when stopped in traffic, it doesn't... correct?
Jun 11, 2011 | 2005 Hyundai Elantra
My Sanyo KS1211W split air conditioning unit does not cool
u r compressor is not functioning,sure u need the service technician
May 17, 2009 | Heating & Cooling
Heating & Cooling Logo
66 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
