Question about Linksys Wireless-G WPS54G Print Server
Upgrade failure When I try to install my new WPS54g print server, on a Vista Business system, I go through the connection steps, the computer it finds the print server wirelessly, but then when I click next it says UPGRADE FAILED. And I can't make it print. Have searched the net but suggested solutions haven't worked.
  • montgome Jul 09, 2008
    I am grateful for your response. Unfortunately, I am unsure of the meaning of th following sentence:
    "Make sure PrintServer is configured on the network with the same wireless settings of your router and with a manually assigned IP address which is in range of the router's IP segment."
    I understand what an IP adress is, but I'm confused about the phrase:
    "which is in range of the router's IP segment."
    Sorry to be such a novice
  • 52 Answers
The software that came with the WPS54G model is not (yet)compatible with Vista systems. This model is not listed on the Vista-ready devices from Linksys' website ( The behavior more likely a result of a software incompatibility.
For PrintServer network setup, you may still use the CD on a non-Vista system (XP, Win2000 or lower). Or, by installing it manually by accessing it's web interface.
To make your Vista working with the printserver WITHOUT the use of the PrintServer CD, do the ff:
1. Make sure PrintServer is configured on the network with the same wireless settings of your router and with a manually assigned IP address which is in range of the router's IP segment.
2. Make sure that computer can print locally to the printer (e.g. via USB connection to the printer).
3. When computer can surf the net and connected to the router's network (wired or wireless), follow the steps from this article and make sure Printer is showing up as Online.
Posted on Jul 09, 2008
I lost my setup disk and I want to install on my new laptop
You can download the drivers for the WPS54G for the following link. You can run on your new laptop onwards to install it.
Remember that this is used to upgrade the firmware of the device. The link is as:
Mar 12, 2011 | Linksys Wireless-G WPS54G Print Server
WPS54G Printer Server Setup
I bought a Linksys Wireless-G WPS54G printer server and trie to put it in my home network. Following the instruction from the manufacturer and spent many hours, I still couldn't make the printer server work. There was no problem to get the IP address from my DHCP server using the wired connection. But when I pulled off the network cable and tried the wireless connection, I got "connection failed" error at the last step to install the printer server. I checked my router's client monitor and found the printer server did get the dynamic IP address wirelessly. When I pinged that IP address, there was no response at all from the printer server. In another word, the printer server couldn't communicate with other devices in wireless mode in the network. I searched the Internet and found there were many users had same problem and couldn't resolve the issue even from the manufacturer technical support. As a last resort before I was going to send back the printer server, I switched the network router to one of a different brand. My previous router was manufactured by BUFALLO INC and the new one was made by D-Link. After I rerun the installation following the instruction, the "connection failed" error was gone. The printer server could work finally.
The tip here is: Try a different brand router when there is a connection failure problem for installing the WPS54G printer server, if possible.
on Mar 02, 2008 | Linksys Wireless-G WPS54G Print Server
I purchased a print server model: WPS54G. I have misplaced the set up CD. We have now two more computers in the house with the children having computers. I have misplaced the installation CD. Is there...
Manuals and software can be downloaded from:
Then they could be easily burned to disc if you'd like a backup. Hope this helps!
Feb 19, 2011 | Linksys Wireless-G WPS54G Print Server
WPS54G should work with the VISTA also.
But the disc will not run on the VISTA.
What you can do , you can set up the printer manually.
Once you are able to set up the print server with the router.
You will need to add printer port on the computer.
Click Here to know step by step solution.
Oct 25, 2009 | Linksys Wireless-G WPS54G Print Server
Linksys Wireless G Print Server set up
Hardwire the wps54g to the router and disable all firewall installed on the compute.
Sep 07, 2009 | Linksys Wireless-G WPS54G Print Server
I have a new computer than I'm trying to install the drivers for a Linksys wps54g and I'm having problems.
unplugged the outlet from the modem , and the router ,than plug the inetrnet wire from the modem to the router,and than you install the cd from the router ,plug every thing back in to the outlet , and restart pc
Aug 04, 2009 | Linksys Wireless-G WPS54G Print Server
Linksys WPSM54G No Device
Do a reset on the print server. To do this, hold in the reset button on the back, unplug, then plug in and continue to hold for 10 seconds. Your setup should now detect the print server
Nov 11, 2008 | Linksys Wireless-G WPS54G Print Server
Linksys WPS54G
Hi Scott.
Make sure your firewall is set on the Vista to allow the network discovery. Follow this link, click on Networking>File and printer sharing. It will tell you how to setup Vista to work with printer
This link should help, too. It is just for your Printe server.
Good Luck!
Jan 05, 2008 | D-Link DP 300U (DP-300U) Print Server
Linksys Wireless-G WPS54G Print Server Logo
326 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
