Question about Kenwood KM305 Stand Mixer
Kenwood Mixer A702
I am having a problem with my mixer. The nut will not stay tight where the beater goes in. When you turn on the mixer it won't rotate. I think I might need new gears. I bought this mixer in 1982. Can you help me find parts for it?
  • starman587 Feb 22, 2009
    Hi,I have a Kenwood A701A with two problems. First, the spindle on the base of the blender unit is broken and I need a new one, and second, the mixer arm(?) has no torque or strength in it so that it only goes around if there is no resistance. Are there gears or a belt broken? Can I fix it/get it fixed? I live in Dublin, Ireland.Thank you,Alan.
  • 515 Answers
There are not any new parts from Kenwood to A700 series, try to find it on internet or if anyone in the forum has one.
Posted on Jul 12, 2008
  • Mirko Blas
    Mirko Blas Jul 12, 2008
    Forget to tell that i have number to agents that still support A700 series, tell me where you are from then i can get a phone number for you.
Repair Hand Mixer
the head gears are not engaging properly
could be the selector knob or stripped gears
get a quote from an appliance repair shop but if the mixer has a few years on ti then it will probably turn out cheaper to get a new one
Feb 25, 2016 | Kenwood Food Mixers
Cannot remove the flexi beater
I have read on other posts that it is the nut at the top of the beater that is causing the problem. You need to rotate it downwards toward the beater in order to have sufficient room to push and rotate the beater out. This didn't work for me, nor did attempting to remove the whole plate by undoing the lug beside the beater insert. Now that I have worn the lug and the nut I cannot get it repaired at a Kenwood service specialist as I have attempted the repair myself.
My advice is to go straight to a professional. Whatever they charge it will be cheaper than being stuck with a machine you can only use some of the time and have to replace!
Dec 31, 2012 | Kenwood KM400 / KM410 Chef Classic Stand...
I just got a Kenwood A702, no instruction manual. I can't figure out how to get the beater to stay in. Help
try going to the support section on there website it should have quite a few documents including the instruction manual
Aug 09, 2012 | Kenwood Food Mixers
Kitchen aid khm3wh beaters will not stay in mixer
I fixed mine (my wife's). Kitchenaid 3-Speed Hand Mixer KHM3WH. Here's how I did it.
This is a pretty old mixer. My wife bought it at a thrift store for $1. She brought it home, we found the beaters and whisk beaters on eBay. Paid $34.00 for both sets of beaters, but when we received them we found they would not stay in the mixer. Oh we also bought the alternative/replacement beaters from Sears, parts online. I don't think those will work with my fix. However with some $0.92 rubber washers from Lowe's and a heavy duty paperclip I fixed the mixer, and it works flawlessly. Maybe some stainless steel wire would be a better, more permanent fix.
Apr 30, 2012 | KitchenAid KHM3 Classic Hand Mixer
I have Kenwood Major Classic (Grey colour) will a mincer A720
Hi. I've checked the Kenwood Service website and from what it looks like, A720 mincer is only suitable for A701, A701A, A702, and for Major models A707, A707A, A717.
The mincer specified for the KM800 (from it's owners manual) is the
A950.
May 20, 2010 | Kenwood KM800 Major Classic Stand Mixer
Can't remove beater kmix from machine. it's stuck!kenwood
Here's how to fix the stuck implement problem:
The implements each have adjustable heights. to adjust the height you need to loosen the bolt at the top with a 14mm spanner. If the bolt was loose when it was being used then it can get too short and not leave enough clearance between the bolt and the machine in order to push up and turn to release the implement. If this happens take the open ended spanner, grasp the implement and rotate the spanner clockwise (when looking up at the machine from below. Once the nut is loose rotate the implement until there is enough clearance to remove it normally.
Jun 05, 2009 | Kenwood KM300 Chef Stand Mixer
Kenwood Chef A702 mixer stopped running
You should sell it for parts on eBay. You may not get much, but anyone willing to pay for shipping will appreciate whatever parts are still working.
Apr 10, 2009 | Kenwood Food Mixers
K-beater is stuck on our Kenwood Chef and we can't remove it
I couldn't remove the K-Beater as when I tried to turn it the whole mechanism turned with it. I couldn't even remove the splashguard! I was going to take it to the Kenwood factory (a few miles from home) but then I thought I'd give it one more go and this is what I did...
  1. Next to where the K-Beater attaches in the middle of the circular plate is a lug with a pointed-shape bolt on the end. Remove this with a spanner and the beater plus gear cog can be removed.
  2. Place some mole grips or wide pliers on a worktop and sit the cogged gear in to it and grip so that it won't turn.
  3. Now you should be able to remove the K-Beater!
Perhaps someone can suggest how to stop it happening again. I haven't attached anything since but will update this post if I have any other helpful tips.
Feb 15, 2009 | Kenwood KM400 / KM410 Chef Classic Stand...
New Kenwood chef km 001 - I can't get the beaters out!
Try turning the beater in the reverse direction to the direction it normally turns - clockwise looking at the beater (I think), this should make the shaft pins ride up on some cams which should release the beater.
Sep 23, 2008 | Kenwood KM800 Major Classic Stand Mixer
Beaters fall down
You have to change the planet hub and the beater.
Nov 06, 2007 | Kenwood KM800 Major Classic Stand Mixer
Kenwood KM305 Stand Mixer Logo
425 people viewed this question
Top Kenwood Food Mixers Experts
ashburton
jason
Are you a Kenwood Food Mixer Expert? Answer questions, earn points and help others
