Question about Whirlpool ED2FHEXN Side by Side Refrigerator
Whirlpool water dispenser
My water dispenser dispenses warm water. Why isn't it cold. This is a new refrigerator.
  • 943 Answers
Hi thanks for the question was a new line installed on your new fridge for the water . if so the installer installed the water line to the hot . not the cold check that the appliance doc
Posted on Sep 28, 2008
  • 126 Answers
IS THE FRIDGE OMPARTMENT COLD ENOUGH AS THE TANK THAT HOLDS THE WATER IS LOCATED IN THE FRIDGE COMPARTMENT.PLEASE FEEL FREE TO ASK MORE ADVICE.MOHAMED
Posted on Sep 17, 2008
2 Suggested Answers
CMV9
  • 594 Answers
SOURCE: Warm water out of water dispenser
If this is a new hook-up please be sure that your water line is connected to the cold plumbing on the house and not the hot.
IF it is on the hot the fridge is cooling it down to warm.
Please let me know if this helps you.
Posted on Jan 06, 2009
The water dispenser dispenses water, but the water is warm...? The refrigerator and freezer work perfectly.
the refrigerator is what cools the water so if that working than the water should be somewhat cold unless you dispense a lot of it. Otherwise its a bad design by the manufacturer.
Sep 19, 2016 | Hotpoint Refrigerators
Water coming from new refrigerator water dispenser is not cold
CHECK TO SEE IF THE DRAIN LINE IS CONNECTED TO THE PAN BEHIND THE KICK PLATE. I would offer a diagram but I'm in search for one myself.
Jun 16, 2009 | Refrigerators
The water from my water dispenser isn't cold.
Hi, Only thing you can do is check the temperature in the fresh food section and it should read 34-27 degrees. The temperature controls should both be set at half of the #'s on the dial.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 05, 2009 | Whirlpool GD2SHGX Refrigerator
No water on dispenser Model#ED5CHQXKQ01
most likely you have a frozen water line to the dispenser. it could be inside the back of the refr section that is just too cold or inside the freezer door.
either one can be tested by allowing each to warm up for 15 to 20 minutes and see if you get water thru door.
do you hear a buzz from the water valve coil when you push the dispenser lever? if so then the water line is probably frozen somewhere.
Jan 15, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Jan 06, 2009 | Whirlpool Refrigerators
I have a 12 year old Whirlpool side-by-side refridgerator (ed20db) with water and ice dispenser. I have not used the water dispenser for years, but for some reason when I hit the lever yesterday, it did...
you have a possible water valve that is not shutting off all the way on the water dispensing side, it has 2 coils, one for ice and one for water. the other possibility is the dispenser tank is frozen, from being too cold in the refr. section and thats causing water pressure to continue running even when not pushing the lever. let the unit warm up slighty on the refr side and see if you can get water to flow properly.
if not working after warming up, then you might have to replace the water inlet valve.
Dec 29, 2008 | Whirlpool GS6NBEXR Side by Side...
Whirlpool ultraease warm on left side, dispenses warm water
not dangerous, i would recommend vacuuming coils under and behind refrig, make sure the fan behind the unit( cooling for compressor) is running full speed. the water is probably "warmer" then usual because the waterline runs across the bottom of the refrig, which appears to be overheating as it is. this should rectify your issue
Nov 20, 2008 | Whirlpool ED2FHEXNS 21.8 Cu. Ft....
Cold water dispenser on new whirlpool side by side dispenses lukewarm water...ice maker works a charm
there is a tank in the refrigerator section that hlds about 1.5 gal of water as you dispense it refills and pushes out the cold water. if your unit is new it will need a day to cool down the tank of water before you will get cold cold water at the dispenser
Hope this help explain how it works
Aug 01, 2008 | Whirlpool GS6NBEXR Side by Side...
New Kenmore Elite ice dispenser not working but water is
Should be no longer than 24hrs. Is the freezer good and cold.. has to reach a certain temp before icemaker activates. Might take little longer if you put a lot of warm things in freezer or refrig. when you made the change. Is there any water or ice in the icemaker itself? Water may not be getting to icemaker call them back out if it dont work soon thats what warrantys for :0)
Sep 02, 2007 | Whirlpool ED2FHEXN Side by Side...
Whirlpool ED2FHEXN Side by Side Refrigerator Logo
1,265 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
