Can't get feeder to work
I just acquired this copier and I cannot get the thing to feed so it can copy.I have already tried to follow instructions from within the copier itself...(You know how a certain light goes on, and then it tells you what steps to take), Well that didn't work either. And I cannot find setup nor operating instructions anywhere
PLEASE HELP!!!!!!!!!!!!!!!!!
Thanx...Linda
  • Grnnprpl Jul 07, 2008
    I was very happy to see that someone responded so fast! Thanx. But spacey me forgot to put the make and model, so here it is.
    Ricoh FT4421....I know it's an oldy, but I was told that it DOES work.
    I'll be waiting to hopefully hear from someone. So thanks again for acknowledging my prob
  • 42 Answers
We need to know the make and model!!!!!!!!!!!!!
Posted on Jul 07, 2008
  • Hadley Hudson Jul 08, 2008
    As far as a manual go to www.techmediacd.net for a operation manual.As far as not feeding, I need a little more info.Will it come to ready,jam,try to feed, what will it do when you hit the print button.
Copies run through feeder distorted
Document feeder Paper feed rollers should be cleaned with alcohol, blow out the document feed area with compressed air (computer duster), check feeder for bits of paper, post it notes, and signature flags. Clean glass, check for sticky areas on the glass.
Hope this is of some help.
Ed
May 12, 2009 | Toshiba E-Studio 3511 Color Copier
IBM 1422 not feeding 8 1/2 x 11 paper through multipurpose feeder
Go into the paper menu and set the multipurpose feeder paper size to letter. It will work if the paper size is set correctly for the MPF.
Apr 30, 2009 | IBM Infoprint 1422 Laser Printer
Canon NP 6050 Paper Feeder won't feed
Seems the wheels on the left side of the feeder maybe slipped or something, I turned them 1/2 way over so the gray rubber part shows, then they were able to grip the paper and feed it into the copier. That worked for a little while, then it did it again, I turned them again and it worked. Maybe I just need to make sure they have a little traction to solve the problem. Thanks for your website.
Apr 01, 2009 | Canon NP 6050 Copier
PAPERS WONT FEED THRU TOP FEEDER
im having the same problem was working fine then quit feeding
Mar 31, 2009 | Minolta EP4000/5000 CS/PRO Copier
Paper will not feed into officejet 4215 to fax or copy, it stalls in the feeder.
Sometimes the feed rollers can get dusty or acquire other deposits on them that can cause a loss of friction, resulting in feed problems. You could try cleaning them to see if it would help. Here's the instructions:
Cleaning the Rollers
Post back your results and good luck.
Oct 10, 2008 | HP OfficeJet 4215 All-In-One InkJet...
Won't copy document through feeder.
When you say it won't copy, do you mean that the paper won't move in the feeder or that no copies come out? Do you get any error messages? Try using alcohol on a swab or lint free cloth and clean the feed rollers in the feeder. They sometimes get paper dust on them and they can't pick up the paper. Also make sure that any paper sensors that detect when paper is in the feeder are intact. Occasionally they get stuck or broken. Hope this works.
Sep 22, 2008 | Canon imageCLASS D760 All-In-One Laser...
Will not copy
If the paper isn't feeding in the ADF (automatic document feeder - upper paper feeder) then the ADF roller assembly will need to be replaced. Try a copy on the flat glass area. If it work, then it's the ADF, If not then the upper scanner assembly with have to be replaced.
Apr 28, 2007 | Canon imageCLASS D880 All-In-One Laser...
jasbo
jasbo
