Question about Whirlpool Washing Machines
My Whirlpool washing machine (approx.9 yrs old) will not go into the spin cycle regardless of what wash setting the machine is on (regular, gently cycle, etc). Any suggestions? Do you recommend having a repairman look at the machine or based on it's age & problem, go ahead & get a new one?
MY wHIRLPOOL WASHER IS 4 YEARS OLD. 11 MINUTES BEFORE COMPLETION OF WASH, IT REFUSED TO GO INTO SPIN AND DRAIN CLOTHES. PUSHING "PAUSE" OR "CANCEL" WILL NOT UNLOCK DOOR. :
Posted on Mar 15, 2009
  • 413 Answers
Based upon the age, it may be as simple as replacing the lid switch.
Open and close lid, listen for 'clicking' sound. If no 'clicking' sound, replace lid switch. Here's how:
To access it REMOVE POWER, lift the console by one of three ways.
1. Look in the back of the console, in each corner there will be a screw, unscrew until the console can be pushed forward.
2. The trim on either side can be pried off from the top, grasp and pull forward to expose to expose a screw.
3. Insert a putty knife under each corner, push to release a latch.
With console lifted:
1. You will find a lid switch connector (white in color). Unplug the switch from the connector.
2. There will be two brass colored clips. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver down and away from you and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Tilt and slide cabinet forward to remove.
If you need further assistance, let me know
Regards,
reg501
Posted on Jul 07, 2008
I have an Estae(whirlpool) washer that i have had for 9 yrs. It works fine until it get to the spin cycle. Then it stops and the water stays in the washer and will not drain. Every different wash mode...
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Dec 12, 2010 | Washing Machines
Whirlpool washer will not spin
sounds like the timer is shot.
Apr 30, 2009 | Whirlpool Washing Machines
The spin cycle for my
Dear shelldon39, Fri 2-20-2009 9:24pm EST (USA)
Some machines will shut down during the spin cycle as a precaution to prevent damage!
They will do this if you overload the washer with clothes and/or use too much detergent!
If this doesn't help please get back to me with more details!
jack
Feb 21, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
No spin or agitation on washing machine
check the coupler it is the plastic and rubber piece that is in between the motor and the transmission
Dec 30, 2008 | Whirlpool Washing Machines
Frigidaire front load washer not spinning
Unsrew the bottom panel and u will find the pump to the right disconnect the hose from the back thats coming down from the tub.You will find a pocket behind the hose connect filled with all kinds of change probably enough to buy a pizza and a couple of beers. I also had a old credit card,gas pass bobby pins,hard plastic tags.chains and a hand full of sand.
My Frigidaire frontloader is 9 yrs old was close to buying a new one but this defintly fixed the problem..
works like new again.
Dec 16, 2008 | Frigidaire ATF6000ES Front Load Washer
Whirlpool AMW5125 washing machine approx 4 years old Spin action not working
your brushes are gone its a easy job and first thing is wright down the model number of the machine its normally on the door when you open it go to ebay on you should get some for £5 ounce you have took off the motor it that easy to put back on
Nov 11, 2007 | Whirlpool AWM5125/1 Front Load Washer
Only Gentle Cycle Works
You have a bad timer. You can take the cover off and verify. Look for burnt contacts.
Apr 14, 2007 | Whirlpool LSR5102LQ Top Load Washer
Washing Machines Logo
59 people viewed this question
Dan Webster
Dan Webster
Sal De
