Question about Honeywell Heating & Cooling
Someone in my house set hold temp (91). i cant change it. it is so hot in here. how do i change this setting?
  • 182 Answers
What kind of thermostat?Is there no "run program" button?
Posted on Jul 07, 2008
How do I bring up heat to 70 degrees on my Proselect PsTs21P52 thermostat which has been programmed?
Looks like you have a hold function. This will bypass the programming and "hold" your desired temp. If the temp rises but reaches a maximum of a certain degree than someone has set the maximum heat temp to that degree. Meaning you will have to enter the settings menu and scroll through to make the changes. You need the manual. Good Luck.
Apr 04, 2017 | Heating & Cooling
Adjusting Apollo hot water tank
I am not sure what you are asking, But i am going to assume that you want to know about changing the Temp on the heater for inside the house.
If the floor heat was installed properly than it should have a temperture manifold or adjustable thermostat for seperate heating.
You need to find the thermostat or manifold for the garage heat and set it at what ever temp you want the garage to stay at.
Then you can change the A B C knob to a higher setting A is cold B is warm ac is hot. So Increase your temp setting on the heater and this will increase your house water temp for hotter showers and faucet temps. However, they recommend not setting the temp above 120 degrees to prevent severe burns.
If you have a newer home increasing the Hot water heater temp setting may not change the temp at the shower or faucets if you have scald guard faucets installed in the house. This will require adjusting the scald guard valves on each faucet.
I recommend using a candy thermometer or digital thermometer to check the faucet and shower Temp prior to using them and make sure that you inform everyone in the house after you change the temp so that no one gets scalded.
I hope this answers you question, feel free to contact me if you need more help!
DR Wilkins
Oct 15, 2013 | Water Heaters
1992 olds cutlas 3.3litre a/c clutch comes on and off continuiously weather a/c is called for or not on the dash.engine cold or hot. rad fan also comes on when engine is cold and hot keeps cycling. when...
ok the ac will cycle even if its not on thats the way the factory has it set up.
the fan will also cycle the same way. but the temp of the motor has to do with
the thermostat thats whare i would be looking the thermostat may be bad
when you pick up a new one test it if it says 180 deg. that is when its wide
open check it with a temp guage a house hold type in a pot of boiling water
on your stove i have found 1 out fo 6 would be good go figure.
now the censors. one wire tells you temp guage 2 wires tells you its a
switch for the fan while the motor is running use the same house hold
guage a meat thermomiter will work just fine
i hope this helps you BOB !!!
Sep 23, 2011 | 1992 Oldsmobile Cutlass Ciera
TH8110U1003 Touch screen thermostats. My problem is I don't have a manual to show me how to operate it. But the big problem I'm dealing with now is when I set a temp. say I set it for 75 and the house...
If your program that you have programed into the stat is set to 73 it will go back to that setting if the stat is in the program mode....... Push the HOLD button on the stat and keep pushing it till it say permanent HOLD right above the buttons on the bottom and then you can set your temp to what you want. Here is a download link for the manual from Honeywell..
http://customer.honeywell.com/techlit/pdf/PackedLit/69-1894EFS.pdf
Mar 22, 2011 | Honeywell Heating & Cooling
Where is the thermast for a 91 mercury tracer 4 door cant find the thermastat in the car to change it .
Find the radiator hose that is attached to the front of the engine, under the housing the hose is attached to the tstat is located. Make sure you get the right temp tstat and a new gasket for the housing. Drain the radiator fully before you start the job or U will have antifreeze all over the place.
Mar 02, 2011 | 1991 Mercury Tracer
I cant adjust water temp 0n a single handle kohler shower valve
4yrs isn't very long, but I do believe the mixer needs a new cartridge in it. unless you have a loose knob/handle.But I don't thnk so. The temps should change almost immediatley. Have someone change the cartridge. It may need a special tool. If you think you can, do it yourself, the tool comes with full instructions. Make sure it does, consult with the pkumbing person .
Nov 09, 2009 | Water Heaters
Minimax pool heater cuts out at 91 degrees when remotely set for
Turn the temp set knobs on the front of the heater all the way up do both pool & spa temp.
If that doesn't help flip the selector switch on the front of the heater the pool temp. This switch doesn't control what heats up Pool or spa it just selects the heater on and which thermistat to use
May 23, 2009 | Pentair Minimax Ch 400,000 Btu Propane...
I cant figure out how to change my thermometer back from celcius to fahrenheit
Make sure that the odometer is set to miles and not kilometers. Hold the button down (while in the regular odometer setting, not the "trip odometer" setting) until it changes to miles. The temperature display will automatically change to fahrenheit. We just figured this out today.
Aug 23, 2008 | 2006 Ford Freestar
Contour comfort control
normally, if you have a hold option, there should be a hold button which when you press again should un hold the setting. have you tried pressing the run button. this would eliminate all hold function and just run the programmed temperatures.
Feb 16, 2008 | Heating & Cooling
Hot house,, effect on freezer temperature
cork....this is interesting. First, I'm going to suggest that you remove all the ice from the unit and clean it. Use a hair dryer to melt the ice and then make it dry. Reassemble. Many of these units allow you to remove the ice maker bucket. Don't forget to clean that up. There is a way on many of these units to turn off the ice maker...If you leave it too full, the defrost cycles will melt the ice together causing your problem. On my Kenmore, I keep the bucket about half full. Generally, the preset temp should be 40 in the fridge and 5-10 in the freezer. If either of these is warmer, you have shorter food life. By the way...Mom will feel warmer if she has a humidifier in the house. Get the cold vapor type.
Dec 19, 2007 | Kenmore 53642 / 53644 Side by Side...
Heating & Cooling Logo
29 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
