Question about Hoover S2220 Flair Bagless Upright Vacuum
Flair motor shorting out?
My 4-month-old Hoover Flair exhibits an intermittent failure: after running for 30 minutes or so, the motor will no longer switch on. Toggling the switch all the way forward turns on the brush, which spins away merrily, but in both the middle ("bare floor") and forward ("carpet") position, no motor, and thus no suction.
As noted, this problem is intermittent and if I let the Flair sit for a few days, it seems to restore function, but only very briefly.
Could this be heat-related? Is there perhaps some sort of "cut-off" in the design which disables the motor if it seems to be running hot?
I should note that Hoover "support" did not respond at all to my email inquiry well over a week ago, so unless I can get the Flair running reliably in fairly short order, back it will go. I will then shop for a product whose manufacturer actually supports it.
Thanks for any assistance you can provide.
  • 3 more comments
  • Anonymous Sep 20, 2008
    Same problem here though it hasn't magically started working again. The brush spins away in the carpet mode but no section and nothing at all happens in the barefloor mode.
  • stasyschneid Oct 07, 2008
    same problem here((( only used it once and it broke!
  • Anonymous Nov 29, 2008
    Yep.  Same thing.  Broke after 6 months.
  • kutterkan Jan 03, 2009
    Me too. Same symptom. Started after about a year.
  • jshotluv84 Jan 12, 2009
    mine's about 5 months old and it did the same thing. except the floor option seems to work, but the carpet option definitely doesn't work... the brush won't even rotate.
There's a thermal cut-off when the unit has overheated. Mine does this quite often and I remedy it by emptying the canister and making sure the filter is clean, especially of lint and things that prevent good air flow.
Posted on Oct 16, 2009
THERE IS A STICKER RIGHT ON THE BACK THAT SAYS IT NEEDS 30 MINUTES TO RESET. THE FILTER MUST BE KEPT CLEAN. i USE A SECOND VAC TO CLEAN IT. WORKS WELL THAT WAY.
Posted on Jan 17, 2013
Hoover flair needs a belt replacement
Remove the small screws on the bottom of the powerhead. On some models there are 2 hidden beneath the rubber wheels in front. Just pop the wheels out with a flat blade screwdriver and remove those two as well. Remove the hood and you have access to the belt, motor and roller.
Here's the correct belt:
http://vacuummedic.com/product.php?id=86
Good Luck!
The Vac Dr
Jan 30, 2013 | Hoover S2200 Flair Bagless Upright Vacuum
Attachment of vacuum base to handle
yes friction and the air suction presure keep the head and the handle together.
Jul 25, 2008 | Hoover S2220 Flair Bagless Upright Vacuum
Hoover U5780-900 Windtunnel a month 1/2 old just started stopping when it is running and wont turn back on for a few hours why?
The motor has a thermal protection sensor on it. So your motor may be going bad, it is pulling to many amps for some reason, could be a clog somewhere or a bad bearing in the motor.
Feb 21, 2010 | Hoover U5780-900 Windtunnel Cyclonic...
Hoover Mach 4 Overheats and shuts down after a few minutes
You have lost air flow due to blockage. Look for blockage in the throat of the machine where dirt enters from the floor. Do this by removing the base plate or opening throat inspection flap if so equipped. Also detach the hose and drop a coin through to see if there is and obstruction in that area.
Sep 07, 2009 | Hoover U8145-900 Savvy Bagless Upright...
Carpet setting not working
there is a belt in the nozzle that is driven by a small motor in turn will drive the roller when set to carpet. did you completely dis-assemble the nozzle? ie, to remove the roller and clean the endcaps? this would also show the belt. The gear on the motor wears very easily and could also be worn. I would change the nozzle or get a new Flair. new nozzles cost about $25-$30.
Jan 12, 2009 | Hoover S2220 Flair Bagless Upright Vacuum
No suction
Sounds like your motor bearings are going bad. This is generally indicated by the motor overheating, and the heat transferring out through the motor pulley, which is where the belt attaches. So, your machine is overheating, melting the belt, and then tripping the thermal cutout. When it cools and you restart it, the belt is no longer functioning due to being melted, and this would make it not pick up on carpet. If you look at the motor pulley and it is turning blue: this is indicative of overheating.
The other possibility is that there is a clog, which is also causing your motor to overheat; so before you throw it away make sure all of your air pathways are clear.
The fact that you've had it 8 years is somewhat remarkable, however, since most vacuums of this type are averaging a 3-5 year lifespan. (And half that for bagless.)
So, check for clogs, and if it's not clogged, you're probably due for a new machine.
-R
Oct 01, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover Light on
ALTHOUGH MOST FILTERS SAY WASHABLE THEY DO STILL NEED TO BE REPLACE AS WASHING THEM SHRINKS THE FILTER AND EVENTUALLY CLOSES THE AIRWAYS. WHICH ALSO IF NOT REPLACE WILL OVER HEAT MOTOR IN MACHINE AND CAUSE MOTOR FAILURE.
Mar 27, 2008 | Vacuums
Need a part for a Flair vacuum
http://www.hoover.com/searchresults.aspx?type=1&keyword=flair
Go to the above website and at the bottom left you will see a section called "srevice and support".
This section may help in finding parts other than what is on the website.
Your vacuum is a Hoover and model is a Flair.
Feb 07, 2008 | Vacuums
Hoover Flair S2200
Should be the same, Hoover would only have one S2200 model and it doesn't matter who is selling it.
Nov 26, 2007 | Vacuums
Hoover S2220 Flair Bagless Upright Vacuum Logo
492 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
