Question about Gateway Computers & Internet
How can I change from a wired network to a wireless network using an iMac computer. I currently am using 3 of the outputs of the Siemens Gigaset SE567 to connect to computers in my home. I want to be able to connect to an entertainment unit (Wii) tp be able to receive NETFLICKS Thanks Harold Wagner
    Habit-Forming:
    New Friend:
  • 156 Answers
Use an external USB wireless adapter
Posted on Jan 17, 2018
SOURCE:
map9966
  • 2351 Answers
SOURCE: I just installed my siemens
Hi tbopper, install linksys software. Follow the instruction. Disable your anti virus / firewall software. (temporally). Make sure the PC with the wireless card is turned on.
Than open My Network connections & run windows Set up a home or small office network. Follow windows instructions.
That's it. When you restart your PC your Anti virus software should enable it's self. Check your firewall is also back on, if it's included in your anti virus it will re-inable it's self. Since your running a wireless make sure you enable security & password, other wise anyone with a wireless can tap into your wireless signal slowing your bandwith down.
To test your linksys is correct. Open internet explorer. In the address window type in 192.168.1.1 & press enter. Your settings should show up. Tech support is free with linksys.
Good Luck & Enjoy!
Mike
Posted on Mar 31, 2008
SOURCE: siemens ADSL Modem (model SL2_141) networking
i m reset the setting in my modem
my modem no is - sl2_141
192.168.1.1 this site is not open
plz solve my prob...
Posted on Aug 23, 2008
  • 5 Answers
SOURCE: siemens gigaset se587 wlan dsl
connection should be as follows..........
comp>>eth cable>>>modem or router>>>>>fone cable>>>filter>>>>wall socket
telefone cble>> ^
no ext should be there ....... no external device should be connected........
if using any device in any socket at home then make sure that they r filterd correctly .....
try resetting the modem/router..... then check the lights.......
last option is to unplug n re plug all the cables.....
80% this should wrk....
ny more q: mail me--dashvrista@gmail.com
Posted on Sep 25, 2008
Stellyx
  • 69 Answers
SOURCE: find the SSID or WEP key/ WPA Passphrase for siemens se567
If this printer is a network printer (it will say so on the box and in the manual) then on the printer itself in the settings screen there is an option that will say something to the effect of *network* in that selection you will find a "print network information" and that page will have instructions and also the IPyou are looking for in order to connect.
Posted on Nov 13, 2008
Joed911
  • 4338 Answers
SOURCE: Gigaset SE587 networking adaptor
Any of the major manufacturers ie: Linksys, Belkin, D-Link Cnet etc. will work. Go to your local computer or office supply store and tell them the router that you have and they should be able to direct you in the right direction.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Nov 23, 2008
How to change password in gigaset 504 agu
How to change my Gigaset 504 Agu wirless password
Mar 13, 2012 | Siemens Efficient Networks SpeedStream...
I have a siemens gigaset 504 AGU wirless router. I moved to a new apartment and changed my land line and internet company provider. Connected my router and wirless network was detected and connected...
Gigaset 504 AGU black color signal antenna . How to find (Host Name) and only showing there mac address ans ip address. i want see witch one using my net and we want fine friend computer name in my router .
Jul 01, 2011 | Siemens Efficient Networks SpeedStream...
Why my Siemens Gigaset 504 AGU wireless disconnect in my HP laptop??
There is a great article at Working with Windows Wireless Networks
If you need more help post back! Thumbs and testimonial are welcome!
Mar 20, 2011 | Siemens Efficient Networks SpeedStream...
I cannot connect wirelessly to a siemens gigaset se 572 router although I can connect with a hard wire. I am using a Netgear WG111T wireless adapter. When I try to repair the connection I am told that the...
Check the type of encryption the 572 is set for, I've found a few cases where it needs to be WPA and not WEP. As a temporary measure, you could switch off wireless security.
Lastly, check your not getting a channel conflict, if a neighbour has a wireless access point with the same channel, you may get problems, which will require logging onto the 572 and changing the wireless channel
Apr 06, 2010 | Computers & Internet
Wireless LAN not active
loptop not connect to router as wireless
Oct 11, 2009 | Siemens Efficient Networks SpeedStream...
Find the SSID or WEP key/ WPA Passphrase for siemens se567
Nov 13, 2008 | Computers & Internet
Power supply gigaset 8825
The power supply for the 8825 base is to be 13 volts AC, rated at 850 milliamps or higher. You can go anywhere from 13 up to 15 volts without hurting the unit, and a higher current rating is even better. We actually make them ourselves through bulk purchases of varieties of power supplys. Your next delimma will be the plug size, it is a pretty common size, most universal adapters will have the right size of the outer and inner connections.
Nov 16, 2007 | Siemens Gigaset 8825 Cordless Phone
Computers & Internet Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Thomas F. Schneider
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
