Question about Philips Magnavox 51MP392H Rear Projection Television
Magnovox 51MP3964H17 coverge problem
Hello, I moved furnature and when I set up the TV the colors were all mixed up I tried to converge but the red will only go side to side not up and down.
  • Philips Master
  • 8,617 Answers
You will need to replace both STK392-120 convergence ICs and about four of the 6.8 ohm 1 watt resistors. The following link has the replacement ICs and resistors and they provide free instalation instructions with pictures.
http://servicemanuals.vstore.ca/
Posted on Jul 10, 2008
I have a 52 in. tv magnovox the color on the screen is not as clear it has alot of red and the color scheme is medium
6d3e6c1f-c991-4dcf-aa4f-930b9d111d87.pngBelow are two of the most common problems encountered with projection TV sets.
Problem #1 - CONVERGENCE PROBLEM
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on Projection TV sets and a fairly simple DIY fix.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
CONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from TvRepairKits.com
Their kits include a step by step instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Problem #2 CRT Fluid is Cloudy
Projection tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around video.
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc.
May 20, 2012 | Philips Magnavox 51MP392H Rear Projection...
Magic Focus button will not line up picture. Red and green colors shadow images.
The tv have a problems known as a convergence picture problems it is dead.The tv have any colors lines like R,G,B mis alignments,tv have any colors shadows pictures or 3D pictures look alike?Yes,than the tv convergence board it is dead and the causes of these problems.The tv convergence board must have to repair like replacing like 2 STk covergence ICS and some or all of it resistors too.To fixed the tv convegence board to solved the tv convergence picture problems.The tvs shops will cost u like $300-350 for parts and labors.
Sep 02, 2011 | Hitachi 53SDX01B 53" Rear Projection...
Won't stay in focus? keeps getting red out of focus.b
Tv have a problems known as a convergence problems,it dead.Any colors lines R,G,B mis alignment.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts must be replaced to solved the covergence problems.Try website like Tvrepairworld.com to buy a whole refurbish convergence board for the replacement.The Samsung/Akai tvs used the same convergence board.Or the shop will cost u $300-350 for parts and labors.
Aug 19, 2010 | Samsung Televison & Video
Tv just looks like i folded picture need help on configurance set
The tv have a problems known as a convergence problems,it dead.U have tools,soldering iron,solders.U know how to do solders?Try Ebay.com to buy a convergence Fuse(FL231).The big block of plastic call the FBT.Resolder the FBT.The 3 three fuses caps on (FL231) beside it.The covergence fuse cap in middle is dead,replaced the covergence fuse cap in the middle will solved ur convergence problems.
Jul 17, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Hello, my tv looks 3d
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
  • Screen looks 3D
93a1209.pngCONVERGENCE SOLUTION
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
May 12, 2010 | Akai PTH5498 54" Rear Projection...
I have a Mitsubishi WT-4211.The picture went to a 3D effect with a red outline.Is this a covergence problem?If so is there a repair kit?
Yes - there is a repair kit. Goto www.TvRepairKits.com
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 14, 2010 | Mitsubishi WT-42311 42" Rear Projection...
Red Covergance Issue
Solution:
Your TV has a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
Screen is bowed in or warped.
Using your original remote go-to the tv settings then goto the convergence or magic focus section.
Try to adjust the convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Its a fairly easy fix.
You can get a repair kit that includes all the parts from www.TvRepairKits.com. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself.
Jan 27, 2009 | Sony KP-46WT500 46" Rear Projection...
Colors Misalinged
You have what is known as covergence problems. Ok to begin with. 1 Go into customer menus goto SETUP do you have the "CONVERGENCE" option. If you do not the the likelyhood is you have the fl231 fuse problem and if you can solder and get it i recomend it a simple repair. ok if you have that option then try going in and autoconvergening if that didnt work try manual the red and blue convergence. if in the manual red and blue the crosshair didnt move then you probably have convergence power board problem if only one moved or just move a up and down or left of right then it might be a amp board issue. the other problems it could need a simple factory alignment.
Aug 26, 2008 | RCA HD56W66 56" HDTV
Colors red and green overlap
Covergence is off... Check convergence and see which color will not move in the convergence settings... That is the STK that needs to be changed out...
May 24, 2007 | Akai PT5492S 54" Rear Projection...
Adjust color convergence automaticly
I hate to tell you but if the colors are not aligning the way they used to is because the set has developed a problem know as a convergence problem,you should be able to align the colors (red,Blue)but if they are not going in is because the covergence IC's are going bad,If you are familiar with electronic service you can do some of the work yourself but sometimes still does require the help of a servicer to do the aligments from the inside,if you are not too familiar be safe and call for assistance.
Oct 20, 2006 | Zenith R56W28 56" Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
49 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
