The place where i stick my charger in is burned what do i do?
  • 23 Answers
If it doesn't work, since it's damage you'll probably have to get new USB ports. if you arent using a compaq with the Creativity Action Center, this means you have to get a new motherboard. Try some simple troubleshooting first, though
Posted on Jul 07, 2008
REPLACEMENT CHARGER MAKITA DHP 456 18V 4.0AH LITHIUM-ION
Here is the charger. it is priced pretty good. I have seen it at other places for over $100.00 https://www.factoryauthorizedoutlet.com/makita-7-2v-18v-pod-style-and-stick-style-3-hr-charger-model-dc1804
Oct 21, 2016 | Makita Drills
This is the 2nd battery for my Acer aspire 1410. I just went off and won't come back on. I don't think it was the correct charger. Could that be burning up the battery?
Batteries only last up to a tear and if charged all the time, less time than that. The charger; if it is the correct voltage and output current with the correct plug fitting, it should be OK.
Oct 16, 2015 | Acer Aspire 1410-8373...
I am not getting any response when I turn on vaccum
battery is not making contact with the connectors on the charger. check for obstructions, etc, and see if you can make contact.
Jul 23, 2015 | Hoover Linx Cordless Stick Vac
Mycharger on my samsung table 10.1 tab 2 won charge please help
The problem might be that your battery is too old. Rechargeable batteries have a limited number of charges that it can undergo.. usually between 300 and 500, before it starts to not hold much power anymore.. If it's not the battery,
I suggest you test the charger.
if you have a multimeter/voltmeter, unplug the charger from the wall socket and tablet. Set multimeter to measure Resistance/Ohms.. Touch one end of your meter cable to one of the charger pins(that you would otherwise stick into the wall socket) & the other end to the end you otherwise stick into the tablet.. all you're looking for is 'some' measurement... if you get a reading, test the other pin (wall socket end of the charger) .. if you get a reading again, then your charger should be fine.
Next look at your tablet, where you stick the charger into.. does anything seem loose/out of place? if no.. call the shop you bought it from an ask for assistance over the phone (typically shops offer advice freely over the phone)
Nov 12, 2014 | Tablets & eReaders
When plugged into charger both lights show green but chair not fully charged
First measure the voltage of the batteries at the charging socket of the joystick.
Sep 28, 2014 | Pride Jazzy Select Elite
Why doesn't my battery charge? Why doesn't the charger's light come on?
Hi Suzanne! Follow these steps to check that your charger and battery are working properly.
1. Unplug the charger for at least 30 seconds.
2. Plug the charger back in. The blue light on the charger should flash once.
If the blue light flashes once this is an indication that the charger is still functioning properly. If the blue light does not flash, the charger will need to be replaced. Follow this link to order a replacement charger. LiNX Battery Charger
3. Place the battery in the vacuum and turn it on for 30 seconds. (even if it does not turn on or powers off)
4. Turn the vacuum off.
5. Remove the battery and place it in the charger.
If the light on the charger is solid blue this is an indication that the battery has been reset. Allow 3-4 hours for the battery to fully charge. The blue light will start to blink slowly to indicate the battery is fully charged.
If the light on the charger is flashing blue or there is no light at all this can mean that your battery needs to be replaced. Follow the link to order a replacement battery. LiNX Lithium Ion Battery
Hope this helps!
Jul 28, 2014 | Hoover Platinum LiNX Cordless Stick Vacuum
Battery for Hoover Linx will not charge. Charger blinks very fast.
Jan,
your battery is Shorted. it is time to buy a new vac or a replacement battery.
sorry that is such a short hand answer but that is what the charger is telling you.
Apr 22, 2014 | Hoover Platinum LiNX Cordless Stick Vacuum
I have a samsung phone. the version is a rant. the part where i stick my charger in, (the metal part inside) came out with my charger when i pulled out my charger. i use tape to tape the charger into...
There is probably a short from the phone charging port to the actual charger. That is the reason why it is turning on and off because it is connected then disconnect quickly. Try and fiddle around with it until it stays on and then don't touch it and it should stay. Or I would recommend going to the retailer whether it be At&t Sprint etc. And either try to get a refund or get a new one. They are fairly cheap 10 to 15 dollars.
May 04, 2011 | Cell Phones
When i place a 18v battery which is dead on the charger both red and green lights come on and stay on. This is happening with both batteries. and neither holds a good charge. What is the problem? It is...
In some model the FUSE got burn.But if this is not your case one or both,batts and charger are burn.Try first to change the batt, then if this not work, change the charger.
Nov 08, 2010 | Ryobi Multi-Volt Battery Charger
Gps won power up when car charger burn frm fuse
Unfortunately it sounds like when the car charger went bad it also did in the board on your tt. It would be cheaper to just purchase another unit than to get this one repaired out of warranty. My advice would be to sell it on ebay. People buy these all the time for spare parts.
Hope this helps
May 09, 2009 | Tomtom GPS
Computers & Internet Logo
David Payne
David Payne
