I have the bd p1600 and i was on netflix when a firmware upgrade screen popped up and i accepted but then my player froze. now i can turn it on and off and i can open and close the tray but the player stays on load can play anything
Here is a video instruction on how to hook up the P1600 model to Net Flix.
A firmware update may be required to get NetFlix on the P1500 model.
http://www.samsung.com/us/support/downloads/BD-P1500 Otherwise, I have seen little information on the P1500 supporting NetFlix.
Please give feedback for this answer, thanks.
Don't upgrade the firmware on your Samsung BD-P1600. The firmware from Samsung is faulty and will most likely crashh your machine, Permanently !!!. I made that mistake last night. Now I have no Video output to my T.V. from any of the video outputs on the blu-ray player. Also the unit turns on but will only display LOAD , OPEN, CLOSE, ON, OFF... Nothing Works now.. This is apparently a common issue and there are several forums discussing this problem.. No fix that I have found !!
On fornt of the player you have the buttons for opreation.You can use these buttons to operate your DVD player with out remote.
I have attached a image for your BD-P1600 player so your reference
1.DISC TRAY :Opens to accept a disc. 2.DISPLAY :Displays the playing status, time, etc. 3.Remote Control Sensor :Detects signals from the remote control. 4.OPEN/CLOSE BUTTON :Opens and closes the disc tray. 5.SEARCH/SKIP BUTTONS :Goes to the next title/chapter/track or goes back to the previous title/chapter/track. 6.STOP BUTTON :Stops disc playback. 7.PLAY/PAUSE BUTTON: Plays a disc or pauses playback. 8.POWER BUTTON :Turns the Blu-ray Disc Player on and off. 9.USB HOST:A USB memory flash stick can be connected here and used as storage when connected to BD-LIVE. It can also be used for firmware upgrades and MP3/JPEG playback.
Thanx
Your not alone. I went into the menu system manually to setup clock and language and other options. I had to download and install the upgraded firmware available from the website, and then to disable the anytime+ samsung feature...then suddenly after hours, and after the samsung help line told me to return the unit, it worked.
good luck
I assume you have a wireless or Ethernet connection for your BDP1600? It may not be working and the first thing your player needs to do is get a firmware update and this won't happen if you do not have an Internet connection. If you do have an Internet connection, look to see if there is some sort of "software update" button somewhere within the tv-based menu system.
