Question about Emerson EWL20S5 20 in. EDTV-Ready LCD Television
Emerson tv goes off after a few seconds
When I turn my Emerson tv on, it will appear normal. Only a few short seconds later, it will turn off on its own. Does anybody know what the problem could be?
  • Emerson Master
  • 5,568 Answers
The shutdown is probably caused by the power supply, although it may not be at fault, just trying to prevent a fire.
There may be other circuitry that is failing and drawing excessive current and most supplies are designed to turn off if the current drawn exceeds a certain maximum.
This is not a problem you can solve without technical skills.
Posted on Jul 07, 2008
Volume keeps going down to zero
Emerson volume keeps going down Questions & Answers ...
www.fixya.com > Forum > Tags > volume keeps going down
Emerson volume keeps going down related problems. Ask your Emerson ... myEmerson TV. It turned itself down to zero and stayed on the screen and wouldn.
Emerson Flat Screen TV volume trouble? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Aug 10, 2011 - My Emerson 32 inch does similar things, volume just goes to 0-100 and stays there. ... Why is the volume on my Emerson flat screen TV not working and how could i fix it? Whats wrong with my Emerson Flat screen tv? Why is the volume on my Emerson flat screen TV not working ...
Jul 13, 2013
My son has an Emerson tv it keeps turning down by itself. Anyone ...
Aug 24, 2006
More results from answers.yahoo.com
Emerson TV problem ' Techlore
Dec 15, 2015 | Emerson Televison & Video
Emerson LC320EMX stays in standyby mode
one of the transformers has an issue which is very common for that model. You can get a replacement inverter from www.tvrepairworld.com
Mar 31, 2012 | Emerson LC320EMX 32 in. LCD HDTV
Why does my tv turn off by it's self after a few
Either a power board problem or something in the set is pulling the power voltages down---if under 26 inches it may not be fixable.
Mar 19, 2012 | Emerson Televison & Video
It stays on for 15-20 seconds then turns off
the tv is shorting out. means its probably old and needs to be replaced. if its not very old its just got a faulty part. get ahold of manufacturer emerson technical service and they will tell you your options.
http://www.emersonaudiovideo.com/support/contact.php
If your items are one of following model numbers;
19 LC8 EMERSON LC190EM1
22 LC8 EMERSON LC220EM1
26 LC8 EMERSON LC260EM1
32 LC8 EMERSON LC320EM1
40 LC8 EMERSON LC407EM1
19 LC7.5 EMERSON LD190EM1
32 LC7.5 EMERSON LD320EM1
Please call 866-309-8819
Operation hours: (Mon-Sat 8am - 11pm EST, Sun 9am - 6pm EST)
*Above model numbers with the "R" in front also call 866-309-8819
Example: RLC190EM1 or RLC220EM1
All other model numbers
Please call 800-256-2487
Operation hours: (Mon-Sun 6am - 8pm PST)
-Derek
Jan 11, 2011 | Emerson EWC13D4 13 in. TV/DVD Combo
I have a LCD Color TV, but when turn on, green
The most common problem is the Power/Backlight Inverter Board. There are 6 mini transformers on the board, one goes bad and the TV will turn itself OFF automatically for " Protection Mode". Replace the whole board or replace the bad mini transformer.
Part number#
Whole board, BA71F0F01042
Mini Transformer, LTZ2PC0MS008
Mar 02, 2010 | Emerson LC320EM8 32 in. LCD TV
My 32 inch emerson powers up and cuts off after a few seconds.
Hi, I own the same TV and had the same problem. It's the #1 plaguing issue with flat panel TVs made by Funai corp. Emerson is made by them. Normally, when this happens, the TV goes into " Protection Mode " because of a failing circuit board.
The most common thing to go out on flat panel TV is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board. But, I can't say it's 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptom. I'm willing to bet you have the same problem like mine. One of six Inverter Transformers when bad on my Power/Backlight Inverter Supply Board. I replaced it and it works fine again. d66cb18.jpg
You have a few choices:
1. You can try leaving the TV unplugged for 30 minutes so the TV can reset itself.
2. If you have some electronic experience, if you can find and purchase a Service Manual at Tvtechcenter.com:
http://www.tvtechcenter.com/xcart/search.php?mode=search&page=1 It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists.Usually, cost under $6. And most cases the new part cost less than $15.
http://www.partstore.com/Part/Funai%20Corporation%20Inc/Funai/LTZ2PC0MS008.aspx
http://www.encompassparts.com/products/?LTZ2PC0MS008
3. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
Sep 10, 2009 | Emerson LC320EM8 32 in. LCD TV
It being emerson 32" hdtv lcd turns on but immediately turns off
This is Emerson's #1 problem.
The Inverter Transformer on the power supply/backlight inverter board goes bad. It's what powers up the screen for your TV. When the part goes bad, it doesn't have enough juice to power the screen and the TV automatically turns off. You have 5 Inverter Transformer on your board.
You can fix the problem by replacing the whole board or replace the bad Inverter Transformer.
Here's where you can get a new board for a good price:
http://www.shopjimmy.com/catalogsearch/result/?q=lc320em9+inverter
Or, here's where you can get replacement Inverter Transformers:
Jun 17, 2009 | Emerson LC320EM9 32 in. LCD HDTV
My emerson tv is turning it self off
my tv shuts off after a few seconds what can i do to fix it
Sep 12, 2008 | Emerson EWL20D6 Television
Tv wont turn on
The sound can be called screaming from the power supply,it senses a short and creates a frequency you can hear,the set has a problem and it needs to be repaired,I will check the horizontal out put transistor for a short,sometimes it goes bad without a reason and sometimes the high voltage transformer is also bad and both have to be replaced but first the transistor only if it goes bad again then you replaced the transformer too.Seek assistance from a servicer if you are not too familiar with tv service,it can be dangerous.
Oct 02, 2006 | Emerson EWC1903 19 in. TV/VCR Combo
Emerson EWL20S5 20 in. EDTV-Ready LCD Television Logo
253 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
