Question about Car Audio & Video
Scosche - Aftermarket In-Dash Installation Kit questions
I have a 1999 mercury sable sedan and one of my family members gave me a
Kenwood KDC-119 Radio. He didnt give me anything else with it. The kit comes with some wires and im wondering will i have to crimp or solder anything in order to install this radio?
  • 624 Answers
The radio should have come with its own wiring harness as well. The install kit will have a wiring harness that connects to the factory harness the original radio is connected to. You need the Kenwood harness and match the colors of the harness to the colors on the install kit harness. They should be crimped to make sure you have a solid connection and do not let any loose wires hang out anywhere. Then it is a good idea to use electrical tape and insulate each wire, then tape them all together for easier installation.
If you do not understand how to do this, you really should take it to someplace that installs radios, they can do it quickly and easily. No worries then about if you have made any mistakes. I have seen many a radio in my shop needing repair from people who thought it was easy to install a radio, but didn't really know how to do it. One mistake can end up costing more than buying a new radio.
let me know if you need any more help.
Posted on Jul 07, 2008
Kenwood kdc-119 wiring diagram
You may download a copy of the manual here. The wiring diagram is on page 19.
Nov 30, 2012 | MTX Ford Explorer/Mercury...
Will this work for a kenwood dnx6160 dvd reciever
Yes should work fine for the 6160.. if you have not bought the 6160 yet.. but a 6960!
Feb 03, 2011 | Scosche Industries Scosche Ma1543b Mazda 3...
How to hook up a kdc-105 kenwood in a sunfire
There are 3 things you need to purchase for this install. 1) The factory spec install kit. 2) The factory spec additional wiring harness. 3) Antenna adapter.
Find the easied way to remove the plastic cowling around the radio and ac controls. Usually you can locate screws helping to retain the plastic dash parts. Be careful not to break the plastic dash by taking your time and looking over and over the part ofr connection hardware. Once you have located and removed all/if any screws, carefully pry out on the piece you are removing. There are often metal clips on the back of the piece that also help to retain the dash. Once that is removed, unbolt/unclip the factory stereo and slowly pull it out of the dash. Remove the factory harness from the backside of the factory stereo. DO NOT CUT THE HARNESS!! The wiring harness you have purchased is designed to plug and play into the factory harness. All you hae to do is color match the Kenwoods harness with the one you purchased. When wiring the two harnesses together use connectors **** a **** connectors, crimp connectors so forth and so on. If there is wiring you will not be using, take some electrical tape and tape the bare wire. We don't want a short. Once you are sure and have doubled checked that all the wiring is secure and matched, reverse the order of disassembly.
The plastic install kit should replace the factory radio size difference. Just remember to take the metal sleeve tha came with the kenwood and install it into the plastic install kit via the instructions provided. Slide the Aftermarket stereo into the sleeve you just installed. Then you are ready to make all the needed connections. Before you reassemble everything make sure to do a test run with your stereo. If all is well reassemble and jam on.
Sep 10, 2009 | 1999 Pontiac Sunfire
Kenwood kdc-119**
No, you have the battery wire hooked up to the ignition switch.
Here is the owners manual with wiring diagram.
Yellow wire must go directly to fused HOT (battery).Not through ignition switch, red goes to switch.
Good Luck
Jul 30, 2008 | Kenwood KDC-135 CD Player
Car Audio & Video Logo
260 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
