Question about Maytag Refrigerators
I have a maytag refrigerator model number mfd2560heq and the inside water spout is not working. I have changed the water filter-that has not helped the problem
  • 24 Answers
The only time mine didn't work, and I have this exact model, is when I had it loaded with stuff and the air would not circulate well inside. I think the water line running through the refrigerator portion froze. Try to let the inside warm up a few degrees (put a thermometer in there and see what the temp is near the back). If it's below 32 degrees, you may have found your solution.
Posted on Nov 08, 2009
Change light bulb in Maytag MAN1956GE Refrigerator. Can't loosen bulb. Can't remove plastic "cage" around bulb.
Hello Jane;
My name is Peter. I am a retired field service refrigeration technician.
What you have provided is the standard manual number not the model number. The model number is on a label on the inside wall of your fresh food section near the top.
You may have a single screw holding the light cover on.
Note; the bulbs in a refrigerator like all of you appliances is specially designed for the service. They are a little expensive $8.00 - $10.00 each. Some food markets carry them. If not Lowe's or Home Depot.
Go into the following link put in your model number and a diagram will appear to help you.
Water Filters Lawn Garden Appliance Parts
Dec 12, 2014 | Maytag Refrigerators
Water on inside of fridge does not work water spout is located on the left side wall inside the fridge. I push the button, and no water
There is few things that could be the problem. 1. filter is clogged or not seated all the way. 2.Bad filter holder, check valve sticking. 3. Bad water valve. I hope this helps.
Aug 24, 2011 | Maytag Refrigerators
New filter installed. how to turn off "change filter" light
There is usually a reset button near the change filter light. Without the model number I cant tell you exactly where.Please comment me back so I can further assist.
Jul 30, 2011 | Refrigerators
Turn off the change filter light on maytag refrigerator
For my Maytag Refrigerator Model # MSD 2756 GE, I had to hold the "Light" & "Lock/Unlock" buttons simultaneously until the "Change Filter" light went off instead of the "Water" & "Lock/Unlock" buttons.
Oct 09, 2009 | Maytag MSD2651 HE Side by Side...
My maytag water dispenser not dispensing water
I am sorry I can not find a model listed Maytag Email me with the correct model or visit my site to see where to look for the model numbers.email is appliancepartsse@yahoo.comsite is below, Thanks, Sea Breezehttp://servicepartstec.blogspot.com/
Jun 09, 2009 | Maytag MSD2756G Side by Side Refrigerator
Filtered drinking water freezing in tank
You can cure this problem by ordering part numbers 12002776 and W10130482. Instructions are included with the parts.
Apr 08, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Refridgerated water spout suddenly stopped producing water
Have you changed the water filter. It should be located in the front loer grille of the refrigerator.
Jan 10, 2009 | Refrigerators
Maytag refrig (french door) water and ice on door stopped working at the same time.
1) Electric Water valve check up.
2) Water/Ice dispenser control check up
3) frozen plastic pipe inside door or/and chilled water container frozen
4) old water filter (clogged)
Dec 07, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
Refrigerators Logo
85 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
