It sounds like you need a general tune up.
The problem would be timing, your ignition should be set to the right timing to avoid that acceleration hiccups.
Check also the spark plug gap.
Hope that helps you out!
thanks for using Fixya!
Kabayan paki rate mo ko at nice comments!
First try to replace the Hi side hose w/ original one before u buy a PUMP assembly!
U could buy cheaper part in Banawe, Young Bros. is the store, they could get u a replacement and original w/ discount!
meron problema un pcm mo hindi kasi 100% sure yun pagrepair.Pero tingnan mo un connector ng pcm baka corroded na.kung di ako nagkakamali nasa consol box malapit sa gas pedal un pcm.Tangali mo un cover makikita mo na un pcm.Tangalin mo muna un battery negative bago tangalin un mga connector
The most likely cause is that there is air in the cooling system, you will need to bleed out the air from the system, an easy way to do this is to get a floor jack and jack up the front of the car as high as you can get it, fill the radiator and coolant recovery tank until they are full, then run the engine until it is at normal operting temp, shut it down and run a garden hose over the radiator, allow the engine to cool and check the coolant level again, remember the radiator fan does not come on until the engine is at the high end of the operting zone on the temp guage, about 225 deg F.
If you did not get a notice that somebody else was before you when you click on "POST", you were the first. If you posted first and immaterial whether somebody elses posts after you and the user does not come back to review/rate/view, then you get the FixYa after 7 days; If you posted first and then somebody else posted after you, your solution gets bumped down and the new gets #1. Am not sure if FixYa changed the method, but the user can only view the 1st solution and will see the second if after he rates the first as a TFT. Ganyan talaga una-unahan lang, minsan swertehan. Hindi mo masasabi na tama o angkop sagot mo. May pagkakataon mali nga ang sagot awarded pa rin or nauna ka nga pero mas pinili ng user yung iba. Best is to provide a technically correct solution and then let it be.
