Question about ViewSonic G75f+ Monitor
I have a VE170 View Panel
My monitor has these lines on the side of the screen that fade in more towards the middle. When I hook the monitor up to my Hp e/pc it works fine but once hooked up to my Gateway it doesnt. I downloaded the driver devic for the monitor, changed the resolution and nothing works. Any advise
  • 165 Answers
Try display control panel-advanced button-monitor and change refresh rate
Posted on Jul 07, 2008
My Acer S200hl monitor suddenly has horizontal white lines on the screen. It gradually fades from very severe lines on the right side to virtually unnoticalbe lines on the left. Any ideas?
It's dying. Pretty much simply that, something electrical or electronic (connections from panel to panel edge connectors, connection to circuit board, or internal to a panel matrix chip). Very likely unserviceable, if under warranty, take it back for service. Only other thing, check connector under back of monitor (if it has a connector at both ends). It's an Acer monitor, they aren't terribly durable, so if it's more than 2 or 3 years old, it's probably on it's way to deadville.
Dec 04, 2013 | Acer S200hl Abd 20" Class Widescreen Led...
Replacing a power switch on a gateway tower
The plastic front of your computer is the Front Panel
Slip this off to access the Power On Button assembly, which has the Power On switch inside it,
Outside view,
Rear View,
-> FOLLOW Anti-Static Procedures -> BEFORE reaching inside, your unplugged from power, computer.
If you do not know, post back in a Comment
Now look at the Rear view of the Front Panel again.
The LEFT Side Panel removes.
Looking at the Rear view of the Front Panel; note that the LEFT side of the Front Panel, is towards the Bottom.
See the three TABS sticking up along this edge?
One at the Bottom, one in the Middle, and one at the Top.
Flat plastic TABS formed out of the Front Panel itself.
Another point of view.......
The metal framework you see that the CD/DVD drive/s are in, is the Optical Drive Bay.
Look at the Optical Drive Bay, and towards the Top/FRONT.
See that flat TAB sticking in from the Front Panel?
Now come down to the Middle of the Front Panel.
See how out at the bottom of the Optical Drive Bay, there is a TAB sticking in from the Front Panel?
See the TAB at the Bottom?
They hook on the metal framework of the computer case.
They go through SLOTS in the metal framework.
The Tabs are pressed to the Inside of the computer case, OR to the outside of the computer case.
This action brings a hooked end on the end of the TAB, to the Middle of the slotted hole it\'s in, and then the Tab is free.
Suggest start with the Bottom TAB, press on it when hooked end is free of slot; then do the same for the Middle TAB.
Now perform this on the Top TAB.
The TABS are pressed to the inside, or to the outside, and pressure is put against them towards the Front Panel.
Push on the Tabs, to push the Front Panel away from the computer case.
Once all three TABS are free, the Front Panel will swing out, and remove.
Power On switch is mounted to this metal case,
I would open that case, and take the Power On switch itself, out.
Then see if I could find a replacement, or one that I could live with,
Direct link to Hardware Reference Guide,
Let\'s see if it works.
If not here is the Gateway Support page for it.
8512041 - Gateway Hardware Reference Guide (5-Bay uATX Case)
Go to Pages 37, and 38. (Top of Adobe Reader in page number box)
For additional questions please post in a Comment.
Apr 19, 2013 | Gateway GM5472 PC Desktop
Picture flickering and faded on left had side of the screen
if rebooting the monitor would do no good, try to get a spare monitor cable if the same flickering issue took effect. If it is so, then call your pc provider to repair your monitor..
Nov 26, 2011 | Philips 47 in. LCD HDTV
Monitor will not stay in full view when watching a movie.
Hello there,
What player are you using to watch the movie try to double click in the middle of the movie screen to get the movie to go into full view mode then you should be able to move the mouse over to the side and it should fade out .
if you need more help with this problem please let me know what type of software you are using .
Thank you and don't forget to Rate
Jan 26, 2011 | HP w1907 LCD Monitor
Corrupted display on LCD monitor.
Those lines on the right side show sign of damaged T-CON board, part of the LCD panel assembly, nothing you can do but getting the new LCD panel. The bright section on the screen looks like the backlight lamp reflector got out off the guide channel.
Sorry for bad news.
May 18, 2010 | Hannspree 28" Widescreen Flat-Panel LCD HD...
My EV 700 screen picture is condenced has one bright clear line in middle screen and two more lines faded,space in between lines
Sounds like a CRT problem but to be sure, hook up another monitor to the computer and if you get the same exact lines then you know its a problem with the video card, if the lines go away then you know its a problem with the monitor.
Jun 09, 2009 | Gateway EV 700 17" CRT Monitor
Line across screen
scane for virus and reinstall the operating system
May 30, 2009 | Computers & Internet
Getting lines across the monitor screen
It may have one of reasons:
1. "Dirty" supplying voltage in the monitor - check all electrolytic capacitor.
2. Bad controller chip - check if it gets extremely hot when working, also you may see darkened area on other side of the PCB where that chip is located.
3. Loosed connection between controller PCB and the display itself - disconnect the cable and clean contacts, especially of blade connector on display side, check if there are some overpressed contacts.
Mar 07, 2009 | Samsung SyncMaster 910T-Black 19" LCD Flat...
Viewsonic VE170 dislay problem
Your LCD inverter is giving up. You can either buy a new inverter but its a bit expensive,
or you can have it fixed by some electronic expert.
Nov 19, 2008 | ViewSonic VE170 (Beige) 17" LCD Monitor
Two light lines have just appeared
Your driver transistors are failing on those "Rows" of Pixels.. a common problem .. you could try "Pixel Reviver" software from here see if that helps.. but it possibly is on the way out sorry..
May 22, 2007 | Sony SDM-HS75/B 17" LCD Monitor
ViewSonic G75f+ Monitor Logo
150 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
