Our D-Link DIR 615 will not connect to our wireless devices such as laptops, game consoles,etc. it got a little wet because we had it in the window sill when it rained and now the globe icon is red instead of green
  • 23 Answers
All you have to do is buy a receiver and plug it into the USB slots of whatever you want to go on the internet and then install it. if you are using it to give internet to a computer created with Windows XP, then you do not need a reciever, as they have one built in.
Posted on Jul 07, 2008
How to connect TP LINK TL-WA901ND with Dlink DIR 615
Have you set the TP Link TL-WA901ND IP to have 192.168.1.1 as the default gateway ?
Also DHCP server is where ?
IN the TP LINK TL-WA901ND or in DLINK DIR 615
Only have one Router running DHCP and set the default gateway in the leases as 192.168.1.1.
What subnet mask are you using is it the same through out all devices ?
Oct 30, 2017 | TP-LINK TP link TL-WA901ND 300 / 11n...
I recently got a hp laptop for work and need to sync work, but it says not connected to internet. I have a d-link dir 615, wHAT DO I DO?
have you try to check your network on your laptop?, it should be an Auto Obtain mode in order for you to connect on your wireless router. Thanks
Sep 14, 2011 | D-Link DIR-615 Wireless Router
How to secure the router
HI
please find the ans.
Features
  • Firewall protection for your network
  • Parental control to supervise Internet activity
  • Works with wireless 802.11b/g adapters
  • Backward compatible with 802.11g and 802.11b devices including game consoles and digital media player
  • Secure wireless network using advanced
  • WEP, WPA, or WPA2 encryption
  • Easy to get started with D-Link Quick Router Setup Utility
Description The D-Link DIR-615 Wireless N Router provides better wireless signals for your network than existing wireless 802.11g technology. Upgrading your home to Wireless N provides an excellent solution for sharing an Internet connection and files such as video, music, photos, and documents. D-Link Wireless N products use Intelligent Antenna technology to transmit multiple streams of data which enable you to receive wireless signals in the farthest corners of your home. Not only does D-Link's Wireless N technology extend your wireless range, it also works with your existing 802.11g and 802.11b wireless devices.
Easy To Set Up:
The D-Link Quick Router Setup utility quickly configures your new Wireless N Router to get you up and running in minutes. Our D-Link Quick Router Setup walks you step by step through the installation process to configure your Internet connection, wireless network settings and security, and everything else you need to get your network up and running so that you don't have to be a networking expert to get it set up.
Easy To Secure:
The DIR-615 supports the latest wireless security features to help prevent unauthorized access, be it from over a wireless network or from the Internet. Supportfor WEP, WPA and WPA2 standards ensure that you will be able to use the best possible encryption, regardless of your client devices. In addition, this Wireless N Router utilizes dual active firewalls (SPI and NAT) to prevent potential attacks fromacross the Internet. Delivering great wireless performance, network security and coverage, the D-Link DIR-615 Wireless N Router is ideal for upgrading your existing wireless home network.
Specifications Technical Specifications Standards: IEEE 802.11n (draft) IEEE 802.11g IEEE 802.11b IEEE 802.3 IEEE 802.3u Device Interfaces: 4 10/100 LAN Ports 1 10/100 WAN Port Antennas: Dual external 2dBi Gain reverse SMA antennas Security: 64/128-bit Wired Equivalent Privacy (WEP) data encryption Wi-Fi Protected Access (WPA, WPA2) Advanced Firewall Features: Network Address Translation (NAT) Stateful Packet Inspection (SPI) VPN Pass-through / Multi-sessions PPTP /L2TP / IPSec Device Management: Internet Explorer v6 or late Mozilla Firefox v1.5 or later Java enabled browsers Leds: Power Status WAN WLAN (Wireless Connection) LAN (10/100) Internet Status Power Input: DC 5V 2.5A, through external power adapter Dimensions: 193 x 116.8 x 30.5 mm Weight: 940 grams (0.7 lb) Operating Temperature: 0ºC to 40º C Storage Temperature: -20ºC to 65º C Operating Humidity: 10% to 90% Storage Humidity: 5% to 95% Certifications: FCC Class B IC CE
Dec 11, 2010 | D-Link DIR-615 Wireless Router
DIR-615 Wireless Router: i have a d-link wireless router dir 615 that i've ...
if youve changed the password on the router since the other computers logged onto the network, then you need to delete the network history from those computers.
Otherwise those laptops will be trying to connect to the network with the old details.
May 16, 2010 | D-Link DIR-615 Wireless Router
I am trying to set up a wireless connection using dlink
Try changing the type of Wireless Security that your are using.
Mar 27, 2010 | D-Link DIR-615 Wireless Router
Connection, via D-Link Dir 615, lost after restarting computer
Did you tell Vista to "automatically connect to XXXXX network whenever in range" ?
Oct 20, 2009 | D-Link DIR-615 Wireless Router
I have a D-Link DIR-615, and the laptop says the Signal is Excellent, but it won't connect and it says Limited or no connectivity. Is the wireless symbol supposed to be steady on the router or is it...
You have not configured the DHCP or manually allotted IP address to the system or possibly a wrong IP address. This is the reason for limited connectivity.
The light blinks when it scans for the wireless devices nearby and as well as for data transfer.
Oct 14, 2009 | D-Link DIR-615 Wireless Router
Set up a d-link 615 wireless n router with laptop?
Assuming you have a broadband connection, yes, the D-Link 615 router can be set up to share your internet connection with your laptop. Please consult with your router manual on the proper steps to configure the device. http://www.dlink.com/products/?pid=565
Oct 12, 2009 | D-Link DIR-615 Wireless Router
Computers & Internet Logo
128 people viewed this question
David Payne
David Payne
