Question about Freezers
Old Upright Kenmore Freezer Help , please
I've just inherited an old 7. cu ft Kenmore Freezer. It must be about 20 years old and I haven't plugged it in yet. The door squeaks and yowls like a horror movie! I tried WD40 and Pam but so far no luck. It has one movable shelf and two that have the coils running through. Can I place food on the coiled shelves?
If it starts OK, what are the warning signs pointing toward imminent death?
As it's a freebie I want to give it a chance. Any particular tips to keep it happy?
The first model numbers are C675 then a string of long numbers
  • 828 Answers
If it is a shelve it is made for storage. A sign of imminent death on these old freezers would be its ability NOT to reach a low enough temperature when running. The older systems had heavier metals in the construction including the cooling systems. Some tips on keeping it happy would be to operate it in a place where you would be comfortable to sit for an extended period of time.
Posted on Jul 07, 2008
20.3 cu. ft. Upright Freezer GLFU2067F: We have an upright frigidaire 20 cu feet that is a...
Sounds like frost bulidup from door being left open warm air gets in making frost and ice. Need to turn off for 24hrs or so to let all the ice melt compleatey then turn back on keep door closed run for 24hrs check Temp. shoud be about 0 to -5 Deg. if good start using.
May 17, 2010 | Frigidaire 20.3 cu. ft. Upright Freezer...
Kenmore upright freezer only 3 years old running ,no clicking noise, no ice build up but won't completely freeze although set to 7 (lowest temp)
check door seals, also check vent direction, a dial or lever in fridge, it adjust how much air goes to fridge and freezer
May 07, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
12 year old freezer won't get above +20. Could it be the temp control dial?
I think you meen below 20 . Its mostlikely low on freon. if only half or less of the evap coil has frost , you low on freon. Then you have a leak in the system.
Dec 01, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Only one half of my chest type freezer freezes? It is old. Bought at least 18 years ago. Help!
My recommendation is to get rid of this 18 year old freezer as it is costing u a fortune to keep it plugged in. Then ask yourself if you really need an additional freezer at all?? If you do, consider purchasing a new small one that is really energy efficient. You will be way money ahead I assure u.
Apr 26, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
sounds like you have compressor lockup-mike
Oct 22, 2008 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Freezer motor has burning smell
disconnect from mains. take cover off compressor electrics. check starting device - easy to replace
Aug 09, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Freezer Not Working
The most likely answer is a slow freon leak assuming it was getting to the right temperature before you went on vacation.
Jul 16, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Freezer stopped working
A no power to the compressor is a good sign as far as being repairable is concerned. Locate the temperature control. Unplug the freezer and jumper the two main wires that connect to the control. Plug it in and if the unit runs replace the thermostat.
Jul 04, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Freezers Logo
182 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
