Question about Refrigerators
LG REFRIDGERATOR MODEL LRBN20510WW: STOPPED COOLING--COMPRESSOR HOT---COMPRESSOR FAN OPERATING--HAS A CIRCUIT CARD & ELECTRONIC THERMOSTAT.
  • 1 more comment
  • susan ferrell Jul 07, 2008
    I read the compressor with a multimeter and had resistance between the common & run windings & the common & start windings.
    I am not satisfied that the compressor is bad. The refer is not completely "dead". The fan runs & the light comes on. I do not know how to check the circuit board or electronic thermostat. Can you give me more info. It no longer cools.
    Does anyone know how to check the circuit board & thermostat?
    Genius:
  • 2,035 Answers
You need a basic understanding first.....all the cold is made in the freezer, then a fan, circulates the cold into the refrigerator. If there was NO cooling in the freezer, and the compressor was running,then I would blame the compressor. However if there was cooling but just partial, then there may be failures with either the fan that cools the compressor, or the fan in the freezer that carries the cold into the refrigerator section, or with the defrost components that may cause a similar problem..ie: frost building up in the freezer and blocking air flow into the refrigerator. As you can see there may be one or more issues....one more I just thought of....the defrost control is on a circuit board, and it sends power to the compressor when it is done defrosting, that control may be bad.
Many repair companies will not work on LG as they can be a bit difficult....you may want to only have LG factory trained servicers.
Posted on Jul 07, 2008
    Brigadier General:
  • 6,966 Answers
Based on your posting/description, it would seem that the starting capacitor of the compressor is defective. This assumption is considering that the motor checks out not to be shorted, is drawing powere but not turning. This could all point to the failure of the capacitor to provide the initial kick to start the compressor motor.
Of course, it is also possible for the compressor to go bad but often it would be the capacitor.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
    Genius:
  • 1,665 Answers
SEE LINK (WHAT IS WRONG WITH YOUR REFRIGERATOR)
http://www.repairclinic.com/0088_4_1.asp
    Sergeant:
    Champion:
  • 417 Answers
If Its Stop Cooling Its Needs Regasing Ive Just got mine Regased My And Now It Works fine - i had the same problem
    Genius:
  • 1,142 Answers
Compressor must have gone bad thats the reason its getting hot
Posted on Jul 06, 2008
  • Maanita Chadha
    Maanita Chadha Jul 06, 2008
    f the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running.
    First, answer these questions:
    • Is the refrigerator completely dead? If so, see “It's stopped completely.”
    • Is the thermostat knob turned to the proper setting? If not, reset it.
    Next, see if the compressor motor is running
    The
    compressor is a football-sized case with no apparent moving parts. It's
    on the outside of the refrigerator at the back near the bottom. If it
    is humming or making a continuous noise and your refrigerator is still
    not cooling, there may be a more serious problem with one or more of
    several different components, we recommend contacting a qualified
    appliance repair technician for further help.
    If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
    • The compressor
    • The Thermostat
    • The overload, relay, or capacitor
    • The defrost timer
    • The condenser fan motor
  • Maanita Chadha
    The refrigerator never cycles offThe
    thermostat cycles the refrigerator on and off. The refrigerator
    normally runs as long as the temperature inside the refrigerator is
    higher than the set temperature. If the temperature inside the
    refrigerator is cold enough and the thermostat still does not cycle
    off, the thermostat may be defective. If so, you need to replace it,
    because it cannot be repaired. If the thermostat is not defective, you
    may have a problem with the sealed (refrigerant) system, in which case
    you should contact a qualified appliance repair technician.
LG Fridge not cooling refrigerator (freezer is fine, fan is running)
those sensors do fail but if the freezer is not as cold as it should be .then the refrigerator part will also not get proper cooling . TEST the freezer temp .
Sep 25, 2015 | LG Refrigerators
I have an NEC refrigerator model FR480 eight years old that has stopped cooling. Called the technician who can't get information with regard to the electronic controls. It appears that the compresor and...
Hi, do you mean the signal to stop cooling is faulty?
I guess the thermostat is faulty. Its the one which detects the temperature and send signals to the circuit.
Oct 10, 2008 | Refrigerators
Why do radiator cooling fans start when key is put in on position
Under normal operation, in low speed, only the LH fan is initially in operation. Voltage is supplied to the low speed cooling fan relay through circuit 60 BK/LG wire. When the relay is energized, voltage fed to the LH cooling fan motor through circuit 538 GY/RD wire. Ground for the cooling fan is through circuit 57 BK wire. After the LH fan has been energized for 5 -10 seconds the RH fan will start automatically. Voltage is applied to the RH fan motor through circuit 3829 LB/BK wire. BK wire circuit 57 is also the ground.
Under normal operation in high speed both fans should operate from the high speed cooling fan getting a command voltage on circuit 30 BK/LG wire. The relay energizes both fans through circuit229 RD/OG wire while the low speed fan relays are de-energized.
The fans will come on immediately when the airconditioning compressor clutch is engaged mode and when the vehicle is in Drive. OBD-II trouble codes are P0480 low fan 1circuit, P0481 hi fan circuit & P0482 medium fan circuit.
Jul 14, 2014 | 2006 Ford Escape
I have a lg frige model #lrbn20512ww. it quit cooling both upper and lower yesterday. are there any known problem with the compressor or could it be somthing else. the compresor runs for about min the...
unplug the ref remove the back panel place a fan behind the ref to cool the compressor when you can place your hand on the compressor then you can clean the condenser coil and plug it back up make sure the condenser fan motor is running
Nov 18, 2010 | LG LRBN20510WW Bottom Freezer Refrigerator
Tempstar furnace when the thermostat is fan on the fan from the air compressor turns on not the air circulation fan in the bottom of the furnace
Y or yellow and G or green are connected in the "auto" setting, as G is fan and Y is cool, the Y and G wires are somehow, energizing the Y wire that goes to the AC unit to run cool, take thermostat off exposing the thermostats sub base Y and G will be there along with R, red, 24volt ("hot leg" of 24 v power) W white= heat, and C common, 24 volt ("neutral leg" or "common" leg of 24 power) common is where all the various 24 volt circuits (cool, heat, fan,) terminate or return to complete the circuit, just as a AA battery nas a positive and negative side of power, so does the furnace and all electrical circuits, its common as all circuits terminate there , its the opposite side of power fro whish all circuits begin, red is the :hot leg" and enters on RED red to WHITE=HEAT
RED to YELLOW=COOL
RED to GREEN= FAN
auto =Y & G connected
on= R & G connected
if you jump red to green, which is fan on, no connection should exist to yellow in on ! only auto!
May 27, 2010 | Heating & Cooling
Haier RRTG21PAAW
Well, your answer would seem to be simple...but in truth it could be many a issue. Just because the light is on does't mean anybodys home. Basic, (a) the cold control (dial in fresh food section that usually shows the word "off" at the warmest point on the dial) try turning it up to its coldest. Sometimes it might not reset after it turns off when it senses its cold. Also try tapping in the area of the control. If the freezer fan is not operating this or the defrost control could be the issue. (b) The defrost timer (mechanical or electronic) might have fail to advance out of defrost. Advanced items, (a) The compressor and or compressor relay and overload might be bad. (b) The evaporator fan is not operating (controled by the cold control circuit). (c) the condenser fan failed, which will cause the compressor to fail or shut down due to overheating. (the condenser fan is controled through the compressor circuit. These advanced items would need a multimeter and a understanding of circuit diagrams.
Ric
Mar 08, 2010 | Haier RRTG21PAA Refrigerator
I bought an LG fridge, initially it worked well
U go in firmly demmanding the manager and tell him u want a new refridgerator cause the one u sold me is junk
Oct 31, 2009 | LG LRBN20510WW Bottom Freezer Refrigerator
No cooling or compressor operation
Compressor and evap fan cycling are controlled by a circuit board as well as the defrost. It is all in serie - once your defrost kicks in contact is cut from the evap fan and compressor - once defrost is finished the switch reverts back to normal operation and your evap fan & compressor turns on.
Most common causes of this issue is either a defrost timer fault or control board (burnt resistor or bad board).
Inspecting and changing the control board will usually fix the issue - if your evap fan comes on after changing the board but not the compressor then you have a bad compressor.
If you have one of those units like some whirlpool/Kenmore/Inglis that have electronic controls in the refrigerator section, this is the board that controls the thermostat and compressor on/off cycling. The board behind your freezer is also connected to the board in your fridge, this one controls the defrost.
Sep 27, 2009 | Amana Refrigerators
Refridgerator/Freezer stopped cooling
if the compressor was very hot to the touch, suspect you have a compressor fault
Oct 02, 2008 | Refrigerators
My LG LRBN20514ST Fridge is not cooling
where to look for the defrost timer on the LG top freezer modle
GR-S392GCA
Aug 26, 2007 | LG LRBN20510WW Bottom Freezer Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
