Question about Pioneer Car Audio & Video
Pioneer p3000ib reciever connected to audio speakers with no problem but dont know why the 2 rca woofer cables to amp dont work i tried with new signal cables and still a no go...The woofer and amp work fine when connected directly to ipod
    President:
  • 624 Answers
On the right side of your display you will see a pair of buttons in the upper part of the face. These two buttons are vertical. The bottom button of those two is the SW/Bass button. Press this button and it switches the display to the subwoofer menu . Check the settings here to make sure the subwoofer output is turned on. Each time you press it, it should change menu setting. If you press and hold, it will change to the bass boost menu.
If this does not help you to turn on the subwoofer, it could be an internal problem in the radio that would need to be checked by a professional. Many of these Pioneer radios have an internal fuse that can open up. It is not the type of fuse you could change yourself. It is a surface mounted fuse that is very tiny and does not look like a fuse at all. It would require very good soldering skills to replace and knowledge of this particular component just to locate it.
If you found this free information helpful a good rating would be appreciated.
Let me know if you need any more help.
Dave
Posted on Jul 06, 2008
How can I hook up BIC F12 subwoofer to Onkyo TX-DS838 receiver? Will the receiver power the subwoofer and other speakers?
Get a RCA cable and connect from your amp where it said Sub Woofer in the Pre Out box in the back of the amplifier top left hand side and take it to the "Sub In" located in the back of your Sub woofer bottom right hand (White round connector).
Good Luck!
Aug 06, 2014 | Onkyo TX-DS838 Receiver
Broken connector in subwoofer connection on receiver
The only thing you do is to open your receivers,then locate the output connector if you see the female RCA jack ,then push it out the broken piece ,that's it
Jul 27, 2008 | Audio Players & Recorders
I just bousght a martin ash home thearer ..how can i conect the bass??
I bought one last night i think its a fake.... doesn't even have instructions. If u figure this out let me know. But i just look up the site called the white van scam... i bought it from some guys in a white truck. And it sounds just like wat they sold me with the same canvas
Apr 18, 2012 | Audio Players & Recorders
Power sub woofer is not working on my pioneer vsx-81txv everything is working all the speakers except the power sub connection at the back all i can hear is the hissing sound when i try to connect the sub...
Hissing? How loud? A sub isn't even capable of making high frequency sounds at normal volumes.
The Pioneer manual would tell you how to enable and test the subwoofer output.
Page 17 and the MACCV procedures on Page 33 (auto) or 43 (manual)
Jun 13, 2011 | Pioneer VSX-81TXV Receiver
How can i test my rca output jacks with a test light? pioneer deh p3100ub. hooked up spkr, nothing. tried one rca plug to white(lt) and then red(rt). Unit has 4 rca jacks, 2 for subwfr and 2 for front...
:) the rca jacks have to be connected to an amplifier,, their signal is too lay to even light a bulb.. you have to connect it to a car amplifier and then from the amplifier to the speakers..
Just so you'd know,, once your deck plays and you hear music on your speakers through your normal speaker wires,, RCA jacks work..
Ok you have 4 jacks,, 2 subs and 2 front.. These should connect to a preamp,, which takes 4 inputs and allows you to equalize or adjust how the music should sound,, now from the pre-amp,, it runs to an amplifier,, thats powers the subs and another that powers the speakers.. Some amps have 4 inputs so you can use one amp for your subs mids and heights..
for example a basic music system is
1 cd player
1 pre amp
1 amplifier (4 inputs, 4 channel out)
you bridge 1+2 and connect this to 1 12" double coil sub woofer
the next 2 connect to 2 mid speakers example "rockford or ev 5 / 8 " and 2 tweeters for heights..
Thats a kicking tricked out basic car audio system,,,
Hope that helps you understand how it works..
Mar 12, 2010 | Pioneer DEH P3100UB Car CD/ MP3 Player
NEED TO KNOW HOW TO HOOK UP SUBWOOFER TO RECEIVER
Hi and welcome to FixYa,
Offhand, most receivers do not have a built-in sub-amp but do have a line level sub woofer out. What is then required is an active subwoofer or an additional mono amp for the subwoofer speaker. The receiver will then be connected through an RCA to RCA cable and the subwoofer speaker connected to the add-on amp.
Good luck and thank you for asking FixYa.
Aug 15, 2009 | Pioneer Audio Players & Recorders
Pioneer DEH-P3000IB... Hook up RCA cables to 2, 2 channel amps for front and rear control. Supposed to be able to set rear to either rear full or sub... can't find how and all I'm getting is sub response.
Here are the directions according to the manual:
1 Use MULTI-CONTROL to select
SW CONTROL.
2 Press MULTI-CONTROL to display the
setting mode.
# Press BACK to return to the previous display.
3 Press MULTI-CONTROL to select the segment
you wish to set.
Press MULTI-CONTROL repeatedly to switch
the segment in the following order:
REAR SP (rear speaker setting)—PREOUT
(RCA output setting)
4 Use MULTI-CONTROL to select the desired
setting.
Turn to change the setting.
When REAR SP (rear speaker setting) is selected.
REAR SP:SUB W(subwoofer)—REAR SP:FULL
(full-range speaker)
When PREOUT (RCA output setting) is selected.
PREOUT:SUB W (subwoofer)—PREOUT:REAR
# When no subwoofer is connected to the rear
output, select REAR SP:FULL.
Hope this helps.
Oct 13, 2008 | Pioneer Audio Players & Recorders
Connecting a sub-woofer to Pioneer VSX-453 surround reciever
I got the same issue. But, I go ahead hooked it up two banana plugs on teh VCR outlet. It works fine on my Cerwin Vega Sub.
Nov 08, 2007 | Pioneer VSX-453 Receiver
More bass
Run one set of RCA lines from head unit to amps if you only have one set of pre-outs on the head unit, then at the amps, use an electronic crossover to split between the two amps, and this will also allow you to control what frequencies go to which amps/speakers. You should use one amp for the speakers and the higher power amp for the subwoofer. You should not try to connect both to the subwoofer. Use 4gauge cables if possible. If you have more questions, just ask.
Oct 29, 2007 | Pioneer GM-7200M Car Audio Amplifier
How do i know if my amp is blown
Hey Yoo,
Go to Radio shack and get you an adapter that will take an earphone jack and convert it to RCA male.  You use this to simulate the signal coming from the reciever.  Hook up to a Cd player or Walkman, anything with an earphone output jack. Test that the device actually puts out music or anything worth listening to.  Connect the device to the input of your amp, with the car running, and the reciever turned on.. This will tell yo if the signal is getting from the reciever to the amp. You may not be getting signal from the head unit.
If you still get no sound to the woofers, dsisconnect the woofers and try a different speaker.  If that speaker dont work,  Change setting and switches., and if you still get no sound, then your amp is toast.
Oct 23, 2007 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
Car Audio & Video Logo
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
